bball7754
  1. Mike - Mid-Ohio would be great, but the elder son is graduating from college that weekend, so don't think it's an option. Steve
  2. Mike - Let me know what Putnam track day(s) you're considering, and I'll try to join you. I'm doing the MVP weekend April 16-17, assuming that my distributor makes it back from Aldon in England. It finally showed up after a month, but with an outstanding customs charge of 45 pounds. Aldon should have picked it up yesterday, and they will appeal the charge. After a month, I'd pretty much written it off. Have plan B in motion (new Pertronix), but ordered it from Summit Racing (believe it or not) on 3/11, and they still don't have it to ship to me. May need to come up with Plan C. I'm having visions of having a non-functioning Seven the weekend of the trackday, and being the proud owner of 3 distributors the following weekend. Steve
  3. Tom - The cam you have will dictate what your valve clearance should be. This is an old post from Blatchat: A Sprint with a standard cam is .014" inlet, .021" exhaust. A Sprint with an A2 cam is .020" inlet, .022" exhaust and a Supersprint is .022" inlet, .024" exhaust I have the Kent 244 cam, which is also .022 and .024, set cold. The cam will also determine which plug to use, and each plug has it's own defined gap. Steve
  4. Mike - After the third trackday where someone came in and told me how much they enjoyed following me and watching my inside front wheel come off the pavement, I decided I needed to change the suspension setup. I went up on the diameter of my front anti-roll bar, and added a rear bar. Since then, no one has said I'm cornering on 3 wheels. I think our vintage Caterham have extremely soft springs - maybe 150 lbs in the front? I think 200-225 is the "normal" front spring rates for street/track use. Steve
  5. Believe the "standard" setup is to have 10-15mm of rake, with the rear higher. Research on Blatchat indicates that the handling can be somewhat evil without the rake. Steve
  6. Mike - I think one of the advantages of the Avon ACB10 is it's weight - or lack thereof. Pretty sure that with a superlight wheel that the total weight would be under 20 lbs. Maybe someone who has them or used them will be along to confirm or correct. Steve
  7. Mike - Thanks. Have you used them? I need to take the connection apart about once a year - can't tell how well they would support that type of use. Steve
  8. I'm looking for a waterproof single wire connector that won't require that I spend $100 on a crimper. Any suggestions? Thanks. Steve
  9. Mike - What John said. I would say it's a couple thou higher at highway speeds. However, I do feel the difference at track days. The 13" wheels (my "normal" wheels are 14") feel lighter at turn in, and it feels like it accelerates a bit quicker. They actually are Panasport wheels. I purchased them used from a Caterham owner with a deDion car, so I knew they would fit. I think you'd notice quite a bit of difference going from 15" to 13". Steve
  10. Sure. From a trackday at Hallett. Steve
  11. Also run 205 RA-1's on my 13X6 rims. No issues with about 10-12 trackdays on them. Steve
  12. Tom - You can throw me on the list as a possible. I'm hoping to have my trailer by then, which makes St. Louis to NJ less of a crazy trip. I grew up in NJ and most of my family is still there, so that's my other incentive. Steve
  13. The thread on this topic on Blatchat seems to be leaning toward Caterham taking over Zolfe. http://www.zolfe.com/ Jez Coates, Tech Director at Caterham, apparently headed up development of the Zolfe. There appear to be two US dealers. You can also sign up to receive info on the announcement here: http://countdown.caterham.co.uk/ Steve
  14. Dean - If you login there will be a "Pictures and Albums" option under the "Community" heading. I was also puzzled at first - this may be the first use of that option. Steve
  15. I think the Zetec is considered the "easiest" Crossflow replacement. Carbs and exhaust on the same sides as the Xflow, and the bolt pattern on the bell housing matches the Type 9. Steve
  16. Mike - Think you talked with Bill Varnum. He does live close, but he can be tough to get in touch with. Believe his number is unlisted, but I'll see if I can find it. Steve
  17. Russ - I realize this isn't US based or cheap, but though I'd post anyway for general informational purposes. UK source for trigger wheels, etc., including complete kits. http://trigger-wheels.com/store/index.html Steve
  18. No weber expert (see other posts) but you might want to make sure the carb's are in synch first. I'm not sure that adjusting the idle valve will help in the mid-range. Believe the circuit the adjustable idle valve/idle adjustment screw is on should only affect the idle and a bit of the transition into the mid-range circuit. Steve
  19. Mike - Pretty sure it's Caterham specific. Maybe take it off and see if a local parts store has something close that would work? My replacement hoses also haven't held up well. Purchased some silicone hoses from http://www.classicsiliconehoses.com/. Haven't installed them yet, but they look good and match the pattern of my existing hoses. Steve
  20. No exhaust leak, and the venturi screws were in place. Looking more and more like put 'er all back together, and keep my fingers crossed.
  21. They are Weber 40 DCOE's, and agree that switching the linkage would not be fun. Fuel pump is mechanical, and the front carb has plenty of fuel. Wondered about timing (I haven't checked it since this happened), but wouldn't it affect all 4 cylinders in the same way? Front 2 are definitely not running lean.
  22. My Crossflow is not a happy camper these days. Symptoms are that cylinders 3 + 4 are running lean. I get spitback through the carb right up to 6K rpm, ceramics on both plugs are white. Came on more or less suddenly at a trackday. Valve springs seem ok, and all the valves open and close. Compression check on the cylinders was good - they actually were the best of the 4, #1 the worst. I've pulled the carb, but before I did checked to see if they were in synch, and they were. No apparent leaking around the O rings between the carb and manifold, but that's only based on a visual check. Didn't check by spraying starter around the carb while running. Was hoping something would jump out at me when I got the carb off and apart, but everything appears ok. One other possible issue is that the O rings for the Pump Jet covers are disintegrating. Replaced them when I rebuilt the carbs about a year ago, and clearly the O rings provided in the rebuild kit weren't up to the task. But hard to imagine they would allow enough air in, particularly when the carb is on the main circuit. I'm about to the point where I'm just going to put the carb back together (with the old O rings on the Pump Jet cover - yes, I did save the old ones) and hope for a miracle. Any thoughts or suggestions? Thanks Steve
  23. Mike - Not only were you on the "pileups", but weren't they about 10 years old? I had a distinct tire advantage that day. Steve
  24. Mike - I think it was mostly my higher corner exit speed. I'll second the impact of having the carbs in synch, and fresh plugs. Haven't changed my rotor and cap yet, although they are sitting on the shelf. I do think that all the "official" HP numbers for Crossflows are at the flywheel. I have the 244 cam, which should put me in the 150 HP range, but doubt the engine is making that today at the flywheel. I think 135 to 140 is more realistic. From my reading on Blatchat, the Aldon distributors that are "unleaded" also impact HP. They were built with a very conservative amount of total advance, to the point that if you set the right advance at idle (I think about 14 degrees), there isn't enough total advance to get where you need to be at WOT (35 +?). Aldon will recalibrate the distributor to the correct advance - just have to ship it to them, and provide some info about the specifics of your engine. In the end, it's just a number. Sort of like one's age. Steve
