Everything posted by JohnCh
Al, glad to hear that good old fashioned guilt is still an effective motivator Any recent pictures of the car? -John
What's up with the porn onslaught on the site?
JohnCh replied to Kitcat's topic in General Sevens Discussion
Thanks, but Mazda installed Spam-O-Matic a couple of years ago when we another big influx of spammers. As long as Croc posted the link to the other thread, and I have people's attention given the use of the word "porn" in this thread, I have a favor. I made a minor tweak yesterday to solve the issue of massive thumbnails when attaching images, and although it works perfectly for me, it's not for Shane. Only the thumbnail posts, not the inline image. Would folks mind going to that thread and seeing if it works correctly for them? http://www.usa7s.net/vb/showthread.php?12426-Testing-thumbnail-changes Thanks, John -
I just banned over 40 more and discovered it stops being fun after 10 in a row... Time for a beer. A really big beer. -John -
The daily total is now 42 threads and 6 users. Hopefully the minor tweaks I just implemented will slow things down a bit. -John -
Ah, so that explains your recent request to become an admin! Not sure why we are suddenly getting hit so hard. So far today I've deleted 33 threads and banned 5 users -- not that I'm complaining about the banning part. That's kind of fun! I'll see if Mazda has any ideas or if the previously installed anti-spam solution has an issue. -John -
JohnCh replied to Croc's topic in Cars For Sale
You only need to mention a Westfield to get him on a roll :jester: -John -
Wow! That is a very interesting sales technique. -John -
I can't remember if this was mentioned before; is it possible the TPS has rotated slightly on the mounting screws and is no longer calibrated correctly? If so that would cause the map to effectively shift and supply the wrong fuel and timing for a given throttle opening. If you have the software connecting to the Pectel, it should be easy to check. -John
Right, but if Bob sold the se7en, then he would simply be a guy who talks to a stuffed duck and Pee Wee Herman, which would NOT be a particularly right blend of crazy. As always, a se7en makes all the difference. -John
Glad to see you came to your senses! -John
Caterham A Frames - check them as part of your annual maintenance
JohnCh replied to Croc's topic in General Tech
It's a little disturbing that the Bookatrack mechanics call it relatively common. Are you considering having a replacement made from thicker material? -John -
Are you sure it's metric and not standard? 9/16" is pretty close to 14mm. Definitely pick up a thread gauge as that will give you the definitive answer. -John
Toyo states that 6" is the preferred wheel width for the 205/60-13 R888 and RA1. I checked with them before buying my wheels back in 2012 and they confirmed this recommendation. Given they do recommend wider wheels for 205/50 and wider still for 205/45, there is likely something about the 60 profile that works better with the narrower rim. Having run both tires, I prefer the RA1 to the R888 for road use. The RA1 has a 10% softer sidewall -- better for a very light car like a se7en -- and I found it more forgiving when pushed. That's not to say the R888 isn't a forgiving tire, but on my car the RA1 feels more playful in the corners, and hence, more fun. I can't comment on lap times differences since my car is used exclusively on the street and back roads. I also don't have experience with either tire in standing water, but it's probably worth a call to Toyo to ask. They've always been very helpful to me in the past and likely have a quantitative view on this aspect of the tires. -John
I have a 2.0L Duratec with Kent DTEC10 cams, some head work, and Jenveys. It's mapped correctly and fires up just like my real cars. -John
In addition to what has been mentioned above, I'd confirm that the fuel pressure regulator is doing it's job. If current fuel pressure is much higher than what what was used to create the map, your mpg (and power) will drop. -John
Are you sure the O2 is narrow band? The Pectel is pretty sophisticated so i'd be surprised if it doesn't use a wide band and have an interface that shows live AFR, or better yet, log it. -John
Looks like the builder took inspiration from the Caterham Levante when selecting mirrors and headlights. -John -
A single pic won't cut it. I suspect there are enough of us interested in the car that it warrants a thread of it's own! -John -
need to source a few things, and some other questions..
JohnCh replied to Jaeggernaut's topic in General Sevens Discussion
For mirrors, see this thread. Several options including what's been mentioned here. The bonnet is a little tricky. If it has to come from the UK on it's own (i.e. not bundled in a container with some kits) shipping costs won't be cheap due to the size. I'd check with Rocky Mountain Caterham and Beachman Racing to see if either have any spares in stock or incoming shipments to which they can add it. As per xcarguy, also check local fabricators. The cost may be much higher than a new bonnet, but it might net out when shipping costs are added to the total. Perhaps the bonnet isn't so far gone that it's more cost effective to have them fix and refinish it? In addition to engine and trans information, what clutch master is installed (brand and part number)? If it's the stock part, the clutch shouldn't be overly light, but you never know what changes have been made by prior owners. Also, when was the transmission fluid last changed and do you know what's in it? That can also play a factor in shifting smoothness. Thanks, John -
I am using a Raceline supplied AP Racing HD clutch and pressure plate on my Duratec. No complaints. -John
JohnCh replied to slngsht's topic in General Sevens Discussion
Welcome and sorry to hear the dealers haven't met your expectations. Not sure what brand you're looking for, but if you are considering a Westfield, contact the US distributor directly. Tom is a good guy and very helpful. if you are looking for a Caterham, Bruce Beachman of Beachman Racing has a very good reputation on the forum, and as per this recent thread, the guys at Rocky Mountain Caterham are back in business. A lot of people on the forum have had very good experiences with them when buying their cars. I've also had positive experiences sourcing parts from them, even though I have a Westfield. Over the years some Caterham dealers have been a little uppity with me regarding Westfield ownership, so they score extra points in my book. If you are looking for something else, it might be worth posting the desired brand(s) to get other recommendations. -John -
"again" would imply that I stopped being in trouble at some point. And no, nothing new since the Elan...but there were a few upgrades -John
No need to for an admin to do this. Feel free to create the thread in Member Rides. There isn't much frequent new content there (only 5 posts in the past 5 months) so no need to make it a sticky, but happy to revisit that if things change and traffic drives it down the page. Before Croc jumps in and corrects your error, I'll simply admit that I'm not worthy of anyone's respect :jester: -John
I spoke with Mazda about your request and we're fine with a dedicated thread in the Member Rides section. One request though; please remember this site was intentionally created as a brand agnostic forum to celebrate cars inspired by the Lotus 7, and we don't want to undermine that brief. If you do things like plan events as mentioned earlier, please keep that off the forum unless they are open to non-Caterham owners. Feel free to PM me if you have any questions. Thanks, John
It happened just north of San Francisco on the way back from USA2005. I hit the carcass with the left front, it then shot up along the tub (look closely and you can the rubber marks), hit the polycarbonate wind deflector, then down to the rear wing. Without the deflector, or if that was just made from plexiglass, it would have been a head or shoulder hit at over 70mph. i.e. it wouldn't have ended well... -John
