GunshipDriver Posted April 5, 2014 Posted April 5, 2014 So mine has a 3-4" vertical aluminum style knob... I've been thinking about getting about a 6" vertical delrin style knob and am making the assumption that it is pretty much a stock S2000 tranny and that if I find one made for it I could just screw it in. What do you all run / like and please share any pictures if you don't mind. Cheers, Eric
xcarguy Posted April 6, 2014 Posted April 6, 2014 My old setup; bought a shift knob from the UK and grafted it onto a stock Camaro shifter (this was a few years ago): http://www471.pair.com/stalkerv/gallery2/main.php?g2_itemId=6323 My current setup is an aluminum handle (ebay score) with a round black knob that has the TKO tranny shift pattern: http://www471.pair.com/stalkerv/gallery2/main.php?g2_itemId=22028
scannon Posted April 6, 2014 Posted April 6, 2014 http://www.knobmeister.com/ can make most any shift knob you want. Joe is a friend of mine and has made a number of custom knobs for me in the past. He makes a lot of other things such as etched glass mugs with most any logo you want.
Croc Posted April 6, 2014 Posted April 6, 2014 Ah...a my knob is better than your knob thread? I could show my knob off but I am too shy...:conehead: All jokes aside there was a good thread a while back here where everyone posted their knob photos: http://usa7s.com/vb/showthread.php?t=2216&highlight=knob
GunshipDriver Posted April 6, 2014 Author Posted April 6, 2014 Thinking about getting one like the 7" one here... http://www.twmshiftknobs.com/shiftknobs/shiftknobs_shop15.php?gearknob=Honda+S2000+AP2%202004-2009&twmonly= As long as it doesn't impede the view of the gauges it should work out... need to mock up a "tester" out of a paper towel roll and see if I like the ergonomics before pulling the trigger....
powderbrake Posted April 6, 2014 Posted April 6, 2014 Made my own out of aluminum. check out this thread on Ultralite shifters http://www.usa7s.com/vb/showthread.php?t=7023
JohnCh Posted April 6, 2014 Posted April 6, 2014 http://www.knobmeister.com/ can make most any shift knob you want. +1 for Knobmeister. I bought a Team Voodoo knob from Joe several years ago and had him engrave the Westfield logo on it as well as on an aluminum horn button I supplied. Great work and prices. -John
GunshipDriver Posted April 6, 2014 Author Posted April 6, 2014 Made my own out of aluminum. check out this thread on Ultralite shifters http://www.usa7s.com/vb/showthread.php?t=7023 Perfect resource... thanks!:hurray:
rotus8guy Posted April 6, 2014 Posted April 6, 2014 Found it! Was in a thread here last year. He makes a variety of shapes sizes and colors in delrin. Reasonable prices too. [/url]http://shop.productinnovationsonline.com/
GunshipDriver Posted April 7, 2014 Author Posted April 7, 2014 didn't want to admit it... but tried with all my might twisting it off... no luck. looking just below the knob.. it almost appears splined. Wonder if it is/was hammered on?
jlumba81 Posted April 7, 2014 Posted April 7, 2014 Check if there is a set screw keeping the knob from unscrewing.
WestTexasS2K Posted April 8, 2014 Posted April 8, 2014 Gunship there is a ring on the bottom 1/2-3/4 inch of the shifter. The little ring unscrews and then there are three set screws that hold the shifter handle on. There are no threads on top of the shifter. The stock Honda shifter is about 12" tall and kinda looks like a shifter for a Mac truck in the Ultralite. The stock shifter has a vulcanized rubber bushing upper section that gets removed what you have left is what is used for the shifter. you can have the shaft turned down and threaded or weld the desired bolt thread and pitch to the shifter stud. I have done it both ways for customers it depends on the knob.
