Sabbot - I have the same "bounce" with my timing light, but have it at idle on up. Just have a Lucas Sport coil. Would also like to know the cause. Towbone - It's a stock distributor. Actually bought it from Summit Racing - they had a good price. I emailed Petronix support asking about the advance curve, and they answered with this, which seems like different info than what you've received:
Yep, part noD190509 (side exit, no vacuum advance). Unfortunately, it's still sitting on the workbench. I had a brain cramp when I put it in and didn't connect the low voltage leads. Tried to start it and flooded it. Connected them, and then had a heck of a time getting it to start. Put my borrowed one back in, and it's been too hot to work on it since. If you buy it and get the Flamethrower II coil, it (the coil) won't fit in the ignition coil bracket for the Lucas coil. Ask me how I know. Steve
Twobone - You might want to find out which Aldon model they are selling you. The "unleaded" version is notorious for having a poor advance curve. I sent my Aldon back to them to be recurved. Gave them my basic specs (primarily the cam I have) and they changed the curve. Some searches on Blatchat should give you plenty of info on the issue. Unfortunately, since it's been back I've had other issues with it, but they were still good to work with. Steve
Corner speed and thin aluminum
bball7754 replied to supersportsp's topic in General Sevens Discussion
Did the same thing at an Autocross about 4 years ago. Was in the process of emptying the boot when someone came up and started a conversation. I got distracted, and didn't remove my jack kit. I already had a few dents in that same area, but added a few more. I've come to accept them as providing my Seven more character. Misery loves company? Steve -
The Pertronix was/is my backup. I sent my Aldon to England to have the curve changed, as what I had was known to be poor. The modified Aldon now causes my tach to bounce all over the place. I've replaced the battery, ignition and HT leads (both were due anyway), changed the low voltage connectors, and confirmed the alternator output. None of them fixed the tach issue. Have another Aldon on loan from a UK Caterham owner who has a spare. With that distributor installed, I have no tach problems. The Pertronix was purchased as an alternate when I thought that my distributor was lost in transit to the UK. See, I told you it was a saga. So, I have a distributor with, theoretically, the correct advance curve for my engine and specs. But don't have a working tach with it installed. And have a Pertronix that let's the tach work, but not sure about the advance curve. Am I having fun, or what?
Ian - Doesn't it really open up an additional 20 degrees between 1000 and 4000? It's at 5 degrees at 1000, and 25 at 4000, which seems like an additional 20 degrees. I had asked for the static advance, but all they gave me was a chart with the advance starting at 5 degrees at 1000 rpm. Is it really possible that the static advance is less than 5 degrees, and that the advance has actually opened up X degrees by 1000 rpm? Steve
Mike - To be honest, the open passing with 10/10ths has made me reluctant to do a track day with them. I've put together a track weekend. Saturday, 8/6 I'm at Putnam Park with 100 Speed. I've run with them several times, and each time the afternoon has just been open track with no sessions. Serious amount of track time. I'll stay over in Indiana Sat. night, then drive up to Joliet, IL Sunday for a trackday at Autobahn on Monday, 8/8 with MVP Tracktime. Steve
I’ve had a distributor issue with my Crossflow for… well, too long. I won’t bore everyone with the full saga, but I’m at a point where I’m ready to replace my Aldon Ignitor with a Pertronix Ignitor II. According to Pertronix tech support, the curve on the distributor is 5 degrees at 1000 rpm to 25 degrees at 4000 rpm. My Crossflow needs 12-14 at idle, which is more like 1200 rpm. Ignoring whether the actual curve suits the cam/carbs, etc., I thought I’d be ok. I thought that moving the idle advance up by, say, 7-9 degrees to 12-14, would result in the total advance being increased by 7-9. So max would be 7-9 plus 25, or 32-34, which is about right (I think 34 is preferred). Pertronix tech support said, no, if I set the idle to 14 the total advance would be 14 plus the 25 per the original curve spec for a total of 39. Which is too much. Is he right? Thanks. Steve
Set with it just touching the ball on the valve, I believe. I bought a long 12mm bolt and used that to measure. Easier (to me) than trying to get a micrometer in there. Steve
Wallage book on rebuilding and tuning Crossflow's has 22-29 ft. lbs. Steve
Kiwi - It's really for track days. I had to limp home (225 miles) from a track day last summer, and finally decided that I was pushing my luck. My preference is still to drive it - but this opens up some other possibilities. Steve
Carl - Could you send me the AI files? Email is: smont7@gmail.com Thanks.
Mondo - Not really sure about the theory behind the design, other than some aero benefit and easy access to both ends. Jim - Pretty sure they didn't do any wind tunnel work when they were designing the trailer. I didn't feel any lift when I towed it empty back from Michigan. Mike - I thought it towed well, but I'd never towed anything before so don't have any comparisons. Drove through some serious storms coming home (windy and heavy rain), and it seemed to track well. I drove 65-70 most of the way home, and got about 14 mpg with the Volvo. I was hoping for more, but it (the Volvo) actually doesn't get very MPG in general. I considered an open Trailex, but really wanted something covered. My friend with the Lotus Eleven has the same trailer. He bought it as an open trailer when he first purchased his Seven, then had them convert it to covered. After owning it for about 4 years, he said he'd still make the same choice. Only downside is that there is lots of opportunity for leaks. But I'm happy so far. Steve
Picked up my new trailer from Montrose Trailers at the end of April. It's 14', enclosed and all aluminum, except for the deck. Total width, including the fenders, is 94". Interior width is 74". "Standard" width is, I believe, 104". According to the Certificate of Origin, it weighs 1380 lbs, but I think that is likely optimistic. Here are a few pics. Steve
Wendell - Here is a possible source for a new Girling, and/or parts. http://www.bugsandbuggies.com/Neal_Grp.asp?Group1=Cylinders&Group_Name=Master+and+Slave+Cylinders Steve
Blatchat cross post - UK L7 Club member looking for St Louis Seven owners
bball7754 replied to Croc's topic in Great Lakes
Dave - Thought I'd pick you up around 6:00 at your hotel. Maybe meet you in the lobby? I'll be driving a white Mini Cooper S. I'm about 5'10, and much of my hair growth has shifted from the top of my head to my face. Mike/Jerry - That should put us at the Tap Room around 6:30. Hope that works for all. Call me at work with questions/issues: 314-726-4551. Or cell: 314-605-6686 -
Haven't heard from Jerry. Charlie can't make it either week, and Chris F. can only make it next week. Mike - you up for this tomorrow, or should we try next week? I'm game for either - or maybe both. Dave - You're up the hill out there, so you should stay dry. -
Dave - Welcome back! Think it will be tough to get things organized for tonight. If we try for tomorrow, Jerry can join us. I was thinking of the Tap Room downtown? Not as far for you, Mike. I'm open to other venue suggestions. Dave - I can run out to Chesterfield and pick you up. If this doesn't come together, we go for plan B - sometime next week. Steve -
Dave - Like Jerry, I'm also out of town the weekend of the 14th-15th, so that weekend probably doesn't work for a Seven-esque gathering. Maybe something on the 10th, 11th, 17th or 18th? Think we need to get you out of Chesterfield so you can see other parts of St. Louis. If we leave it somewhat loose and weather dependent, Jerry, Mike (breezy7), and I could bring our Seven's - which is sort of the point, right? Can probably drag along a few ex-Seven owners. One has had 3, and is between Sevens. The other "traded' his SV for a '57 Lotus Eleven. Thoughts? You should have a personal message on your other topic. Steve -
Huge News: Team Lotus F1 team may takeover Caterham
bball7754 replied to rnr's topic in General Sevens Discussion
Interesting thoughts on the Caterham sale. http://joesaward.wordpress.com/2011/04/26/more-on-the-team-lotus-caterham-deal/ Steve -
An unofficial confirmation. http://joesaward.wordpress.com/2011/04/22/team-lotus-principals-buy-caterham-confirmed/ Steve -
I'm in University City, just across the St. Louis city line, and own a '98 Caterham. Let us know when you're coming back to St. Louis, and we can try and put some sort of gathering together. Steve -
Mike - Agree with Dingo's recommendation on the Roger King mod. I did it last year, and I went from spitting out a third of a catch tank worth of oil per session at a track day to maybe a quarter of an inch. And now that I think about it, as I remember you have a PCV canister for your crankcase ventilation, and not sure your valve cover cap had a vent. For what it's worth, the gasket from NAPA was Fel-pro 50091 R-1. Turns out the package actually lists "Ford British 4", both a "1298 cc (Crossflow) 67-78", and a "1599 cc Engine 67-73". Dave Bean part number is "416E 6451 - Valve Cover Gasket, special for Aluminum covers". And the Wallage Crossflow book torque listings state 3-4 ft. lbs. I agree with Dingo - it's probably not able to breathe, and is pushing it out under the valve cover. Steve
Mike - 1) I don't think it's serious. I don't have a leak from the valve cover, but have the same white "stuff" drifting out of my catch tank - which is where my valve cover vents to. 2) Probably. 3) Can check specific size tonight, but don't think it's metric. After all, it's an English engine from the '60's. Doesn't need a torque wrench, and my blatchat research indicates that you don't want it very tight. Too tight, and it leaks oil - seems counter-intuitive, but my experience has been that it's accurate. 4) Believe I got mine at NAPA. They had to order it, so got two. Have them lookup the part for the 1600 Pinto from around 1970. Can also look at my spare tonight and give you the part number. 5) Think I just put some oil on the valve cover side. A little fiddly, but not too bad. Mine tends to stay stuck to the valve cover when I take it (the valve cover) off. Steve
From my reading, changing jets, etc. on Webers is a steep, slippery slope. Float level is important. Did you check/adjust it when you installed the new floats? Carb's also have to be synced. Welcome to the brotherhood of the Xflow. Steve
