Everything posted by JohnCh
More like an invitation to get in line
I'm a crappy organizer, but a terrific thread starter In other words, throw out ideas for things to do either now or post Winter. -John
This site was created to celebrate and connect owners of cars inspired by the Lotus 7. If someone has a problem with a Locost in the community, they shouldn't be here When I bought my Westfield, I didn't think I would ever want to drive it on the freeway, but after driving over 750 miles of major interstates the first day to get close to home, I decided it wasn't that big of a deal. -John
Rather than further derail this thread, I started a new one here to gauge interest on a Seattle-area event or tour. -John
Following up on comments in another thread, any Seattle-area (or beyond) owners interested in getting together before the weather turns, or perhaps planning a tour for next summer? If so, please pile on and share your interests and location. I'm on the eastside in Duvall. -John
We weren't spared the snow this year. 10" of wet, heavy snow in one day with 7 trees downed on our property. It seemed appropriate to mention that here given the number BTW a little bit more on topic; although I've tried to organize get togethers and tours in the past with very little interest, perhaps we are getting the number of se7ens in the area up enough that could actually do something? -John
When I connected with him a couple of weeks ago he characterized things as going slowly; good to hear he is making progress. Hopefully the car will be completed before we enter the Wet Hell season. -John
I've lived and worked on the Eastside for a long time and have never seen any make of se7en on the street, let alone twice in a week. With that kind of luck you may want to consider playing PowerBall Have you checked with Bruce Beachman? He may know the car. BTW there is a new Caterham (believe it's a 420S) under construction in Carnation. No idea when it will be completed. -John
Those look like the air bypass screws. They are used to balance flow between barrels on the same carb and to adjust the location of the throttle plate to the progression holes at idle. -John
Glad to hear things worked out and we're not losing another se7en in the area! -John
Thanks Bob. I hope to get out again in late August. Depending on weather, this time I might try the Olympic Peninsula. I've heard there are great roads out that way, but it is a rain forest, so timing is everything. -John
Earlier this week, I did a brief solo tour in WA that included Mt. St. Helens, Mt. Rainier, and the North Cascades Highway. The short version is I had a great time, with little traffic and no conversations with state revenue collectors. For the truly bored, the longer version, including more photos and a recap of my interesting experience with foreign tourists, is here. http://www.usa7s.net/vb/attachment.php?attachmentid=12830&stc=1 -John
Caterham S3, SV, CSR size comparison
JohnCh replied to benhughlett's topic in General Sevens Discussion
Yep, same picture Skip. Picture was there for me earlier, but I don't see it now either. I should point this out to an admin... -John -
Here is an overhead shot that compares the S3 to SV. http://www.usa7s.net/vb/attachment.php?attachmentid=12754&stc=1 -John -
2004 Caterham SV with Turbocharged Miata Engine For Sale
JohnCh replied to scannon's topic in Cars For Sale
I still remember Skip's initial posts elsewhere regarding his "heretical" idea of installing a Miata drivetrain in a Caterham. Given the required surgery to fit the gearbox within the tight confines of the frame, some people (mostly respectfully as I recall) thought he was...well, nuts. However, the output from that marriage showed Skip's internal wiring harness was not hemorrhaging Lucas smoke, and resulted in a very unique and desirable car. Sad to see it go, but hope Skip does continue to stick around. -John -
JohnCh replied to slngsht's topic in General Sevens Discussion
Dave, are you looking for a vintage ride, or back road blaster that sticks to the lightweight ethos of the original Seven? If you want vintage, then look at an early Caterham, Pre-Lit Westfield, or Lotus. Big budget spread between the three, but they'll give you that experience. Move to more modern variants and the things do begin to change. Engines go from 2 valve to 4 valve, carbs and points to programmable engine management systems, options of roomier cockpits, IRS, alloy 4-pot calipers, and leather or carbon fiber seats. You can't go wrong with either style, but the driving experience is a little different. As for replicas; if you are a purist, buy a Lotus. Semi-purist, Caterham or Birkin. Just want something fun that follows the Seven ethos, then things open up. Most of these cars aren't replicas per se, but rather interpretations of Chapman's concept. Some stray from that a little further than others, but they all have merit. The thing is to find the one that best meets your criteria. -John -
Given this began after a hard jolt, I'd check for loose electrical, pinched wires, or crank position sensor. Do you hear the fuel pump when you turn the key? If not, check the fuse and then the wiring. Next, check the fuse for the ECU to make sure no issues there. Also check any connectors in the engine loom to make sure they are still tight. It's also possible that the crank sensor wasn't fully tightened so it moved a bit when you hit the hole. Not sure how to check that if you don't have the plastic alignment tool included with a replacement sensor, but others might know. -John
Like Gert, I've had my Emerald for ~12 years, and have upgraded to later firmware. It's very user friendly, lot's of support from both the company and various UK se7en forums, and reasonably priced. They do make harnesses and can modify them to suit your needs. After developing some issues in the harness I built during the initial install in 2004, I bought a replacement from them this summer and had them prep it for some future mods I have planned. It's very well made. -John
According to this video posted by Edd China, he is leaving Wheeler Dealers due to changes implemented by the show's new owner (Velocity Channel bought it prior to last season.) Sad to see the specific reason below, as I viewed the segments with Mike Brewer as the tax to see the interesting bits with Edd, not the other way around: "Unfortunately, on Velocity’s first attempt at producing the show they found Wheeler Dealers ‘too difficult to make’, ‘at least in its current format’. In particular, the detailed and in depth coverage of my fixes in the workshop; what I consider to be the backbone and USP of the programme, are something Velocity feel should be reduced. The workshop jobs are certainly the hardest part of the show to make and reducing their substance and role in the show will save the production considerable time, effort and therefore money. However, this new direction is not something I am comfortable with as I feel the corners I was being asked to cut compromised the quality of my work and would erode my integrity as well as that of the show, so I have come to the conclusion that my only option is to let Velocity get on with it, without me." -John
Having Fun..in WV...Best roads for a Seven...480.
JohnCh replied to mknelsonmd's topic in General Sevens Discussion
I don't recall seeing Pearl before -- looks fantastic! Of course that appreciation is tempered by my frustration from seeing photos of a se7en under blue skies. -John (in Seattle, where we've had our wettest winter on record...) -
I don't recall seeing such a tall bonnet bulge on other S4s. Special engine, perhaps? -John
Newbie Already Needing Parts & Repairs
JohnCh replied to AveryCloseCall's topic in General Sevens Discussion
Regarding the steering column's contact with the exhaust manifold, have you checked the engine mounts? One might be collapsed or broken. -John -
Have you changed your wheels since I saw the car? If not, then I'm pretty sure those are manufactured for Caterham by KN Wheels in the UK. A quick search on BlatChat should confirm and a call or email to KN might get you a definitive answer. -John
Based on what I've read, this is one of those "it depends" scenarios. Lots of people powder coat their wheels with no issues, but I have occasionally heard of wheels that have subsequently broken. I even know of one wheel vendor whose warranty explicitly denies coverage to problems arising from powder coating. The crux of the issue seems to be the age hardening process. Depending on the alloy, that is done at a temps near or below those used for powder coating, over a multi-hour period. If the cumulative aging time for the wheel with powder coating is over the accepted range, then the tensile strength will be lower. If it is still within the target time range, then there is no negative affect. For example, 356-T6, which is often used for cast wheels, is aged at 305F-315F for 2-5 hours. In this example, if the original age hardening was done close to the 5 hour mark, powder coating could tip it over the edge for the application. If it was only done for 2 hours, then it would be fine. To be safe, I'd contact the wheel manufacturer and ask their opinion. -John
I'm not sure why you are trying to draw attention to the driver of the hot rod. I'm familiar with him, and that guy is a snake... Oh, and second the kudos on your photos. -John
