bball7754
  1. I’m considering going to the 2024 British GP to celebrate my 70th birthday (which falls on the July 7 race day). I’ve started exploring companies that have packages of accommodations, transport, and tickets, and was wondering if anyone had any recommendations? Steve
  2. FWIW, when I bought my 1998 19 years ago, it had several chips in the heated windshield of similar size. I’ve never done anything, and they have never grown. Although I probably just jinxed myself! 😊 YMMV Steve
  3. The 155 was on his dyno, not at the rear wheels. But, it feels strong, and was a HUGE improvement from before the rebuild. He didn’t change the cam, valves, or rockers, it had all those.
  4. Curtis rebuilt and upgraded my Crossflow. Forged pistons, SCAT crank, and he did some head work. I have the 244 cam and roller rockers. As I remember it made 155hp on his dyno. Still runs strong. Wish he was still building engines, and agree that he’s likely down in the Caribbean sailing. Steve
  5. Are you keeping/using the bellhousing? If not, I might be interested depending on the depth of the bellhousing. Steve
  6. I have a set of Magnecor for my Crossflow. https://www.burtonpower.com/magnecor-ht-ignition-lead-set-ford-x-flow-side-entry-8-5mm-mes01s-85.html Burton also has their own brand for about half the price. Exchange rate is pretty good right now, and I’ve been surprised (in a good way) at the shipping price. Steve
  7. bball7754
    Washer?
    So I think the issue with the replacement rubber washers was that I over tightened and compressed them, which led to them disintegrating. I’m not totally comfortable with only relying on the friction of the nylock preventing the nut backing off. As long as the unthreaded length is slightly longer, I can test fit just the plate and add one or two thin washers to allow me to tighten the nut, but not compress the rubber washers. The original washers were less compressible than the rubber washers, and were more able to withstand my incorrect overtightening.
  8. bball7754
    Washer?
    MV8 - that is the setup, incorporating the large machined hat. So the length of the unthreaded portion of the bolt shank should be slightly less (1/16th ish?) then the total length of the washers, bushing, and the plate. This will allow the nut to be tightened against the non-threaded portion with minimal compression (almost none) of the rubber washers, allowing them to retain their full dampening properties.
  9. bball7754
    Washer?
    I have been looking to identify and source these washers off and on for several years. They are on my Mallock, and are used on either side of a large bushing inside of a boss on the chassis, to which an aluminum plate is bolted and used as part of the engine mount. They seem to be made of some type of fibrous material, sort of fabric like. They are finally disintegrating, and the reinforced rubber replacements didn’t last 3 race weekends. I know there are some excellent Google researchers here, with more knowledge and experience than mine. Engine is currently out, so now is the time to replace. An aeronautical engineer came up with this design when he built a replacement chassis, in case that helps. A photo in situ, and a blurry photo to give a sense of size.
  10. With clamshells!!!
  11. Based on the last photo, it looks like you bought Jerry’s WCM?
  12. Still a definite maybe, but the probability has decreased. Those are the same dates as the last race of the season at the new Ozarks International Raceway. While Ozarks and International are not words normally associated with each other, the track is close (3 hours) and amazing. It’s 2 years old, 19 turns, and more elevation change than you can imagine. One of the most fun tracks I’ve driven. It even has a mini Eau Rouge. In Missouri!! Who’d a thunk it.
  13. You were at Black Hawk last weekend, right? We talked, and I have the polished Mallock. Meant to suggest you post here, glad you found the site! Steve
  14. Mike- thanks, although I think one Mallock is enough for me! 😊 There have been times when it felt like one was too much! Went to the New England Classics site (as I remember that dealership has an interesting reputation), and the write up said the 15 is the same as the 11 but with a deDion rear suspension. I’ll have to research that a bit. Another Mallock joined me at Black Hawk last weekend, and it was in theory an 11, but had the deDion rear.
  15. Looks great, and love the Pirelli Cinturato CN36 tires!
  16. Mike - These are two new additions to the storage lot where I keep my trailer. Interested in a new project? 😊
  17. I joined in 2005, so was pretty confident of my history. 😊
  18. Wasn’t/isn’t the screen name of one of the originators (or maybe THE originator) of the site SLNGSHT? He put a V8 into his Rotus.
  19. The Webers are low pressure, 3-3.5 psi. More pressure overwhelms the floats. I’m confident the Facet is higher than that, hence fuel regulator. Do they still make that model? Any reason not to just get the same? Steve
  20. @Croc Assume you’re following this? https://bringatrailer.com/listing/1975-bmw-3-5-csl/
  21. That’s the weekend before the VSCDA race weekend at Road America. May not be an issue if the Mallock is not running by then….which unfortunately there is a high probability of based on it’s history. Or, I may do both. I’m a definite maybe. Steve
  22. I have these and they work great. I don’t think a drop came out the last time I pulled the engine/trans. https://www.summitracing.com/parts/lil-23400?seid=srese1&ppckw=pmax-tools&gclid=Cj0KCQjwpPKiBhDvARIsACn-gzAvDFlhzZ-752hhspUWB_0owmqtbHtC8kz1cAP99gF15rNj0WAsjbMaAhkNEALw_wcB
  23. I’m getting a “Page not found” error.
  24. Does that jack in the background lift the car high enough to get it on the stands? If not, how did you get it on them?
  25. FWIW, I stopped fastening the bottom dzus fasteners about 10 years ago, and that includes lots of track sessions. YMMV. 😊 Steve
