sf4018
Everything posted by sf4018
  1. Roger Kraus Racing has some ZZR 333 and A24 compounds that just came in if anyone wants some.
  2. I have a set ready for the Mitty in April (along with A64s and A24s). I would hope the grip will be better, but the main interest for me is how many laps will they take to get going. 6 laps on the A64 is too long, about 2/3 of a sprint race.
  3. These are the prerequisites for the pump to run: 1. Master switch on 2. Key in position 2. 3. Immobilizer unit sees the fob 4. Inertia switch ok. At that point the pump control unit is powered up. The unit runs the pump when: - Initial power up it runs for 1 second to charge the system. - Sends a pulse to the pump on each rising edge signal received from the ECU output. It does not stay on if the ECU output stays on . So I modified the pump control relay harness to take out the unit completely and run the power and ground from the clear/white connector directly to the pump (the large green/yellow and black wires). The issue with this is the pump runs even when the engine is not, which is a battery drain issue and somewhat of a safety issue (e.g. if the fuel line breaks it'll keep pouring gas instead of cutting out). I guess a solution could be to find an alternate unit to the H8QTB so it just runs when commanded by the ECU Engine Running signal. May not exist, dunno, documentation is scarce.
  4. Really well thought out and executed, looks great, congrats! When I did redid the fuel system I was expecting the pump control relay to the left of the tank to be a dumb relay that switched on when the ECU command is on. Unfortunately for me it only pulses the pump on the rising edge from the ECU, it's basically looking for the engine rpm pulses to drive the pump. I ended up taking the relay out so the pump runs full time, but it's not particularly safe to do this if the engine is not running to have it pumping gas plus the battery drains really quickly. Looking forward to see what you come up with for this, I'll probably copy whatever your solution is.
  5. Thanks for the responses, registration will open mid February I believe so I’ll circle back early February to gauge interest.
  6. There's been some chatter about having a get together in the Southeast for a while now, so here's the first go to try and organize something. Chin Track Days will be running a HPDE at Barber Motorsports Park on April 15-16, 2023. Chin runs their HPDEs very well and have both beginner groups with instructors and solo run groups, so there's something for everyone. Weather is usually really nice can be unstable this time of year but even if it does rain it dries out pretty quickly. This will be a casual event. The 16-turn 2.3 mile course is finished to a very high level: fantastic surface conditions, and safe run-off areas. Perfect for Sevens. And, the lap is famously surrounded by an eclectic collection of outdoor art installations and sculptures! It's a technically challenging course that rewards car set-up and driver skill over horsepower, and several notable blind elevation changing corners. Right next to the track is the Barber Vintage Museum, one of the world's most renowned collections of motorcycles. The intent right now would be to integrate with Chin's usual group formats. Green: This is a novice group with instructors and classes. Blue: This is the intermediate solo with point-bys. Red: This is the advanced solo group, with no point by. I think we would probably split into 2 groups - the green and blue, any red drivers (if they want to drive with the group) would request a move to blue, but we'll figure this out between the drivers and Chin later on. Maybe there will be more red than blue, who knows. Saturday evening we'll setup dinner at one of the great BBQ places nearby and also possibly one of the awesome microbreweries in town like Cahaba Brewery. Registration doesn't open for a while, but when it does it sells out quite quickly, especially the green group, so if we do want to do this we'll need to be ready. Anyways, I'm open to changes in dates or even locations, just wanted to get the ball rolling!
  7. You have more patience than I did trying to get the OEM supply hose off the tank, congrats. I wish I had your knowledge level when I replaced my fuel system! I would say if you're going to run a return line to the rail you might as well replace the original supply line too, it's a crappy semi hard plastic, the diameter is quite small too and hard to work with. You can then put on your own fittings on the ends. I ended up with 5/16" stainless braided hose with connector... Dorman 800-081 Dorman Fuel Line Connectors | Summit Racing Spectre Performance SPE-29310 Spectre Performance SSteel-Flex Fuel Lines | Summit Racing
  8. They are Hoosier F2000 slicks, the old softer R35 compound (got them on the cheap as the series has moved to R55).
  9. No supply chain issues next year Includes 1 set each of ZZR A64, A24, MAX for the Mitty next spring.
  10. We managed to take apart the u bolts in the tunnel. There was no grease in the universal joint, completely dry. There’s also no zerk or any way to grease it. We IDed the universal joint as a moog 340. We’re going to get a moog 341 with the zerk. I can only assume the shaft was assembled incorrectly by the supplier to Caterham.
  11. One of the U joints on the driveshaft is very stiff. Here’s a theory about the gearbox oil loss: the drivetrain vibration at high speeds is caused by the bad u joint, the vibration from this causes the yoke to vibrate inside the gearbox, which encourages oil flow out past the yoke. Does this sound plausible?
  12. There was a small amount of slip yoke left, maybe 1/2”, the diff is fixed and the gearbox will have I guess a small amount of movement but I can’t imagine it would move that much, so I think it’s fine. The driveshaft can only be removed as is going backwards unfortunately. A local racer is bringing over something called a u joint puller to see if the joints can be serviced in the tunnel. Not familiar with that tool but he seems to think so.
  13. Thanks @JohnCh. Engine is out, one of the axis on the knuckle on the driveshaft is seized up so now I know where the vibration was coming from. I guess it wasn’t greased from the factory. Is it possible to replace the u joints with the driveshaft in the tunnel? I really don’t want to have to take the whole rear apart to get the shaft out 😭.
  14. Thanks @MV8 and @IamScotticus. I,ve rotated it around and don’t see a grease zerk anywhere, but I’ll take another look when it comes out.
  15. I’m in the process of taking the engine out and noticed a label on the prop shaft that says to “ensure the unit is fully lubricated with a lithium based grease before use”. I didn’t do that on the original install, did I screw up or is this just a cya? Does anyone know how to fill it up? All I see are some spring clips on each joint.
  16. If it’s Motul 105778 that’s the LS version of 10577. 105778 is what Caterham racing people recommended at the time back in 2018 when I built my r20R and I haven’t had any chatter or other issues with it. Finding any Motul product is difficult for some reason right now. I’m also looking for it.
  17. You know you want to do the brake upgrade 🙂.
  18. If you go with the race rear brakes, I believe there’s no handbrake, does CA require one for road use?
  19. Thanks @d15b7, would be good to see some more 420Rs out there sometime. I was guessing the cold pressures, the hot pressures were 21-22psi, maybe they should be higher, don’t know but I’ll experiment some next time. I read message boards online about this and there didn’t seem to be a solid consensus.
  20. G forces are fun but not much use, there are too many variables like track temp, braking down or up a hill, camber. Momentum cars like ours the exit is more important than braking, figure out the perfect exit first, then work backwards.
  21. Thanks @Croc, we were in Group 3 for sprints and V for Enduro. The Ginetta has a 1.6l engine, weighs about 1250’. The cockpit is very small, the driver had to take his helmet off first before getting out, but it’s a beauty.
  22. After a rainy Thursday, the rest of the weekend turned sunny and mild at Road Atlanta and made for perfect racing conditions. My son David and 3 of his roommates came up from Auburn to help out. Friday Qualifying 1: Set the tires to 17psi. The track was still oily, it took 6 laps to warm the ZZRs up enough to get them switched on, finished P1 with a lap time of 1:38.965, but it looked like the tire pressures never got high enough. Saturday Qualifying 3: This was the money session, it was early morning, cold track, cold air, beautiful. Bumped the cold tires up to 18psi. Finished P2 with a 1:37.002 with a 1967 Ginetta G12 coming out of nowhere and killing it with a 1:35.7. It took 6 laps again to get the tires warmed up. Saturday Sprint Race 1: 360 Video here. Good start but briefly dropped to P3 before late braking at turn 1 and taking back P2. Just behind P4/5 got into each other at turn 1 and span out leaving the rest of the field behind to slow down, so by the time it got to turn 3 it was already just the 3 of us. The Ginetta was way too fast to bother with so it was between myself and the red Porsche #112 for the podium spots. Once again the tires were not very grippy cold and feathered the throttle in 5th gear from turn 3 all the way to 6. #112 passed me on the back straightway and I was very nervous braking in to 10a, so used engine braking a lot to slow down to make sure of tire damage. Things settled down then lap 6 the tires switched on and started reeling #112 in, eventually overtaking him coming out of 10b. The gap between us was 0.007 seconds at the line. Super fun race. Sunday BRM Endurance Race: This is a 1 hour race with a mandatory 5 minute pit stop which has to be taken before 40 minutes. The ZZRs were still in very good shape, Mintex rear pads still had 8mm left, we filled the tank to 15 gallons so we could pit early, though very heavy. Lined up 2nd row, the front cars (which were in a different class) took off and with a full tank could not keep up, barely running 1:39s, so settled into P3. We were hoping for an early double yellow so we could be one of the few with a large tank to pit, but it didn't happen. P1 and 2 pitted after lap 17 under green flag then with just minutes to go before the 40 minute limit was up the full course came out and we pitted right away. We only lost 1 lap during the 5 minute pit, so came out in P1. The race was then black flagged and finished a little early which is a shame not to enjoy the restart, but the boys were so happy to get the win. Sunday Sprint Race 2: The Ginetta was a scratch so this race was between me and the 112 car. We swapped for the lead half a dozen times before he had an engine issue and fell back to third place, a real shame as it was an exciting race. Fall Historics Wraps Up with Repeat and First Time Weekend Feature Race Winners at Michelin Raceway Road Atlanta – Historic Sportscar Racing (hsrrace.com) I have a set of A24s coming for the next race, hopefully they'll respond better for the sprint races. The Mintex pads are great for the rears, very little wear and balance is good. Road Atlanta curbs as very high and some have deep ribs, so it looks like I may have run over them too much and caused some drivetrain damage somewhere, but totally worth it!
  23. I’m planning on seeing if we can get a track day for sevens to get together in the spring next year. Once the track day people release their schedules next month I’ll make a list of possible dates and locations.
  24. Yes probably hopped over the curb at turn 3 at Road Atlanta a few too many times last weekend. I’ll add that to the list!
  25. The left and right driveshafts look a bit eccentric... https://youtube.com/shorts/hZJro1IIAIU?feature=share https://youtube.com/shorts/B1a8R7ZMDuo?feature=share ...but maybe spinning at lower RPM compared to the center driveshaft it's not that important, dunno, maybe that's normal. Center looks ok at low speeds anyways, not sure if this is of any use... https://youtube.com/shorts/bpUyGbaYsuU?feature=share Time for a complete disassembly!
