Anyone putting one on a Stalker or other car that does not come with one standard?
I don't really want to add the weight, extra work, or buy more parts, but I do always use it when I park my cars (I typically drive manuals).
Opinions?
If you're planing to register it make sure your state inspection doesn't require one.
Check your state's inspection req't to see if the parking brake is required, and secondly if it must be separate from the main braking system. Of course, it's anyone's guess if the inspection technician would notice/ask if the parking brake was separate...
Did some research on this one, but never really made a decision
Some spot calipers:
Wilwood: http://www.summitracing.com/search/product-line/wilwood-billet-spot-calipers
IPSCO: http://www.ipsco.org/Custom%20Services/Parking%20Brake.htm
The alternative to a mechanical one is a hydraulic line lock, like Park Lok: http://www.speedwaymotors.com/Park-Lok-Hydraulic-Brake,1970.html (This is what Scott had recommended to me)
Here's a few pictures from a Stalker owner with the Wilwood one mounted: parking brake-mechanical spot brake for parking brake. It is a Wilwood mechanical spot caliper.
set-72157631686359649
Opinions?
Mine is a simple 1500 psi inline ball valve from McMaster Carr that's plumbed in with the rear brakes:
http://www471.pair.com/stalkerv/gallery2/main.php?g2_itemId=10560
http://www.mcmaster.com/#ball-valves/=tg8hpx Part #4114T21
Part #4114T21
Be careful with that. If warms up after closing the valve, the pressure could go well above 1500 psi and crack a caliper. I would plumb a small pressure relief valve across the ball valve to prevent this.
Someday over a beer I'll tell the story about how I learned that a Chevy Chevette caliper cracks at this pressure.
Some spot calipers:
had the wilwood ebrake on my car. was a rattely pos. it also barely kept the car from rolling.
I'm glad u brought this up Jevs. My older style M-spec has the miata rear brakes. The calipers have integral park brake. Problem is where they are positioned, there is not way to actuate them or run the cables...
I need to look into an alternative. I would like to have one for street duty, and have a feeling the DOT inspection will require them.
My Westfield uses the brakes from the Miata donor. Simple and easy installation and they work well. To make the cables work, you swap the uprights and calipers left-to-right. This makes the cables come into the calipers from the rear and the cable length is correct. You do not invert the calipers, so the bleeds remain on the top.
Doesn't really rattle on mine but you are correct that it doesn't do a whole heck of a lot. It will stop the car from rolling if I lean on it, but if I park it on any sort of hill, it get put into gear also.
Dan,
I put quite a bit more repetitive (and agressive) pressure on the brake pedal when on track than I ever do when I set the pressure to hold the car in place. Typical brake pressures for an automobile can range anywhere from 800 psi for normal, day-to-day driving to up to 2000psi for maximum application. At NJMP, coming off the straight at Lightning and into turn one, I'm applying maximum brake pressure (right at the edge of skidding the slicks on a 1900lb car) from around 140mph down to around 85mph. At MSR Cresson on the 1.7ccw course (longest straight), I'll max brake from around 130 down to 70. The valve, rated to 1,500 psi @ 70° F, has been on the car for seven years and has performed as expected with no issues. With most of the brake bias on the front, I don't know if the rear brakes have ever even seen 1500 psi. And I still want to hear your story, preferably with something cold in hand. :cheers:
Edited by xcarguy
I have also used Wilwood parking brakes. At least from my experience I would say...Don't waste your time or money they are virtually worthless. Looking for a better way.
Gale
They are better than Wally World plastic chocks.....you don't have to have some one pull em for you and jump in
Dan,
The valve, rated to 1,500 psi @ 70° F, has been on the car for seven years and has performed as expected with no issues. :cheers:
Industrial hardware like this is typically good for 4X the rating, so that valve probably works to 6000. My concern is for the caliper, not the valve. Of course, if there's any air in the system, that will alleviate the thermal expansion problem.
The rear calipers (Gran Am GT) have been on the car for seven years as well, and no issues. Whether needed or not, the brakes are thoroughly bleed prior to every track event; this ensures they are air-free.
Edited by xcarguy
