Marine7 Posted June 22, 2012 Posted June 22, 2012 Offered for sale: 2002 Birkin S3. I purchased this car as a roller from a fellow member in December 2009. Over the past 2 years, I’ve endeavored to build a fast road car that I could be proud of and enjoy. The car is now complete and is a blast to drive. It has a total of less than 75 shake-down miles. It will need an ecu tune to extract serious power as I’m still running a base-map and have not switched to full closed loop running on the wideband 02 sensor. The car is a 2002 Birkin S3 chassis with live axel. It is fitted with 4 pot outlaw brakes, full interior, Ford 2.0 liter Zetec 3 (18k miles) fitted with Jenvey throttle bodies, Emerald ECU, Tech-edge wideband lambda, and Ford Type 9 5 speed. It has both full windshield and brooklands screen. It has both single roll-bar and full roll bar, clamshell and cycle fenders. I am also including a brand new Quaife LSD (NIB) that I purchased as part of a group buy. I’m asking $25,500 for the car and all additional items listed: Brooklands screens, mounting strap and Racetech mirrors Standard windscreen with spare mounting brackets and Raydot mirror Full canvas Toneau cover Birkini top (still in the bag) with hood hoop 2 roll bars (standard black and polished single) Heater (not installed) 2 center consoles (one mounted and one spare) Relocated ignition switch with separate ECU power/start button Jenvy Throttle bodies w/K&N filters Emerald Mdk3 ECU Wideband 02 sensor with real time gauge (mounted in center console) Raceline wet sump Raceline water rail Braided stainless fuel lines all the way to the tank Aero filler cap Clamshell fenders and brackets (used Caterham items but match well) The brackets will fit, but slight need modification to account for the birkin front uprights 2 spare fuel pumps (new) 1 spare Birkin starter (new) 2 additional 12volt power sockets installed in center tunnel Cast alloy Zetec 1 cam cover with Birkin wire cover MSD wires and distributor Fidanza adjustable cam gears Odessy PC 680 battery Wesco 4 point harnesses for both passenger and driver (passenger is not installed) DOT retractable seatbelts for both passenger and driver (driver not installed) Taylor Race Engineering custom annular release bearing Quaife trans cover with fill hole and vent Spare belts, cam cover gaskets, hoses, thermostats, filters etc All receipts in excess of $10k in parts alone, Birkin Build manual, ECU tuning manuals and a lot of things I’m forgetting at the moment. PM if you’d like more pictures or have any questions. I can also be reached at Jason.alford “at”ymail.com. Thanks Jason
Marine7 Posted June 22, 2012 Author Posted June 22, 2012 More photos of brooklands screen and single roll hoop. Also pictured are a few of the spares, clamshell fenders and brackets.
sevenup Posted June 23, 2012 Posted June 23, 2012 Does anyone have the specific paint code for this 2002 green Birkin?I would love to paint my Stalker this specific color...
11Budlite Posted June 24, 2012 Posted June 24, 2012 Sevenup - I remember someone (I think Folis J.) mentioning that he used the BRG from a 1995 BMW (paint code 312) to match the paint on his Birkin. I've also heard that the Mazda Miata SE BRG is pretty close as well. Just be aware that both BMW and Mazda have a metallic green that was close to BRG but doesn't look nearly as good as the solid BRG. I can't say for sure how close the two paints are to the Birkin color but it's a start. Hope this helps.
Marine7 Posted June 24, 2012 Author Posted June 24, 2012 Caterham BRG is very similar as well, though not an exact match. (the clamshells in the photo are Caterham green)
11Budlite Posted June 25, 2012 Posted June 25, 2012 It came out beautiful Jason, good luck with the sale!
sevenup Posted June 26, 2012 Posted June 26, 2012 Not to stray too far off topic, Z3's came in a beautiful not metallic brg, DunkleGrun (dark green) II 307, not to be confused with their metallic Oxford green and Boston green. I will either paint the Stalker DunkleGrun or Miata BRG. But I really like that Birkin green best!
Marine7 Posted June 28, 2012 Author Posted June 28, 2012 Couple of items I forgot to mention on my listing. The car also has a Fidanza lightweight flywheel and a Spec Stage 3 street clutch/pressure plate. Tony L came by last Sat for a look at the car, so interested parties may wish to contact him for his opinion. Cheers Jason
Croc Posted June 28, 2012 Posted June 28, 2012 Jason - The car looks absolutely beautiful in the photos. I hope there is a good replacement in the wings?
Marine7 Posted June 28, 2012 Author Posted June 28, 2012 Mike, I dont want to jinx things, but the plan is to replace it with a certain "car" that has 2 less cylinders and 1 less wheel... and thanks for the compliment. Its not perfect, but I'm very happy with the way its come together. Jason
Canadian 7 Posted June 29, 2012 Posted June 29, 2012 I can't believe this has not sold yet! Are things really this bad in the States?
Marine7 Posted July 7, 2012 Author Posted July 7, 2012 Update on the car. Tuning problem solved. Loose injector wire fixed and now the car runs like a scalded cat. Still for sale... I think ('cause it sure is fun to drive). Thanks 11Budlite for the help! Jason
Marine7 Posted July 7, 2012 Author Posted July 7, 2012 Also have to thank Tom C aka 1turbofocus and John C for their patient advice and assistance. The resources on this board never cease to amaze me. If you have a problem or a question, somebody will be there to help. Thanks and now back to the regularly scheduled program...
KiwiBirkin Posted July 8, 2012 Posted July 8, 2012 Are you intrested in selling the Birkini hood and hoop separately, I need one for my car and it's move to Australia and would be keen to purchase it.
Marine7 Posted July 8, 2012 Author Posted July 8, 2012 KiwiBirkin, For now I'm going to keep it all as a package. Cheers Jason
11Budlite Posted July 8, 2012 Posted July 8, 2012 Jason - It was my pleasure to finally meet you and your family, and to help you with your car. I'm glad it was a simple fix. Your car looks even better than when it was sitting in my garage! To anyone interested in this car Jason has spent a lot of time and money to get this car to where it is today. Are you sure you want to sell it now???
Marine7 Posted July 23, 2012 Author Posted July 23, 2012 Seveners, I'm lowering my offer to $23,500 for the car and all extras. Heck, you could buy the car, sell off the LSD, clams, cam cover, Birkini top and probably net have just over $20k invested in a brand new car with less than 100 miles on the clock. Given the current number of cars on offer, the hardest decision for a prospective buyer is which Birkin fits the bill. Kitcats duratec is certainly a beautiful and powerful car to consider. feel free to PM for more photos or to answer questions. Rgds Jason
