Hello! I've been lurking for a while but am in the early stages (second week!) of building a 420R.
I've decided to blog the build, for several reasons (i) I've found online build blogs to be a fantastic resource and help (thank you!) and so I wanted to contribute what I can back to the group, (ii) documenting the process for myself and (iii) as a way of connecting with the Caterham community. Never blogged before and having a rocky start self-teaching Wordpress, so apologies for any mistakes and expect the format and structure to bounce around a bit ... but for now, the blog can be found at Caterham Chronicles.
There is information on the blog about why I'm building, spec etc. I started with installing the engine and am now progressing through the front suspension. I'm finding it enjoyable, frustrating, challenging, and rich with lessons. I'm really happy with the process - hopefully stay that way throughout!
Again ... Hello! Any questions, fire away :classic_biggrin:
  • Like 4
  • Thanks 2
Congrats on the acquisition. I got my 420r June 2024 from Greg. I didn’t have the space (or likely the skills) to build mine. So likely not helpful in the build questions. But I have gotten pretty familiar with the car and can check anything  since mine was factory built (so I’m 60% sure it’s correct).
I just passed 10k miles since June 2024. Get yours done by Oct and come down to njmp for the annual get together.
And I won’t take offense to the “flat” green comment on the color choice.
Thanks for the offer! May need some help with details ... the Build Manual can certainly be a bit vague and a quick photo of a Greg-built car could be the perfect answer.
I still go back and forth on the color. Have always loved green (with yellow, but like your silver stripe as a more modern choice!) but was tempted away by something a bit brighter. Hopefully won't offend to many with my comment 😳
Wow! Great start on the blog, I put it in my RSS reader and I’m going to keep up on it. Good tips already, mine is in final assembly now. Similar spec.
Nice work, newer blogs like this are helpful to future builders, as Caterham makes lots of small little changes over time so the older blogs can have some confusing/incorrect bits in them.
PS I saw a mention of painted bolt heads to ensure they are tight on future checks. Many bolts go through powder coated parts and you can NOT trust a painted line. Just because the bolt hasn't backed out doesn't mean it isn't loose. Prime candidate bolts for this issue are the engine mounts into the block. There are others as well. Bottom line is, on a 7 you need to do proper spanner checks regularly.
Thanks ... and good point!
trust is a dirty word. when it pertains to anything that you risk your life with.  I always loved the tech inspections as they added to my safety.
  • 4 weeks later...
I finally got around to reading @chrisp993's blog. It's well worth checking out if you haven't already done so. It's brought back a little trauma from my build, but other than that, I've really enjoyed it.
  • 4 weeks later...
Quick update that my build is complete :classic_biggrin: and I'm now putting those frustrating break-in miles on the car. Blog still needs work to improve referencing and navigation but most of the content from my build is online.
  • Like 4
  • Thanks 2
