Flyin Miata has two LS3 oil pans made by Moroso (aluminum and steel) for their V8 conversions. They have sumps with trap doors to prevent oil starvation and are a little shallower than the stock ones to give a little more ground clearance. I suspect they would work well on the Stalker V8s without the cost of dry sumping the system as well as save some space.
Many of their V8 conversions are track and race cars and I have not heard of any of them having problems with oil starvation.
http://www.flyinmiata.com/index.php?deptid=5675&parentid=0&stocknumber=26-04115%20%20ALUMINUM
http://www.flyinmiata.com/index.php?deptid=5675&parentid=0&stocknumber=26-04115%20%20STEEL
Thx for this; I've seen the Improved Racing LS pans but not these yet. Research commencing...
  • Replies 46
Posted Images
The Improved Racing pan (LS1 style w/ baffle) is good up to around 1.2G with 6 qts (1/2 qt extra) in the engine. Ask me how I know this. :D
Xcarguy, have you tried the Accusump out on the track?
Not yet. NJMP in July will be the maiden voyage. However, the Lightning course runs CW and only has two left-handers, but we'll see. I went back and reviewed my other videos from the March 22 event at MSR Cresson (1.7ccw course). It's worth mentioning that on one of the videos, the low oil pressure light illuminated briefly in a 'left-hand' turn. :ack: That was a first.
Subtle Z28, have admired your Stalker. Yes it's an XL, will post more pics tomorrow.
[attach]6352[/attach]
[attach]6353[/attach]
Thx for the pictures! Excellent! Can you confirm if it's a T-56 Magnum, or is it a used/rebuilt T-56?
Beautiful!! I saw it in various stages when I had stopped by the Shop, very nice workmanship, Scott has some serious talent. Enjoy that ride!
toedrag,
I'm sure MB7 won't mind my posting this. You ask about the tranny; here is a link to a few shots I took of the car prior to completion. One if the photos shows the Tremec. From what I got from Scott Mineheart (MB7 can confirm) ALL parts used in this build are new:
http://www471.pair.com/stalkerv/gallery2/main.php?g2_itemId=24553
Edited by xcarguy
mote drag,
[/url]http://www471.pair.com/stalkerv/gallery2/main.php?g2_itemId=24553
Thx, xcarguy! I've seen those shots before, but I didn't realize it was this car. That's good news if the Mineharts found a way to put the shifter in the proper place when using T-56 Magnum. You can see from the following picture from your link that the shifter wants to pop up behind the lower part of the dash, but in the completed car, it's where you'd expect it:
http://www471.pair.com/stalkerv/gallery2/main.php?g2_view=core.DownloadItem&g2_itemId=24577&g2_serialNumber=2
http://www.usa7s.net/vb/attachment.php?attachmentid=6352
Very nice,
The low angle of the windshield catches my eye: compared to the birkin which is almost vertical.
Are those RPF01 wheels?
The shot from over the rear wing is so nice!
Interesting that w/the V-8, the Stalker's hood (bonnet?) is much lower-it doesn't have the standard Stalker engine bulge.
I forgot to look at how Scott moved the shifter back when I was there also.
But this is what I did and it works very nicely. There is a very thin silicon lubricated Teflon washer between the moving joint at the shifter stub.
I still had to cut the dash and tilt the bottom bit out slightly to clear the shifter stub.
This set up is somewhat throw adjustable also.
http://www471.pair.com/stalkerv/gallery2/main.php?g2_itemId=17720
Gale
Gale
Thx for posting that! I'm guessing/hoping that the Minehart solution is similar to this since I don't have the skills to fabricate something like this.
It looks so sweet. I saw it at Scott's while it was under construction. I'm so jealous. I couldn't come up with the $48k or so to have him build it (or the $48k or so to buy all the parts and tools to build it myself.) I'm stuck with my $20k used Mustang. Still fun sounding (and not bad skidpad at .9) but nowhere in the ballpark for experience. Congratulations.
I will share that I did not come even close to fitting in this car. I'd have to add two inches of height on that roofline (or more if I'm thinking about a helmet) and I suspect that would totally change the appearance for the worse. Being 6'-2" isn't all bad but not so great when it comes to small cars.
Someday maybe I'll get there . . .
Twerd68,
How about the Stalker XL for a tall guy. :jester:
