Just delivered this Morning before the driver headed up a little north to drop off another.
edit: oops put this in the wrong spot. missed the dedicated build threads. Mods either delete or move please.
Edited by captain pabst
note about being in wrong location
Done.  Congrats on the arrival!  What options did you add other than the stripe and weather gear?
Thanks!
its Series V with lowered floors
Heat!
Carbon seats
4 piston brakes
track day cage
shift lights
map pockets
4 hours ago, JohnCh said:
If you optioned the cage, then there is no point in asking if you plan to track it :)
oh hello!   What’s your local track @captain pabst ?
Congratulations on Christmas arriving early!
I'm the guy from 'a little up north'! 😆 Congratulations! Thanks for doing the crate unboxing and removal first, the driver knew exactly what needed to happen and we were offloaded in 30 minutes!
Congrats! Might as well put that other car in your garage up for sale. 😉
Great color and looking forward to the build!
Summit, I haven't been this year but look forward to the build on this and going from there.
Glad you guys got it unloaded so quick. I got about 5 minutes notice before he showed up so I was extremely short handed.
Optioned but not included at all. I have quite a few missing things, including a missing pick list which could explain a lot, but makes reconciling what is and isn't there even harder.
  • Sad 1
I've made some progress, Front suspension is on. We put the wheels on for fun ( I have a 5 year old )
I did the suspension while everything was very low to the ground and put it on jack stands after.
Engine and Tranny are ready to be bolted together.
Seats are just placed in the interior.
Having a lot of fun so far ( even amongst the looking for the correct hardware for each step)
I am very biased. But love the green. Good luck. I can’t  offer many insights as mine was factory built but happy to take pictures or measure anything on my car if you need. Mine is a 2022/2023 so it should be very similar.
So one thing I find to be daunting is the drilling of the steering wheel. I have come up with the following 3d model that should take some of the guess work out of it. Feel free to use it as you please. The hole at the center is 2mm and I used a small drill bit here to center on the divot in the back of the wheel.
The holes for the drill bit are modeled as 6mm. I measured my bolts as 5.8mm
This is designed around the felt wheel. The thinking being there is a pointer at 12 o'clock and then a flat on the bottom to align with the text of the wheel (assuming it is square).  the gold is from my kid and the paint pens...
steeringdrill11mmextension.stl
Yes, that transmission tunnel is tight.  Given production tolerances, some transmissions rest against the side of the tunnel requiring extra effort to create a gap.  Any updates from Caterham on your missing roll cage?
My missing parts including roll cage and pick list are en route. I hope it has everything. Seeing some other threads where there was 1 missing radiator mount and I have the same issue. Probably best to be the lowest number in a group of cars coming over instead of the highest like mine was.
  • 4 months later...
Have you driven the Shenandoah Circuit?
  • 3 weeks later...
Indeed, I have driven all of the tracks at Summit, but not every layout.  Only been on track there with a Porsche GT4.
I drove the Shenandoah Circuit at the LOG30 track day in 2010.  My Elise was stock at that time.  I had just sold my first Caterham off to Cape Cod.
The Caracciola Karussell is a hoot.  When I was there the concrete was nice and smooth. I hope it's holding up well.
  • 3 weeks later...
Anyone Know about de-pining the Body side of the Engine harness? I've got a no start and it appears the culprit is in this connecter. Pin numbers are for reference and probably not the actual connector because I'm not sure of the numbering on this connector. But It goes Red-5 White-6 black-7 on the engine side and then on the body harness it goes to White-5 Red-6 Black-7 (Red and White have switched positions). Leading to Crank Signal being at ECU pin 7 instead of 12 (which is supposed to be a power ground), and Crank Return is at Pin 11 (correct) and Power Ground is at pin 11 instead of 7.
