bball7754
  1. Graham - yes, in retrospect Gateway was not the optimal track for my first track day. It is definitely on the dangerous side, with extremely limited runoff areas and lots of concrete walls. TBH, I don’t run there anymore. Mike - Well, I actually bought the car in 2004 for my 50th birthday, but couldn’t get it shipped from Denver until Jan. 2005. So, sort of 18 years.😊 Steve
  2. My intro to track days was with Nathan. The spring after I purchased my Caterham, LOG was in St. Louis. Nathan was working at RMSCI, and he and Ben Wofford came to St. Louis. As part of LOG there was a track day at Gateway, and I think Nathan came out with me during my first session, as well as providing some coaching. What I really remember was going out with him during his last session, and getting a sense of what it was like to truly drive on track.
  3. That’s what I thought. Ask Nathan as I’m pretty sure he drove one year. Maybe not 2009.
  4. Mike - wasn’t your car in a 24 hour race (Buttonwillow?), which is why it has the large gas tank? As I remember, Nathan drove a Caterham in that race. Your car? Think they ran a Caterham 2 years in a row, but not sure Nathan drove both years. Lots of rain one of the years. Apologies for the mini thread hi-jack. Steve
  5. Unfortunately, think I need to be a maybe. Date conflicts with a VSCDA race at Road America. However, given the seemingly never ending issues with the Mallock, I’m not counting myself out yet. Steve
  6. bball7754
    Lotus SUV
    https://www.nytimes.com/2022/04/21/business/lotus-eletre-suv-electric.html With quotes from Ross Robbins! 😊 Steve
  7. Couldn’t find the website for the one in the US, but here is evidence that you are not alone. 😊 https://purplemeanie.co.uk Steve
  8. I think I’ve read of people going to bicycle shops where they can replace the cable and retain the existing housing. Might be worth a call. Steve
  9. I replaced mine ( S3- Crossflow) using a jack. It was fairly early in my ownership, and I remember it being a longer and more frustrating job than I expected. But, ultimately it worked.
  10. Yes, the plan is to be at Blackhawk in June. Actually, the plan is to make the entire VSCDA season, which would be a first. My ownership of the Mallock has been, ummm….challenging. So, we’ll see how the season goes. Right now, I just want to get it all back together for Gingerman. Steve
  11. Thanks. I had printed out a plumbing size sheet from BAT, and it seemed like the pump port was 3/8”, although I expected it to be 1/2”. So you think the hose end is also BSP? This is me at Blackhawk in 2020, so probably. 😊 That was right before the S2000 went flying by me.
  12. Hoping the collective wisdom of this forum can solve my plumbing challenge. I had the Crossflow in my Mallock rebuilt, and the engine builder did not replace the fitting on the side of the engine block and one of the fittings on the front mounted oil pump with what I left him. So, I want to replace them with what matches the existing female hose ends. Think I have the block figured out. I need a 1/4” BSP male/-8 AN male fitting, and am confident on that one. The female hose end definitely is -8, and BSP seems correct for the engine block side. Titan no longer makes the front mount oil pumps, and can’t seem to find any literature that specifies the port size. But, it seems to be 3/8” BSP. It’s the female hose end that really has me stumped. It’s a convex female. A spare male/male adapter kicking around my garage seems to fit, but that style of fitting seems to be either NPTxNPT, BSPxBSP, or BSPxNPT. The female hose end is not chamfered, but is flat, so it’s not AN? Could it be metric? Or should I just replace the hose, and use a male/male 3/8”BSP/-8 AN with a -8 AN hose barb? All these fittings were on the car when I purchased it. I’m hardly Carroll Smith to begin with, and I HATE plumbing. Any and all thoughts are appreciated. First pic is the hose fitting in question, and the incorrect fitting in the pump as returned by the engine builder. Fourth pic is the fitting with a male/male adapter I had lying around that seemed to fit the hose end. Last pic is the incorrect fitting removed from the pump.
  13. I mounted mine under the carbs. My ‘98 has a mounting bracket for the windshield washer fluid reservoir, which I never used, under the carbs. Removed the reservoir and drilled a few holes in the bracket for the pressure regulator. Steve
  14. Are you pushing the entire hoist, or “swinging” the trans towards the engine? If you’re “swinging” it, then the height will change. Believe the last time I did this, I put the trans on my jack and balanced it with one hand while I moved the jack/trans towards the engine. Even easier to do it that way if you have another pair of hands. Thought I’d throw another option out there. 😊 Oh, and make sure you have both positioning dowels in either the block or the bellhousing. Steve
  15. The racers use it to hoist the entire car by the roll bar, then put supports under the car.
  16. Thought I’d throw this in the mix as an option, although probably not what you had/have in mind. https://www.mktechnologies.com/products/mkt/mkt_a-frame.htm Steve
  17. Have you contacted Caterham in the UK about a key?
  18. I don’t find myself using the new features, but have enjoyed when the pic of Reese Witherspoon comes up. I didn’t know she owned a Seven! 😊
  19. 520 miles, St. Louis to Birmingham AL for LOG 29 in 2009. Rained for the first 3-4 hours, so started out with the full hood on. Other than that, no real excitement going or returning. Furthest drive for a track day was St. Louis to Hallet, 430 miles. I did loose a bolt on the alternator bracket, but a trip to Home Depot solved that. Knock on wood, I’ve never been stranded.
  20. Will you peel down the protective covering before you rivet to avoid it being trapped under the rivet heads? Really enjoying this build thread, by the way. Steve
  21. Michael - Agree, that sounds fair. I’ll give you a call tomorrow. Steve
  22. Michael-I’m interested in the clam shells. Mine are pretty tired, and would like a backup set. Steve
  23. Vin - Sorry, I didn’t do a very good job reading your post, and missed that you already have the SCAT crank. I also have roller rockers. The C/R is 9.91, but the only info Curtis gave me is that he got the pistons from Burtons in the UK. Don’t have any specifics. I would think that around 12 would be way too much for pump gas. I think the Crossflow in my Mallock is 12.5, and I use 110 race gas with it. Where are you on the Cape? My aunt had a house in Chatham where I spent several summers. Steve
  24. Looks fantastic! Did you polish the ali before mounting the front suspension? If so (and I think you did), you will never again have that kind of access to that portion of the body. I always find that area a challenge. Steve
  25. Vin - when I had my Crossflow rebuilt by Curtis Farley (now retired), he recommended that I replace my stock crank with a SCAT crank used in FF engines. I did, and have more peace of mind around 7k. I already had the 244 cam and a head with port work and larger valves. Added forged pistons and the crank. It’s been great, and still strong. Steve
