s2k7 Posted May 11, 2014 Posted May 11, 2014 ...of fuel in your tank? ......in the hi-way driving, how many miles do you get in the full tank? I'm sure depending on big is your engine, V8 could be less miles?
locost7018 Posted May 11, 2014 Posted May 11, 2014 8 gallons and about 160 miles the way I drive!!!! 1300cc Xflow Ford. More if I drive like a normal guy. Russ
powderbrake Posted May 11, 2014 Posted May 11, 2014 Ultralite, 2 liter engine, 13 gallons, about 250 to 300 miles, but I never let it get that low, I generally refuel at 200 220 miles.
escondidoron Posted May 11, 2014 Posted May 11, 2014 5 gallons. Don't know exactly how far as I don't have a speedometer. I fill up every couple of hours or so. Probably about 100ish miles? 1340cc Cosworth Ford.
s2k7 Posted May 11, 2014 Author Posted May 11, 2014 wow !!! that's the reason why - i only have 6 gallons. that means I need to peee & look for station every 80 miles. one reason why i don't go cruising and be a burden with the group
xcarguy Posted May 11, 2014 Posted May 11, 2014 wow !!! that's the reason why - i only have 6 gallons. that means I need to peee & look for station every 80 miles. one reason why i don't go cruising and be a burden with the group Seriously? That's the best excuse you have? Everybody is ready for a peee after 80 miles. At the very least, a good stretch and much-needed scratching of the ol' arse. :smilielol5: . . . . . :cheers:
scannon Posted May 11, 2014 Posted May 11, 2014 Assuming I have the standard 44 liter tank like other SVs then that is 11.6 gallons. I have gone a little over 300 miles on a tank on a road trip but usually fill up at 275 to 280 miles. Highway mileage is 30 - 32 mpg depending on cruising speed. Around town it is 24 - 26 mpg depending on how many G-force fixes I give myself. My fuel range far exceeds my bladder range so I stop about every 100 - 150 miles. My back also appreciates the frequent stops to stretch a bit.
Paul Hill Posted May 11, 2014 Posted May 11, 2014 Depends which vehicle we are in.... My '92 Dodge Ramcharger 4 x 4 does about 20 mpg on the highway with the cruise at 65 mph. That leaves looking for fuel around 600 miles....34 gal tank. Our '95 BMW 325 IC is a bit easier on bladder control, about 400 miles with the 18 (I think) gal tank. It won't be fuel necessitating stops once the motorhome is complete.... 125 gal Freightliner tank. Assuming we get close to the predicted 20 mpg with our Cummins motor that's north of 2000 miles between fuel stops. Of course having a bathroom on board for Rosemarie means it will likely be my but cheeks screaming for mercy, even with the air ride seats, or meal stops.
jlumba81 Posted May 11, 2014 Posted May 11, 2014 (edited) Paul, you need a massaging driver seat. Maybe out of a Mercedes or BMW. I usually fill up my 7 around 250 mi since the gauge doesn't read accurate under 1/4 tank. MPG depends on incline, head winds and lead foot. Looks like audi has better massaging seats. Edited May 11, 2014 by jlumba81
AndyB Posted May 12, 2014 Posted May 12, 2014 8 Imperial gallons about 180 miles highway cruising. Less than 100 miles spirited driving before I suffer fuel starvation on right handers. Tall block Lotus Twin Cam (1700cc) Despite these numbers like some of you have mentioned the float on my bladder sometimes moves faster up than the one in the fuel tank moves down necessitating a premature pitstop!
CASwede Posted May 12, 2014 Posted May 12, 2014 (edited) 8 gallons. About 20 per gallon on highway. ZX3 Zetec with the bells and such. Spirited on the road driving, about 13-15 mpg. Edited May 12, 2014 by CASwede
Blokko Posted May 13, 2014 Posted May 13, 2014 My understanding is that my Caterham SV (1.8 Rover K) has a fuel tank of 9.1 imperial gallons (41.4 litres). As I generally get 38mpg when touring that would give me a theoretical range of 345 miles - but not all of the fuel in the tank is usable. I tend to refill at about the 250 mile mark to be on the safe side.
IDreamOfChapman Posted May 14, 2014 Posted May 14, 2014 I have a seven gallon tank in my caterham with a ~210 horsepower zetec. I get around 110 miles driving on back roads, close to 150 on an all-freeway drive.
rnr Posted May 14, 2014 Posted May 14, 2014 7.5 gallons and no fuel gauge means that I stop and fill every 125 miles. Plus having a fuel cell means that there is no sputtering or starvation till it runs completely dry - ask me how I know :-(
rss Posted May 14, 2014 Posted May 14, 2014 Plus having a fuel cell means that there is no sputtering or starvation till it runs completely dry - ask me how I know :-( i experienced that phenomenon myself, only i was quite lucky in that a gas station came into view just as i ran out of fuel. i coasted into the station and only had to push the car about 15 feet to the pump.
