johncg Posted July 9, 2022 Posted July 9, 2022 I generally run 13" wheels but also have a set of 14" wheels I like to use for routine driving. Seems this size is becoming rare especially among sticky tire options. I've just about used up a set of Toyo R888 tires in 205/55-14 and 225/50-14. Sadly, Toyo no longer make the smaller front size, or I haven't been able to find them. The only option I have found is Hoosier R-7 in 205/55-14 which I'd use on all 4 corners. Any suggestions?
MV8 Posted July 10, 2022 Posted July 10, 2022 R888R are available in several 13s and a 185-60-14 that may work for your rim width.
MoBoost Posted July 10, 2022 Posted July 10, 2022 I’m running a set of 195/60R-14 Falken Azenis RT660 SL. Wear rating of 200. Not much time on them, but they throw pebbles into the car, so reasonably soft compound.
johncg Posted July 10, 2022 Author Posted July 10, 2022 2 hours ago, MV8 said: R888R are available in several 13s and a 185-60-14 that may work for your rim width. Thanks for this. These are the size many lower powdered Caterhams came with but I've been using larger tires and also staggering.
johncg Posted July 10, 2022 Author Posted July 10, 2022 1 hour ago, MoBoost said: I’m running a set of 195/60R-14 Falken Azenis RT660 SL. Wear rating of 200. Not much time on them, but they throw pebbles into the car, so reasonably soft compound. Thanks. While I don't put a lot of faith in the tread wear ratings, I am looking for tires in the 20 to 40 range if I can find them. For example, I used a set of Avon ZZR tires recently and I think they are rated at 20. These were 13" and unavailable in 14.
coffee break Posted July 11, 2022 Posted July 11, 2022 I got a set of Dunlop summer tires from Tire Rack 185/60-14. The tread wear is 200 as I remember.
johncg Posted July 11, 2022 Author Posted July 11, 2022 11 hours ago, coffee break said: I got a set of Dunlop summer tires from Tire Rack 185/60-14. The tread wear is 200 as I remember. Thanks!
johncg Posted July 11, 2022 Author Posted July 11, 2022 On 7/10/2022 at 5:22 AM, MoBoost said: Here's what I've found so far for 14 inch tire solutions - 4 Hoosier R7 in 205/55-14 Tread wear = 40. The issue is that these are not recommended for road use even though they are DOT - 4 Toyo R888R in 185/60-14 Tread wear = 100. - 2 Toyo R888 in 225/50-14 Tread Wear = 100. May only fit on rear. Thanks. While I don't put a lot of faith in the tread wear ratings, I am looking for tires in the 20 to 40 range if I can find them. For example, I used a set of Avon ZZR tires recently and I think they are rated at 20. These were 13" and unavailable in 14.
johncg Posted July 11, 2022 Author Posted July 11, 2022 Here's what I've found so far for 14 inch tire solutions - 4 Hoosier R7 in 205/55-14 Tread wear = 40. The issue is that these are not recommended for road use even though they are DOT - 4 Toyo R888R in 185/60-14 Tread wear = 100. - 2 Toyo R888 in 225/50-14 Tread Wear = 100. May only fit on rear.
NSXguy Posted September 3, 2022 Posted September 3, 2022 Curious what you end up going with here as I need to order new tires for my 14" panasports. I've been evaluation options and come up with similar results as you pointed above. I'm also contemplating getting some 13" wheels for more tire options. Will look to decide in the coming week and order.
johncg Posted September 3, 2022 Author Posted September 3, 2022 2 minutes ago, NSXguy said: Curious what you end up going with here as I need to order new tires for my 14" panasports. I've been evaluation options and come up with similar results as you pointed above. I'm also contemplating getting some 13" wheels for more tire options. Will look to decide in the coming week and order. Since these are my street use only tires and I live in the Pacific NW, I have going with 205/55-14 Hoosier Sports Car DOT Radial Wet H2O Tires 46115H2O from Summit. I've clearly made some trade offs here so think about whether this is the right choice for you. I run slicks for other uses (track, autox, etc)
11Budlite Posted September 3, 2022 Posted September 3, 2022 33 minutes ago, NSXguy said: Curious what you end up going with here as I need to order new tires for my 14" panasports. I've been evaluation options and come up with similar results as you pointed above. I'm also contemplating getting some 13" wheels for more tire options. Will look to decide in the coming week and order. I've been using Toyo R888R 185/60-13 on my Caterham and been happy so far. When I have to replace the Avons on the stock 14" wheels I wouldn't hesitate to replace them with R888R's too. If you want to try them out you're more than welcome to come over to Higganum and we can swap them to your car as long as you have the 4 x 108 PCD.
Anker Posted September 3, 2022 Posted September 3, 2022 The R888Rs are fine for track, but not for autocross. It is near impossible to get heat into them, even with a 1 mile+ fast course. The temperatures have to be in the high 80s before they get decently warm. It is weird to have to put blankets on my tires when everybody else is spraying theirs!
John B Posted September 3, 2022 Posted September 3, 2022 Your post gave me the idea to get off my butt and get rid of some of the wheels I'm not using. A nice set of Minilight 13x6 & 13x7 wheels if you're interested.
11Budlite Posted September 3, 2022 Posted September 3, 2022 1 hour ago, Anker said: The R888Rs are fine for track, but not for autocross. It is near impossible to get heat into them, even with a 1 mile+ fast course. The temperatures have to be in the high 80s before they get decently warm. It is weird to have to put blankets on my tires when everybody else is spraying theirs! Thanks for your input Anker. I should have clarified that I've only used my R888R's on track days.
johncg Posted September 3, 2022 Author Posted September 3, 2022 3 minutes ago, 11Budlite said: Thanks for your input Anker. I should have clarified that I've only used my R888R's on track days. I run the Yoko R888 tires now (worn out) with larger ones in the rear vs the front. The front smaller one is no longer available so I had to look for another solution.
NSXguy Posted September 4, 2022 Posted September 4, 2022 11 hours ago, John B said: Your post gave me the idea to get off my butt and get rid of some of the wheels I'm not using. A nice set of Minilight 13x6 & 13x7 wheels if you're interested. John- PM'ing your now. Interested.
NSXguy Posted September 4, 2022 Posted September 4, 2022 13 hours ago, 11Budlite said: I've been using Toyo R888R 185/60-13 on my Caterham and been happy so far. When I have to replace the Avons on the stock 14" wheels I wouldn't hesitate to replace them with R888R's too. If you want to try them out you're more than welcome to come over to Higganum and we can swap them to your car as long as you have the 4 x 108 PCD. Looks like what John has to offer may work for me. so i'll work that angle. Thanks for the offer. Hopefully we can still get together before the season is over!
11Budlite Posted September 4, 2022 Posted September 4, 2022 (edited) 8 hours ago, NSXguy said: Looks like what John has to offer may work for me. so i'll work that angle. Thanks for the offer. Hopefully we can still get together before the season is over! I thought you might be interested, hope that works out. I still don't have my car registered but hope to have that done sometime soon. Still have 3 more track days to do this season. One in NH in Sep and two in NY in Oct. Edited September 4, 2022 by 11Budlite
NSXguy Posted September 4, 2022 Posted September 4, 2022 Trying to see if i can make the NJMP track day this year... It's a tight schedule!
