bball7754
  1. In case you’re also looking for the Webers….. https://www.apexspeed.com/forums/showthread.php?88843-40DCOE-ITALIAN-Webers-and-Manifold-Kent-1600 Steve
  2. I have nothing to add, other than this is why I hate plumbing! Steve
  3. You might want to try Redline Components in the UK. Believe your best bet is a phone call. Steve
  4. Not sure if it’s still true, but at one point the Caterham electrical OP gauges were known for failing or reading incorrectly. Mine did, and I took the advice at the time and replaced it with a mechanical gauge. No issues since. Steve
  5. A mini Seven gets a mini build thread. 😊
  6. I have no actual experience with removing the body panels, but I would think it would be extremely difficult to remove them without damaging them. I don’t think it’s the kind of project that is considered “maintenance”. Drilling out the rivets will enlarge the diameter of the whole in both the panel and the chassis. Also, the flared part of the rivet will remain inside the chassis tubes, creating a giant rattle. Although I doubt you could hear it, it has been cited as an area of concern on Blatchat. What year is your Seven? Is there a reason you are concerned with the state of the chassis? Steve
  7. Seems to me your effort deserves a dedicated thread. 😊. Doubt I’m the only one who finds your build interesting. Clam shells? They would be appropriate on the Cape! 😊 Steve
  8. bball7754
    Hagerty
    I insure my Caterham with them, and enjoy their magazine, but wasn’t aware of the rest of their ventures and direction. https://www.nytimes.com/2021/12/16/business/classic-cars-hagerty.html Steve
  9. I purchased a Crossflow over the summer, and he had at least one other to sell. Believe it was a 711M. He is in SC, and can put you in touch if you’d like. But, I came across this post after I’d purchased the engine. Wish I’d seen it before - I could have gone and gotten the engine rather than paying for shipping. https://usa7s.net/ips/topic/13328-locost-parts-for-sale/
  10. Quite a build, worth the read.
  11. I have no wisdom to add, other than sharing a few photos of my experience with insufficient octane. This happened after about three (maybe two) laps at NJMP. I had filled my fuel containers on the way to the track, and have wondered if the attendant didn’t fill them with Premium as requested.
  12. Did Caterham/Arch notch the chassis, or was that a modification made once kits reached the US? My recollection is that some of the first, if not the first, Zetec’s were installed in US cars. The lack of a body patch on the right side to cover where the Zetec exhaust would have been confirms to me that this always had a Duratec. Believe the early Duratec cars had the notched left rear fender as that was all Caterham made at that time. This may be a one of one Seven, with the combination of clam shells, Duratec, red interior, wagon wheels, and white piping on the tonneau cover.
  13. Hmmm…. first review I looked at on Pistonheads had multiple statements that the sidewall is “very stiff”. Not good for a Seven.
  14. Anyone ever use Nankang tires? Saw these on a Europa on BAT, and was pleasantly surprised to see they are available in 14”, both 55 and 60. https://www.nankangusa.com/passenger-tires/ns-2r-sportnex/ Steve
  15. I thought the rear fenders looked different. They seem narrower, more Series 1/2 like. They would look good with my clamshells, I think.
  16. Found the KitKat thread: Sounds like Redline is your best option. Steve
  17. I know Mike (KitKat) had a half-shaft issue, so I expect he’ll be around soon to provide info on his experience. As I remember, it was quite a challenge to find parts. Steve
  18. Just booked a VIP Suite, and will register shortly. New helmet arrived yesterday. Oil changed, brakes bled, new front pads. And I’ve squeezed in an econo $10 polish job. 😊 Targeting arrival around 2:00 on Saturday. Have been in touch with TJ to do a quick alignment, although I’ll run even if I can’t get it done. Steve
  19. What did you decide regarding the head gasket? Just curious. That photo that showed the small round opening sort of looked like a plugged channel, particularly thinking back to all the rust removal efforts you went through. Steve
  20. I needed a new helmet regardless, so that’s been ordered. Many racing organizations, including the VSCDA that I run with, are still accepting SA2010 helmets this year. But next year I’ll need a 2015 or 2020.
  21. After a long hibernation, my Caterham is back running. So……I’m now a possible. My belts are fine, but primary issue is a new helmet, which I’m working on. Need an oil change and brake bleed, but those are scheduled for tonight or tomorrow. And I have to accept that it wouldn’t get a fresh polish before the event. Steve
  22. Do you have a Pertronix ignition in the distributor? I had an intermittent issue with the Crossflow in my Mallock which got worse and worse. It finally cut out on track at Road America, and it wouldn’t start. I had a spare ignition, which I installed, and it still wouldn’t start. It had fuel, and electric from the coil to the distributor. I had read that the normal brown color rotors can be a problem. Pulled the rotor, and showed it to an extremely knowledgeable mechanic who prepares vintage race cars. He took a one second look at it and said it was bad, and was shorting out. I found a replacement red rotor at the track, put it in, and it started immediately. No issues since. Steve
  23. I also found that pumping slowly was the key, and agree 1/2 is about the max. However, I still have the occasional overfill, usually right after I’ve polished the aluminum.
  24. bball7754
    CycleKarts
    I’m pretty sure everyone on this site reads BAT daily, but for those few who don’t or have missed this article: https://bringatrailer.com/2021/07/26/event-coverage-the-huntsville-cyclekart-grand-prix/ The first video is excellent, and gives a great presentation of the types of personalities drawn to CycleKarts. Seems to me they would fit in fairly well with Seven owners. 😊 Stev
