sf4018
Everything posted by sf4018
  1. Regarding the BFH, on the 2nd time installing the diff (after a shaft replacement) we needed some real power to get the top bolt in. We couldn't get enough power under the car (not enough hammer stroke) so we taped a threaded rod to the long bolt head, long enough to poke out into the wheel well area, then use a masonry hammer outside the car, can really put some power into it. Good times.
  2. Try adding a light or some indicator temporarily to each of the outputs to the relay circuits relating to the engine starter/ignition, maybe something strange is happening to the key wiring.
  3. If you don't have luck try this - remove each of the 2 shorter bolts below one at a time and replace them with narrower screwdrivers than the bolt, this will allow enough play to move the diff around a little but still hold it in place. Then you should be able to move the diff to straighten up the exit for the long bolt and smash the crap out of the long bolt to get it through. Once the long bolt is through working the diff for the shorter bolts is a lot easier, use a hydraulic jack to align the LSD to the chassis holes. Stuff of nightmares.
  4. Here you go... For the trailer you can definitely use the rear wheel as well, that's probably more standard way. I just got into the habit of using the sub frame as the rear wheel area is usually too hot to handle when loading after a race. It all works, the car is so light anyways.
  5. The previous dyno we tied off the rear of the car at the sub-frame (the circular tubing), also do that for transport on the trailer.
  6. I have a 6 point harness for racing, I don't see a benefit of a 7th. I also use arm restraints to keep limbs inside and Hans device to prevent neck injury on front impact. The biggest risk for my setup is lateral impact to the neck. I believe some people have installed a halo (from a radical?) and bolted to the roll cage, which is ok but the problem with that is the standard Caterham race seat is not secure with only 4 bolts connected to the thin aluminum floor on the bottom (normal race car seats are bolted at the back to the roll cage as well as the floor so they will not move at all) so there's definitely potential for seat movement on impact. I wish there was a better racing solution for the seat, I tried to find a seat with lateral head support but was not successful finding one that would fit, they are all pretty bulky and flair out too much on the sides.
  7. I had the same, it is odd. I coiled it up and strapped the down beside the engine somewhere, you don't want it hanging down below the chassis or flapping around in the wind.
  8. Have you checked for any nicks or scratches around the top edges of the tank where the cap screws down to?
  9. What are the hot/cold pressures for the R7? I’ve never run them before. The spec sheet has these pressures but they seem high.
  10. I would guess it's a mechanical issue in the tach. No idea if it's serviceable.
  11. The front suspension is easy access, just jack up one side, make the adjustment and repeat for the other side. The rear suspension can only be accessed from underneath. I don't have the trailer space to put in a hydraulic lift so putting it on jack stands is the only option, which is time consuming, especially if I have to repeat a few times. Maybe at the end of the day but then I'm eating into beer time
  12. Type Manufacturer Model Comp. Front Wheel Size Front Part # Rear Wheel Size Rear Part Number DOT Avon ZZR A64 13x6 185/55R13 13x8 215/55R13 ZZR DOT Hoosier R7 R7 13x6 P185/60ZR13 13x8 P225/45ZR13 Slick Hoosier F2000 R35B 13x6 20.5x7.0R13 13x8 22.5x8.0R13 Some notes on suspension... The f/r ride height is currently tuned for the ZZRs. If I put on the F2000 I'll have to raise the front by 9mm to maintain the rake, which would not be too hard to do at the track. For the R7s though it's a real problem, I'd have to lower the front by 30mm, I'm not even sure that's possible at this point I haven't tried, but that's a huge change. Changing the rear ride height at the track would be a major pain. I already have the tires and wheels for the R7 so I'm committed for now to running them, but a better combination will be 13x6 fronts (same R7 tire) but the taller wheel size on the rear (15x8). This combo will minimize suspension setup change to the ZZR. I had a short look around to see if there are wheel sizes of the same style for 13x6 and 15x8 that would fit but I couldn't find any. I'll dig deeper later this year.
  13. Fully stocked for the year Used Avon ZZR A64, Hoosier W2, Hoosier R7, F2000 slicks.
  14. Time is a great healer.
  15. Ok thanks guys. I see the warning light now, just wanted to make sure there wasn’t an issue with the brake light. Strange that it’s not on the wiring diagram.
  16. I may (or may not) have an issue with the handbrake wiring. The wiring diagram on the assembly guide version 2015c on page 218 doesn’t even seem to show any handbrake wiring on the chassis wiring diagram but there are 2 wires connecting to a switch that is actuated when the handbrake is pulled up. What’s the handbrake switch supposed to do? Should the brake lights come on when the handbrake is up? Any info appreciated!
  17. @SK400The chassis harness has these 2 connectors for the reverse switch which used to connect to the GB on the RHS... Assuming BY10/G9 is in fact the reverse signal and not power wire up BY10/G9 to these (direction is not important). The 12V comes from G73 for the reverse light. You'll have to snip off the weird connectors for GN137/G73 and put on some Deutsch or whatever. Steve from SBD will probably know about the ECU pin function. No idea for the rest. Is this the Caterham kit 6 SPEED SEQUENTIAL GEARBOX KIT - Caterham Parts?
  18. What ECU do you have? For a MBE9A4 ECU, pin 16 is an output from the ECU, pins 19 and 27 are programmable inputs to the ECU (shift up/down?). Guessing G9/BY10 is the reverse switch, like MV8 says put it in reverse and see what happens to the ohms across those wires. That would leave getting power from the left connector I suppose. No idea what the 5 wires are for other than power.
  19. That’s terrible! https://caterhamparts.co.uk/calipers-pads-discs/7662-1-brake-pad-rear-standard-material-de-dion-cars.html CP3915-42-DS25HP
  20. Agreed, I’m looking at that for the rears. From my personal experience on the A7/R7 choice track temperature is also a big factor. I have not run on Hoosiers yet in the 7, but in another race car which weighs 2850’ if the air temp is above ~60F and sunny R7s are the way to go. I would imagine for 7s it’s a higher temperature, maybe someone with experience in Hoosiers would have some insight.
  21. A7 isn't available for the sizes unfortunately or wasn't last time I checked.
  22. I encountered the same stuff during a fuel cell installation project a few years ago. It's crazy that the pump control module is basically guessing the fuel demand. With your new ITB the "guess" is no doubt going to be wrong, especially if you have the green injectors. The Pump On command wire GY from the ECU has to be a pulse to work, you cant just leave it on to run the pump, so I ended up removing the pump control module, though It's not as safe. Also the fuel pump really drains the battery quickly when it's on full time, so watch out for that. I made a thread on at the time, it has some diagrams and videos with and without the pump control module, you've figured most everything out already but maybe there will be something in there that is useful...
  23. Wheel Size Use Type Manufacturer Part # Comp. Diam (in) Diam (mm) Width Width (mm) Notes 13x6 Track DOT Avon 185/55R13 EXT ZZR EXT 21.0 533 7.3 185 No longer available 13x8 Track DOT Avon 215/55R13 EXT ZZR EXT 22.3 566 8.5 215 No longer available 13x6 Track DOT Hoosier P185/60ZR13 R7 21.9 555 7.3 185 13x8 Track DOT Hoosier P225/45ZR13 R7 20.9 529 8.9 225 15x8 Track DOT Hoosier P225/45ZR15 R7 22.8 578 8.9 225 Avon ZZR rears have a diameter of 566mm; the Hoosier P225/45ZR13 is 37mm smaller but the P225/45ZR15 is only 12mm bigger despite being on 15" wheels. The problem for the P225/45ZR13 is the limited top speed (usually run >125mph on straights) and the massive suspension adjustment. The P225/45ZR15 may be problematic too with needing more torque to get to top speed, but at least the suspension adjustment isn't huge. I need to think about it more.
  24. Well crap I may have made a mistake on the rears. Has anyone gone 13/6 front 15/8 rears on the Hoosier R7?
