sf4018 Posted June 22 Posted June 22 (edited) This 2018 Caterham Seven 420R SV is a option loaded left-hand-drive model that was built by the current owner. Power comes from a 2.0-liter Ford Duratec inline-four linked to a six-speed manual transmission and a limited-slip differential, and the car rides on 13” alloy wheels with Eibach adjustable coilover race dampers, aero wishbones and four-wheel disc brakes including uprated front ventilated discs. The interior offers a quick release MOMO steering wheel, and carbon-fiber elements include the dashboard fascia, sill covers, and rear stone guards. Seats are equipped with Schroth 5-point harnesses. The wide body SV version car with lowered floors is finished in black with white and red stripes. A red “7” accents the grille, and additional details include a red certified race roll cage and black boot cover. The car is equipped with an independent front suspension and a De Dion rear axle with Eibach racing adjustable coilovers on front and rear. The 13” alloy wheels have silver centers and are wrapped in new Toyo R888 tires. Braking is handled by four-wheel discs with four-piston front calipers and ventilated front rotors. The GRP racing seats have black padding and Schroth branded 5 point harnesses. The MOMO steering wheel is mounted on a quick-release hub and fronts a carbon-fiber dashboard that houses a 160-mph speedometer, a clocked 9k-rpm tachometer, a shift light, and gauges for oil pressure, coolant temperature and fuel level. The digital odometer indicates 3,000 miles. The Carfax report lists an issuance of an Alabama title in August 2019. The 2.0-liter Ford Duratec inline-four was factory rated at 210 horsepower and features a Caterham-branded valve cover and intake plenum as well as a stainless-steel long-tube header and a polished right-side muffler to black track day rear exhaust. Power is sent to the rear wheels through a six-speed manual transmission and a limited-slip differential. Sequential shift lights provide indication for ideal shift timing. Additional track related safety equipment include the plumbed in fire extinguisher and 55 liter fuel cell. The standard locked ECU has been replaced with an unlocked SBD Motorsports MBE9A4 ECU. The car is titled as a 2018 CATERHAM CARS SEVEN using the VIN AL19AN00X00072922. The title carries a 3500 miles actual notation. The Carfax report shows no accidents or other damage. The car also is convertible for racing purposes and has a decorated racing history with wins in HSR (Group 3), SVRA (Group 12) and NASA (SU) series events. Log books for all series will be part of the provided documentation. A 2nd set of Caterham wheels wrapped with used Hoosier F2000 slicks are included. Caterham 420R SV, Chassis No. SDKLDK5SL18974074 Fresh set of Toyo R888 tires mounted on Caterham 13" rims, 6" front, 8" rear. 3,000 Miles Indicated 2.0-Liter Ford Duratec Inline-Four 6 Speed Manual Gearbox R Pack upgrades Track Suspension Pack Race Dampers Aero Wishbones Plumbed in Fire Extinguisher 55l (14.5g) Caterham Fuel Cell with external fuel pump Unlocked ECU - SBD Motorsports MBE9A4 Race Roll Cage Sequential Shift Lights Lowered Floors Rear Exit Exhaust System Six-Speed Manual Transmission Limited-Slip Differential Bilstein Coilovers Four-Wheel Disc Brakes 13" Alloy Wheels Black Paint w/White and Red Stripes GRP Racing Seats MOMO Quick Release Steering Wheel Spare set of 13” wheels with Hoosier F2000 slicks for track days, 6” front, 8” rear. Custom car cover for Caterham Seven SV bodies. For more pictures and any questions or offers please DM me! Simon Edited 16 hours ago by sf4018 Corrected CF Seats to GRP Seats 3
sf4018 Posted June 23 Author Posted June 23 1 hour ago, Croc said: Wow - thats a shock. Such a well prepared car. What next @sf4018? I need to make space for an endurance race car that’s currently being built from the ground up, sadly this car is the one to make way, but hopefully she’ll go to a great new owner! 1
scdude Posted July 6 Posted July 6 Still available? Would someone 6'4 250lbs fit in this chassis? I absolutely love your spec. Have to travel for next two weeks for family trips otherwise I'd be omw down to check it out from SC. Will respond as I can if you DM me/reply. 1 1
Croc Posted July 6 Posted July 6 7 hours ago, scdude said: Would someone 6'4 250lbs fit in this chassis? I Sure will in an SV. I had a gentleman 6'8" and 300lbs fit in an SV. You may need to tweak for roll bar clearances like lowered floor, different seats (maybe leather S Type seats?), take seats off runners and bolt through floor, etc. - you don't want to clout your head on a roll bar. Maybe go back to a regular non-overhead roll bar? I have taken some hefty gentlemen out on track - the biggest was 6ft and 360lbs. Dented performance somewhat. Plenty of options to work with to make it work for you. 1 1
UglyFast Posted July 6 Posted July 6 10 hours ago, scdude said: Still available? Would someone 6'4 250lbs fit in this chassis? I absolutely love your spec. Have to travel for next two weeks for family trips otherwise I'd be omw down to check it out from SC. Will respond as I can if you DM me/reply. Pfft. You could test fit in 7.2 if any time you want. and yeah, if my big (sexy) ass will fit in heated carbon Tillets, yours will. SV awesome. Lowered floors awesome. lemme know my man. Come on back from the beach and we can skrrt skrrt a lil bit. Cage and all. Give you a good idea what this 7 would be like. there is a different cage with D shaped openings (no top side bars) that would make life significantly easier for people who’s joints are like mine, old and crusty. But I’m stubborn and love this full cage setup. (Plus the colors, Go GAMECOCKS!) @sf4018 I’ll be in contact for a finders fee if this closes. lol. 1 2
TSnuggs42069 Posted July 6 Posted July 6 (edited) 13 hours ago, scdude said: Still available? Would someone 6'4 250lbs fit in this chassis? I absolutely love your spec. Have to travel for next two weeks for family trips otherwise I'd be omw down to check it out from SC. Will respond as I can if you DM me/reply. I'm about that size and I fit in an SV, even without lowered floors. Edited July 6 by TSnuggs42069
JimmyG Posted July 31 Posted July 31 (edited) I weighed 227lbs / 5'8" / 40in waist, and in my 2012 360R the stock GRP buckets like on this car were really, really tight. I then switched to the newer Tillets padded carbon seats, which are 0.5 - 1.0mm wider, still fit the narrow chassis, and was much more comfortable, but still very secure for hard cornering. For a heavier / taller person, you really should try the car out first, or just look for a wider SV chassis with the un-side bolstered leather seats with even more width for non-track, touring use. Edited July 31 by JimmyG
Ian7 Posted July 31 Posted July 31 35mm wide seats? hmmm LOL. Even if that were cm, that's still less than 14". 2
11Budlite Posted July 31 Posted July 31 I have a Tillett W1I-40 in my S3 and I can confirm that it is 35cm at the narrowest point. It's a really tight fit in a S3 Caterham!
Ian7 Posted August 1 Posted August 1 True, I've had 3 in the past, never had 'seats' though, just the old style cushion on the floor :-)
Rhs17 Posted Sunday at 01:55 AM Posted Sunday at 01:55 AM Hey is this still available? I’m interested
sf4018 Posted 16 hours ago Author Posted 16 hours ago On 8/8/2026 at 8:55 PM, Rhs17 said: Hey is this still available? I’m interested sorry it is sold.
sf4018 Posted 16 hours ago Author Posted 16 hours ago What a car, may be gone now but a lifetime of memories, videos and photos live on! 1 1
