JohnCh
Administrators
Everything posted by JohnCh
  1. No turbo. It's a Euro 2.0L Duratec with Kent DTEC10 cams, a tiny bit of head work, Jenvey DTHTBs, lightweight flywheel, 4-2-1 header, Raceco silencer, etc. Wouldn't clogged injectors and/or filter impact running at larger throttle openings/higher rpms where there is a bigger demand for fuel flow? My car runs fine in those situations and at idle, it's just the inbetween that's problematic. Also, there was no change to the running in either closed loop or open loop mode. It really feels like TPS is bad -- but that's been replaced -- or the ECU is applying a correction in those situations. Hopefully more logging will add clarity. Thanks, John
  2. It certainly drives like a lean condition: roughness and small backfires as the unburnt mixture hits the hot exhaust system. The wideband O2 that feeds the ECU also shows things are lean. Preliminary logging showed around 13:1 at idle trending to 18:1 (where the WBO2's data logging range tops out) at part throttle and returning to 13-14:1 at heavier throttle. I suppose spark could also be the culprit. If the logging shows no timing or injection corrections when the problem occurs, and the fuel pressure regulator checks out, I might swap out the coil pack. -John
  3. That was my initial guess given how this started, but as indicated above, both the air and water temp sensors appear to be working correctly based on data logging (i.e. steady and showing temps that sound reasonable.) Karl at Emerald gave me a few specific channels to log to help trouble shoot. They should show if anything in the ECU chain, including battery voltage and sensors are acting up and causing the fuel injectors to turn down output, or if the problem lies elsewhere in the fueling system. Occam's Razor never seems to be correct when I'm troubleshooting, so I'm assuming this is a case of MADB (Murphy's Awkward Dull Blade: the most convoluted explanation is correct). Thanks, John
  4. I pulled the O2 sensor out of the loop when switching to open loop mode, so even if that's bad, it wouldn't affect how the engine runs, and there is no MAF (Direct to Head Throttle Bodies with a Throttle Position Sensor). I just heard back from Emerald and Karl suggested I also log the battery voltage and injection corrections to see if those are okay, as voltage issues can impact injector pulse width. He suspects that the issue could also be a faulty fuel pump or fuel pressure regulator. The latter is pretty easy to check, so I'll add that to the list when I log the items above. Thanks, John
  5. I need some help diagnosing a sporadic issue with my 2.0L Duratec running an Emerald ECU. The engine runs very lean at light throttle above idle, but is normal at idle and above 1/2 throttle. The issue presented itself after letting the car sit in a parking lot for 15 minutes after 20 miles of driving on a hot day. I initially suspected a heat soak related issue, but when starting the car up the next morning with temps in the mid 50's, the problem was still there. I drove the car for several days in an attempt to get a better handle on the issue, and it miraculously fixed itself. However, after repeating the initial circumstances (~20 miles on a hot day and then letting it sit in the same parking lot for 15 minutes) the problem reappeared. A new TPS did not fix the problem. Temp gun shows similar temps on each primary pipe, and after increasing idle speed to about 2300rpm where the lean condition is very obvious, pulling plug wires in turn had similar results for each cylinder. I haven't done a leak down or compression test yet, but it doesn't seem like I have a bad cylinder. I've also confirmed that the air and water temp sensors that feed the ECU are operating correctly, and have turned off closed loop running, and fuel cutoff on the overrun to no effect. Any ideas? Thanks, John
  6. Shhh! And please don't tell anyone about my front turn signals either. http://www.throttle-steer.com/uploads/1/1/0/8/11083275/9036596_orig.jpg -John
  7. No reason to hide. You are absolutely right about Seattle. It rains constantly here. In fact the only time I ever see the sun is when travelling on business. As proof, here is a photo taken earlier this morning after returning from a rain-soaked blat. That green stuff in the foreground that looks like grass? Mutant strain of moss. The highlights that look like the sun streaking through the incredibly dense, green, and oh so wet foliage? Simply areas where the acid rain has washed out the natural colors of the landscape. Whatever you do Croc, don't...move...to...Seattle. It sucks. Really. :jester: http://www.throttle-steer.com/uploads/1/1/0/8/11083275/5440785_orig.jpg -John
  8. I've run both, and for street use, prefer the RA1. Although the R888 feels slightly grippier, the RA1 feels a little more lively; a little more engaging. According to Toyo the sidewall is 10% softer, which may be what I'm feeling (our cars need all the help they can get in that area) but regardless, the difference is noticeable to me. That said, if Toyo discontinued the RA1 tomorrow, I'd be happy to run the R888 again. They are both great tires. -John
  9. And you'd also know you're still single -John
  10. JohnCh
    Well . . . .
    I didn't realize my telekinetic powers were so strong. Let that serve as a lessen to the rest of you who dare to jinx the site :jester: -John
  11. JohnCh
    Well . . . .
    Good point. Damn attorneys* are always trying to create loopholes. -John *this seemingly disparaging comment about attorneys is made in jest and does not represent the poster or the website's actual opinion on this noble group of professionals. i.e. no need to sue anybody.
  12. JohnCh
    Well . . . .
    Actually it was coffee break who jinxed us in post #51 above. His posting privileges are currently under review as a result, although his attorney has proposed a voluntary cylinder deactivation in his crossflow for 2 weeks to serve as an example to others. Not sure where this one will end up... -John
  13. JohnCh
    Well . . . .
    Well, if you suddenly find yourself without posting privileges...you'll know why :jester: -John
  14. I've had standard A-arms and Cat Motorsport wide track, which I believe is a little narrower than the Westfield item, but still allows full lock. The difference in turning radius is significant. Agree about the sale price. Those also have the camber adjusters which is a nice feature. -John
  15. Anyone remember the Berzerkeley, Grassroots Motorsports' project Berkeley powered by a 140hp GSX-R engine? http://grassrootsmotorsports.com/media/img/projectcars/DSC_1827.jpg -John
  16. I need a higher res version of that photo for my garage wall -John
  17. I'm not sure that scenario is possible. As you can see in this photo of my car in front of a full size pickup, very little of it reaches as high as the grill :jester: http://www.throttle-steer.com/uploads/1/1/0/8/11083275/5000557_orig.jpg Sean, I attended that show in Pacific Grove 2 years ago. Had a great time and strongly recommend it to anyone attending Monterey car week. -John
  18. Thanks for posting the photos. I can't believe I live near Seattle and have never heard of this event until your earlier post. It's now on my calendar for next summer. Thanks, John
  19. JohnCh
    Well . . . .
    I think I may have pulled a muscle in my finger banning all those guys... -John
  20. Congratulations Dan! And of course now that the build is done, you can begin your journey down the slippery slope of modifications -John
  21. :confused: But I thought all someone had to do to blast by you on track was to wait for you to perform your famous impression of a farmer plowing his field?? :jester: -John
  22. It's great to see that the car has effectively stayed in the family! :cheers: What are your plans for the cars? Are you keeping both and setting up the yellow car for street use, or selling that one and planning some tweaks to make the new car a little more street friendly, or simply taking a wait-and-see approach? As for changing your handle, I think it will be easier to simply paint the new car yellow :jester:
  23. So many possible responses, but I can't think of one that won't put me in the awkward position of having to ban myself. -John
  24. Westfield has sold many thousands of cars over the past 30+ years, and even have (had?) one-marque racings series in two countries, yet very few have made there way here. I think part is down to the distribution model in the early-mid '90's when they had a good opportunity to help shape the market in the US. The distributor wanted to sell turn key cars, and his quality was...well, let's just say it wasn't up to my standards. Manik has done a great job since taking over several years ago, but sales of any new se7ens in this country have been pretty limited since the recession hit. Also, for some reason, very few of the new buyers seem interested in forum participation. As for the Purple People Eater, it sounds like the car is destined to end up in Minnesota -John
  25. I'll refrain from commenting on the color (but I want to, I reeeally want to). The engine is probably the Cosworth YB which uses the Pinto block topped with a Cosworth twin cam head. Westfield offered a turbo version in the early to mid 90's, called the Zei220, that I believe was essentially the engine from the Sierra Cosworth. The non-turbo version was pretty popular in the day, since it bolted in with factory pieces, and offered a lot of power potential thanks to the head design. The downside was weight. -John
