sf4018
Everything posted by sf4018
  1. Thanks all especially @JohnCh for the suggestions and info, so to summarize these are the options... 1. Rebuild engine with new pistons and other internals. 2. Add Roller Barrels or Throttle Bodies 3. Replace Diff. 4. Entry level 5 psi regulated turbo setup with rising rate regulator, small oil cooler, and no intercooler. e.g. Garrett 6262. I think I'm gonna focus on 2 for now, seems the easiest for my limited skill and tool set.
  2. I’m looking to increase the HP of my standard 420R Duratec 2.0 engine by 20-30 HP to be a little more competitive in a race. I have an unlocked ECU and a fuel system that pushes 60 psi of fuel. The tune is setup rich to better ensure engine life and fuel consumption is not a problem (the tank is ~14 gallons). Does anyone have any suggestions or recommendations?
  3. I'm sure you've done all this already but make sure lid clicks during tightening, check hose clamps are tight, remove the top bolt of the radiator to make sure there's no air trapped, and make sure the cooling fan switches on before you hit the red line on the temp gauge.
  4. For me the engine harness is a sub harness to the ECU harness, yours might be different, dunno.
  5. I've not replaced the ECU harness but did replace the engine harness recently, I tried to do with everything in place and feed the harness through with the existing but it's too tight with not good enough hand access, so ended up replacing it after removing the engine for something else. I would imagine it would be a similar story for the ECU harness - lots of stuff to remove, I would guess the scuttle and prop shaft would have to come out at minimum.
  6. I had the exact same symptoms for oil pressure. Ended up being an intermittent loose ground wire somewhere on the engine harness. Swapping out the harness also fixed a weird issue with bogging down on track on occasion.
  7. The Lambda for my duratec is all over the place when accelerating/decelerating, between 0.85 to 1.30, but the engine feels good. https://youtu.be/uqRcBIpMkSY
  8. I'm guessing that's an S3 size? Not sure what they mean by "metric"?
  9. https://caterhamparts.co.uk/pumps-senders/726-fuel-pump-for-bag-tank.html?search_query=5249970000&results=1 its a Bosch pump, 100lph. The fuel system is pressured to 60psi, the return is local to the tank, not at the rail. My guess is it’ll draw 2/3 the amps of yours. Don’t have the p/n.
  10. I didn’t upsize the Caterham wiring for my external pump, works fine. Didn’t notice any heat build up in the cable either so doesn’t appear to be close either. Only reason I can think of to do is if the voltage drop for 16AWG at 10A is too high (can’t imagine it would be, the wires are not that long).
  11. Just a thought in a different direction - the hydramat: does it work with higher fuel flow return to tank applications with it being basically a big filter bag? Can the pump take the negative pressure intake?
  12. The Lambda drifting to lean over a few seconds looks like the fuel psi dropping away to me too than a tuning issue. Don't know how much effort it would be to bypass the ECU pump run command and just have the pump run full time temporarily to see if it's a problem with the ECU output and/or rear relay.
  13. Can you give some detail on the new relay - what type of relay and where you installed it? I need to do the same thing and control the pump run command from the ECU. For me SBD had a 420 race setup but it was quite far off in the end. He spent 3 hours tuning the cold start, warm start, low rpm stuff in one session at the house then another 3 hour session for the full mapping and tuning on a dyno. Very expensive. But haven’t had any issues since.
  14. Is the fuel pump control module still part of your system? https://caterhamparts.co.uk/pumps-senders/5336-fuel-pump-module-seven-485.html?search_query=Fuel+pump+control+module&results=184 if I remember right the fuel system has a pressure regulated return to tank from the rail?
  15. Any luck?
  16. Caterham's factory installed fire system is based on this system... Lifeline Zero 2000 2.25 ltr Club Fire Marshal Mechanical System (lifeline-fire.com) ...it says it's a foam system, but I couldn't find any more detail on what kind of foam, maybe that's proprietary, dunno.
  17. I have the 9A4. Attached is the Race Studio 3 .xc1 file and the pinout for the ECU if you want to hook the temp sensor up to some spare IO. The CAN output from the ECU is programmable so it is possible to add any sensor to it. MBE9A4-PinoutIssue_F.pdf Caterham_420R New ECU_@20210824_224149_008622.xc1 Cheers, Simon
  18. It's an 8 bit unsigned integer, 0 (0v) = -30C, 256 (5v) = 130C. If you have the SBD ECU have a CAN protocol for Aim RS3 if you want it (I think I modified it some on the ECU side but it's a reference at least).
  19. My wife has that weekend pencilled in for a trip to the smoky mountains, which is about half way there so if I can sort out timing and logistics it may work out.
  20. Did you get to try them out? We had too much rain to cycle through the compounds last weekend, but did try out the A24s - they basically melted during a sprint race, it was a sunny day tho so I guess the track was quite toasty.
  21. Doing it right now, I hate the diff!
  22. Sadly true, the ESG movement in the UK is ruining the potential business climate. Jeremy's Farm highlights this too.
  23. Signed up for Sunday only too. 3 Sunday spots remain, 19 Sat/Sun spots.
  24. Thanks @jimmylukeii, sorry I dropped the ball on this, it looks like the registration opened last week sometime. The novice green group has sold out already unfortunately, but there are 20 spots open in the solo groups. The solo groups will require a list of previous track experience. There is a waitlist possible for the green group though. I didn’t realize it was going to be this competitive , this may scupper the whole event. There’s another series I’m racing in here at Barber next month, it sold out in 27 seconds. We know this because we hit the submit button a few seconds too late. Luckily we got in on the waitlist, but still, it’s nuts right now the demand.
  25. I heard Avon will be shutting down production the end of this year and the molds may move to the US (Goodyear). Don’t know how much of that is true.
