Everything posted by JohnCh
Good idea, but everything is clean on the other side of the throttle plates. #2 also has the problem, but not to the same degree. I suspect that it's a combination of TB wear and dirty/failing injectors. Although the engine only has about 33k miles, it's been in the car for 15 years. I plan to speak with Pete at Raceline in the morning to discuss. Thanks, John
It's the same runner in the head and the TB. Here is better photo of that port and back of the valves. As you can see, it's very clean, just like the rest of the head. Although it looks like oil in the seal area, it's present to varying degrees on all of them, and it's a tacky consistency with a fuel odor. Given there is no way for oil to get there except through the valves or from a outside leak, my guess is it's a mixture of fuel and carbon giving it the color of oil. The Raceline/Jenvey DTHB are fed through a Pipercross sausage filter with nothing venting into that system. http://www.usa7s.net/vb/attachment.php?attachmentid=15884&stc=1 http://www.usa7s.net/vb/attachment.php?attachmentid=15885&stc=1 Thanks, John
Nope. I'm wondering if I'm getting some wear in the spindle assemble for that TB? I need to call Raceline next week about some related items, so I'll ask them if they've seen this before. As for the 2.5L, you have a PM and you now have me rethinking the head decision Thanks, John
The plot thickens. Yesterday afternoon I warmed up the car and redid the test. I set #1 to TDC then confirmed it was correct with a dial indicator. Leak down was 10%. Hmm... Did again, with the same result, then checked the other cylinders using the dial indicator to confirm TDC. Those numbers were all the same as the last test. I suppose something was stopping a valve in #1 from fully seating and a short drive knocked it out. With that done, I started prepping the engine for removal, ending up with this Saturday morning. And then I found another head scratcher. http://www.usa7s.net/vb/attachment.php?attachmentid=15857&stc=1 Removing the Raceline/Jenvey DTHTBs revealed another "what the?" moment. The rear set looked fine, with a bronze cast of dried fuel running from the back of the throttle plates to rear of the tract. The front TB, however, was filled with shiny black crud that looks like a combination of fuel and carbon. #1 is the worst, yet the ports and back of the valves are very clean. Any idea what would cause this? I'm not running breathers into the filtration system so it's not oil. Pics below show #1 and #4 TBs for comparison purposes, and #1 intake ports. Tough to photograph, but outside of the very front, the intake ports and back of the valves look very, very clean. http://www.usa7s.net/vb/attachment.php?attachmentid=15858&stc=1 http://www.usa7s.net/vb/attachment.php?attachmentid=15859&stc=1 http://www.usa7s.net/vb/attachment.php?attachmentid=15860&stc=1 Thanks, John
JohnCh replied to slngsht's topic in General Sevens Discussion
Good to see a new member from the PNW! Agree with Bruce on your choice in cars and the request for photos -John -
Glen, really great write up that captures the spirit and fun of doing a group tour. The only downside to reading it is that I'm now compelled to read the fist 70 pages of your thread. I guess I know how I'm spending the weekend... -John
Of course I can't handle all that horsepower. That's part of what makes it fun. As for the Elan, it runs just fine, thank you. Unlike your 400i.... BTW I forgot to address your comments regarding oil filler proximity to #1. I was too distracted trying to figure out how a corporate finance guy could subtract 27,894 from 32,853 and come up with just 4,000. But I digress. It's a fair point and the breather is back by #4. I'll take a closer listen to the various leak points when I redo the test later this week. Thanks, John
Yeah, I know. Life has gotten in the way of long tours to nowhere over the last few years No signs of head gasket or other issues. I went with TDC and did that test twice on a couple of cylinders including #1. That involved rotating the engine a full revolution between tests to reset the TDC point. I can't confirm that it was perfect, but I doubt I got it wrong in just the same way twice on that one cylinder. The difference between those tests was less than 1%. Someone else suggested repeating at BDC to see if it's an issue at the top of the bore. I'll try that when I re-run the test over the next couple of days before draining engine and trans oil in prep for the engine removal. If I do the upgrades I'm contemplating this is all moot as the pistons, head, and head gasket will all change, thereby renewing/replacing all the failure points. But I'm still riding that fence. Thanks, John
I could use some help interpreting compression and leak down tests on my 2.0L Duratec. Compression remains high and within 10psi across the board, but #1 now has very high leak down. No audible noise from the exhaust, and the sound from the intake didn't seem louder than the other cylinders, however, the whooshing sound from the oil filler was much louder. To me that means rings, but if it's rings, then why is the dry compression fine in that cylinder? Below are the results of tests taken about every 6k miles. As you can see compression numbers have remained pretty consistent, but #1 has always been the leak down outlier and has gotten much worse over the past 6k miles. Any ideas? I need to pull the engine to deal with a faulty oil pressure relief valve, and am contemplating a refresh and possibly upgrades as long as I'm in there, so don’t want to miss addressing an issue while it’s easier to tackle. [TABLE] [TR] [TD] Date[/TD] [TD]4/28/12[/TD] [TD]10/19/14[/TD] [TD]8/27/19[/TD] [TD][/TD] [/TR] [TR] [TD] Miles[/TD] [TD]22,146[/TD] [TD]27,894[/TD] [TD]32,853[/TD] [TD][/TD] [/TR] [TR] [TD]1[/TD] [TD]205 psi[/TD] [TD]190[/TD] [TD]210[/TD] [TD]Compression[/TD] [/TR] [TR] [TD]2[/TD] [TD]205 psi[/TD] [TD]198[/TD] [TD]210[/TD] [/TR] [TR] [TD]3[/TD] [TD]215 psi[/TD] [TD]195[/TD] [TD]200[/TD] [/TR] [TR] [TD]4[/TD] [TD]215 psi[/TD] [TD]201[/TD] [TD]210[/TD] [/TR] [TR] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [TD][/TD] [/TR] [TR] [TD]1[/TD] [TD]10%[/TD] [TD]13%[/TD] [TD]23%[/TD] [TD]Leak Down[/TD] [/TR] [TR] [TD]2[/TD] [TD]7%[/TD] [TD]8%[/TD] [TD]10%[/TD] [/TR] [TR] [TD]3[/TD] [TD]7%[/TD] [TD]11%[/TD] [TD]10%[/TD] [/TR] [TR] [TD]4[/TD] [TD]7%[/TD] [TD]9%[/TD] [TD]9%[/TD] [/TR] [/TABLE] Thanks, John
Here you go: http://www.usa7s.net/vb/attachment.php?attachmentid=15829&stc=1 http://www.usa7s.net/vb/attachment.php?attachmentid=15830&stc=1 -John
JohnCh replied to Croc's topic in Cars For Sale
The windshield is installed incorrectly and too upright. The base of the mount should be parallel with the join line of the scuttle and tub. And yes, that certainly looks like Derek Bell. I seem to recall he is involved with a car dealership in Florida where that car is located. -John -
That's outdated information. Many of the communists in power have been replaced by conflicted anarchists. Agree about the microbreweries though. Also a good foodie town. If you like books, make sure to visit Powell's which bills itself as the world's largest independent bookstore -- it's enormous! -John
If you decide to stick with traditional lighting, Daniel Stern is a great resource. I have the Cibie lenses couple with Navra +50 bulbs and have no complaints about the lighting; sharp cutoff and very good output. -John
Just remember to drain the transmission first or you will have an oil slick under the car once the driveshaft separates. -John
Al, glad to hear that good old fashioned guilt is still an effective motivator Any recent pictures of the car? -John
What's up with the porn onslaught on the site?
JohnCh replied to Kitcat's topic in General Sevens Discussion
Thanks, but Mazda installed Spam-O-Matic a couple of years ago when we another big influx of spammers. As long as Croc posted the link to the other thread, and I have people's attention given the use of the word "porn" in this thread, I have a favor. I made a minor tweak yesterday to solve the issue of massive thumbnails when attaching images, and although it works perfectly for me, it's not for Shane. Only the thumbnail posts, not the inline image. Would folks mind going to that thread and seeing if it works correctly for them? http://www.usa7s.net/vb/showthread.php?12426-Testing-thumbnail-changes Thanks, John -
I just banned over 40 more and discovered it stops being fun after 10 in a row... Time for a beer. A really big beer. -John -
The daily total is now 42 threads and 6 users. Hopefully the minor tweaks I just implemented will slow things down a bit. -John -
Ah, so that explains your recent request to become an admin! Not sure why we are suddenly getting hit so hard. So far today I've deleted 33 threads and banned 5 users -- not that I'm complaining about the banning part. That's kind of fun! I'll see if Mazda has any ideas or if the previously installed anti-spam solution has an issue. -John -
You only need to mention a Westfield to get him on a roll :jester: -John -
Wow! That is a very interesting sales technique. -John -
I can't remember if this was mentioned before; is it possible the TPS has rotated slightly on the mounting screws and is no longer calibrated correctly? If so that would cause the map to effectively shift and supply the wrong fuel and timing for a given throttle opening. If you have the software connecting to the Pectel, it should be easy to check. -John
Right, but if Bob sold the se7en, then he would simply be a guy who talks to a stuffed duck and Pee Wee Herman, which would NOT be a particularly right blend of crazy. As always, a se7en makes all the difference. -John
Glad to see you came to your senses! -John
Caterham A Frames - check them as part of your annual maintenance
JohnCh replied to Croc's topic in General Tech
It's a little disturbing that the Bookatrack mechanics call it relatively common. Are you considering having a replacement made from thicker material? -John
