bball7754
  1. Robert - I have a friend here in St. Louis who is selling his Caterham SV. It was purchased from and built by RMSCI, and has the high HP Zetec and Caterham 6 speed. Photo of the car is attached. I've left you a PM with his name and email if you're interested in contacting him. Nothing wrong with the car, he's just replaced it with a Lotus Eleven. Steve Added a few photos of the Eleven, since I know there are fans here.
  2. Ian - I've been putting off dealing with the same issue on my Crossflow. I also have the Aldon Ignitor with the Unleaded advance curve, which as you said seems to max out at around 25-25 degrees advance. Other than sending to Aldon to be corrected, I guess a new Pertronix might be an option. It's on my list of winter projects. I'm likely going to go with shipping to Aldon. Sounds like Rob is the man to contact. Steve
  3. I don't have a heater, but believe that there have been issues with heat continuing to come out even with the controls fully closed. A quick search on Blatchat should return info on the issue. It's a pretty rich source of info on Caterhams. http://www.blatchat.com Steve
  4. Skip - Mine arrived today. My wife has family in Denver, so I'm hoping to someday be able to make good on my beer offer. Thanks again. Steve
  5. Mike - Appreciate the info. It's Putnam Park with 100-Speed. Haven't run with them before, but it's another 2 group trackday with the possiblity of the afternoon being just an open session for everyone. Weather looks good - high around 85. Steve
  6. Skip - I'll take one. How do you want to handle the payment? Steve
  7. Any suggestions on how far down you can safely run Toyo RA1's? At this point the only tread I have left are the groves that run around the circumference of the tire. Also, has anyone reversed the direction? The outside shoulder of the left side tires are the most worn areas of the tires, as I've mostly been on tracks that run clock wise. Pictures would obviously help, but woke up this morning wondering if I should change back to my street tires for a trackday tomorrow, and had to get to work before I could take any. Thanks. Steve
  8. Since Ian mentioned that there was info in the Tony Weale book, I thought I'd take a look at my copy. Not to steal his thunder, but per info in the book I think your code breaks down as: CS3 - Caterham series 3 3622 - Chassis number (I think we all figured that one out. ) TC - Big valve twin cam L - Left hand drive 2 - Mark 2 Escort Sport axle It also has a section on the approximate number sequence for each year of production: 1975 From 3570 1976 From 3625 The last section seems to contradict the approx. number sequence. It lists "Major Changes" by chassis number, and includes the entry: 1977 3612 TC R First Mk 2 Escort axle Again, credit goes to Ian. Confess I wasn't aware this info was in the book. Steve
  9. Since Ian mentioned that there was info in the Tony Weale book, I thought I'd take a look at my copy. Not to steal his thunder, but per info in the book I think your code breaks down as: CS3 - Caterham series 3 3622 - Chassis number (I think we all figured that one out. ) TC - Big valve twin cam L - Left hand drive 2 - Mark 2 Escort Sport axle It also has a section on the approximate number sequence for each year of production: 1975 From 3570 1976 From 3625 The last section seems to contradict the approx. number sequence. It lists "Major Changes" by chassis number, and includes the entry: 1977 3612 TC R First Mk 2 Escort axle Again, credit goes to Ian. Confess I wasn't aware this info was in the book. Steve
  10. Any issues with the height of the engine, and/or width of the transmission? Skip - I thought the trans. was a tight fit in your SV? Steve
  11. Mike - The starter is fine, and the solenoid is also, for the most part. The lead sticking out of the solenoid, which connects to the ignition switch, is not original. The connection of the lead inside the solenoid is loose. So it will work fine for extended periods of time, and then just stop. I can always start the car, it just takes two people. One turns the ignition to the "start" position, and the other (me) wiggles that wire on the solenoid. Starts immediately. Oh, and I'm trying to get it fixed before the track day at Putnam this Saturday. At this point I'm going to go anyway. I've already had to approach strangers at a gas station and ask them to turn the ignition, so I've got that process all worked out. You still planning on being there? Weather looks good. Steve
  12. I've been wrestling with an issue with the solenoid on my starter. At this point I'd like to just replace it, but I'm having trouble tracking one down. The starter is a Magnetti Marelli. The numbers on the solenoid have worn away and are illegible. Numbers on the starter are "27048A" and Type "M79 (0.9). Date on it is "26-97". Haven't had any luck with searches on both Google and Blatchat. Any info would be helpful. Lucas or Bosch equivalent starters (if there are any), vehicle the starter was originally built for, sources for a solenoid, etc. Thanks. Steve
  13. The Craigslist posting has expired, but from the pictures on the The Motoring Enthusiast site it looks like the car has Avon ACB10 bias-ply tires. Since he didn't know that he had a de Dion, it's unlikely that he knows that you need a different set of ears for non-radial tires. Don't know if that would cause the darty-ness, but don't imagine it's helping the situation either. Steve
  14. Had a recent request for a photo of mine, so I have one handy. Steve
  15. Here is a link to a post on Blatchat that covers reversing the buckle: http://www.blatchat.com/t.asp?id=38653 And here is a link to a site with pictures and step by step directions: http://homepage.ntlworld.com/richard.a.price/Luke_harness_swap3.HTM Did I mention I spend way too much time on 7's sites. Steve
  16. Mike - Unfortunately, just electronic ignition (no points) but no 3d. I think the cam does help. Believe my engine started life as the 135 HP spec, and later had the cam change. Steve
  17. Although my 1700 Xflow with 244 cam has the roller rockers, my reading on Blatchat supports John's view. Roger King (UK Xflow guru) actually seems to have negative views of the roller rockers, and seems to prefer the standard valve train for highly tuned Xflow's. There seem to be many happy UK Xflow owners who have added the 3d ignition. Steve
  18. Another option would be Dave Bean here in the US. They're listed in my copy of the English Ford Racers Catalog. Steve
  19. Here's the update, for those of you on the edge of your seat. First, a bit more background. My Crossflow actually has 3 separate gaskets, one for the front cylinder, one for the middle two, and one for the back cylinder. I had replaced the rear cylinder gasket about a year ago. The photo is a bit blurry, but shows the setup. To pull the header off, I have to remove the muffler from the 4-1 collector, then remove the collector. Anyway, did all that (again), and pulled the rear header off. As hoped, the gasket stayed mounted to the block from the silicone gasket stuff I'd used. Pulled the header out to check the face of the flange, and realized immediately that when I'd replaced it previously I'd noticed that the header pipe was slightly proud of the flange face on one side. I was able to use a round file to bring down the pipe without touching the flange face. Put the Permatex silicone gasket stuff on the flange side of the gasket, then put it all back togther. Let it set for about 30 minutes, than fired it up. No leak. Brought it up to temp and re-tightened, and still no leak. I think I'm good to go. Thanks again for all the feedback.
  20. Martin - That does help, although it means I may have to write off the track day. Dave - I didn't use the Permatex 300, but did dress the one side of the gasket with Permatex High-Temp Red RTV Silicone Gasket. After I scraped the block surface with a razor, I used some steel wool to get the remaining old silicone off. At the time I wondered whether the steel wool would cause the surface to become untrue - although obviously I decided to go forward with that method. Bad decision?
  21. I replaced the exhaust gasket on the rear cylinder of my Crossflow last weekend. Used some high temp silicone between the gasket and block, but didn't use it on the side of the header flange. Fired it up last night to bring the engine up to temp and retighten, and it still leaks. Got better after I tightened, but still not a complete seal. Realized that I hadn't cleaned the surface of the header flange, only the surface on the block, so I'm wondering whether that's causing the problem. Long intro to the real question. I have a track weekend this Sat. and Sunday. Any chance for real damage (burned valve,??) if I leave it as is? I've considered taking it apart and cleaning up the surfaces, but am worried that the gasket won't make it through the process, and I don't have another replacement. Steve
  22. Here in MO you can purchase a 1 day permit for driving to and from an inspection. It was around $5. MN might have something similar. Steve
  23. I've had a similar experience with my Caterham, although it would ultimately start. I have a Crossflow, so no modern electronics to deal with. But I would turn the key and get nothing. Starter didn't engage. But after numerous attempts, it would work and the engine would start as normal. Spoke to Ben, and he said that the connections to the ignition switch can become either loose or corroded. It's near the top of my list to get under there and clean things up. Steve
  24. This just came up on Blatchat. Apparently the savings is about 20 kg. http://www.blatchat.com/t.asp?Id=166574 Steve
  25. Interesting thoughts/observations, but I'm wondering if it's not all a bit backward. As Martin stated in his post, the 11 was designed first (1956), followed by the Seven. Steve
