I am reasonably certain the application process is the same, not sure after that. Here's a link to the outfit here in Denver that I will go to. Their website may detail the specific process used for each type.
http://appliedplastic.com/
Now I get it. :jester:
Thanks,
Carl
  • 2 months later...
  • Replies 233
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Hey, Mike,
Just touching base. I know you've been busy with work, but have you had any time to sort out the start issue with your car? Tried to pm, but your mailbox is full. Sorry for letting the whole world know your a cyber clutter bug. :jester: . . . . :cheers:
Hi Shane,
PM mailbox is fixed - I forgot to renew my USA7s subscription - good now.
I pulled the harness off this weekend and am sending it back to Easy Performance for troubleshooting. I think they screwed up the wiring to the ECU as the engine keeps throwing codes. The band aid fixes the technician recommended were not helpful. I have a plan B in the works in case their troubleshooting doesn't do the trick.
Mike
Hi Shane,
Mike
Mike,
Sounds like you're narrowing it down. I'll be interested to know what Easy Perf finds.
Haven't got my 2008 5.3 swap into my 67 pick up working correctly due to hard shifting... found the custom wiring harness was short two wires from the tranny to ECU. Just got new replacement harness... hope that solves it. Very frustrating to figure out.
Update: I ordered another custom-fit harness from Speartech. The Easy Performance harness is going back for a re-work. Once repairs are made and they certify that it is good to go, I will sell it along with the E67 ECU.
Barring anything crazy, the car should be back on the road in a couple of weeks.
I went with Speartech also. I like the fact John was a GM power-train engineer and that they test run every harness prior to shipping it!
  • 4 weeks later...
Storker received a new set of specs this weekend. They are 5.75" Harley Davidson Daymaker LED headlamps.
http://i60.tinypic.com/33xik55.jpg
http://i57.tinypic.com/34gos42.jpg
http://i62.tinypic.com/24e46it.jpg
http://i58.tinypic.com/210kg0g.jpg
Awesome, Mike!!! :cheers: Okay, cutting to the chase; I'm assuming these fit nicely in your existing buckets.
Sorry, cannot get a shot of the beam pattern - electrical system is undergoing some work. You should be able to get info by searching the Harley forums.
The 7" LED ought to fit most buckets, but the best way to find out is to visit your local Harley Davidson dealer.
At $525 each they ought to call them Walletbreaker instead of Daymaker.
  • 3 months later...
MightyMike, I think I saw in another thread that you used a Quicktime bellhousing. Any issues, tips, or tricks during installation? I'm probably going to use one and was curious if there were any gotchas or prep items, like grinding part of it to fit the starter, or drilling holes, etc.
It looks like alignment dowel pins are sold separately. Do you have them? If not, any issues getting it aligned?
It bolted right up. No problems with alignment or having to grind, etc. My engine block had alignment dowel pins and those mated up perfectly. The only thing I recall having to do was use 2-3 different lengths of bolts - that was really a non-issue.
http://i57.tinypic.com/flzuyc.jpg
Edited by MightyMike
Perfect. Thx. I got nervous when I read their install instructions online, and they mention checking register bore run out and using offset dowels to correct alignment issues.
  • 1 year later...
My Storker recently had some cosmetic surgery. The rear corners were rounded off and the fenders were contoured to fill the gaps. IMO, the aluminum looks far better than fiberglass. I am undecided about painting the rear and am considering putting more aluminum up front.
http://i65.tinypic.com/21bnhqr.jpg
http://i66.tinypic.com/14ujmrp.jpg
http://i63.tinypic.com/29epzqd.jpg
