Everything posted by sf4018
Great video and driving skills! The Caterham ECU switches the fan on at 105C and off at 101C, it runs hot, so those temps seem within range.
My garage is super tight too so couldn't fit a fixed lift in it unfortunately, so I went with a portable Quick Jack system. As @locost7018 mentions a scissor lift is definitely a plan B solution but it does work, once the car is lifted you have to lower it on 3 or 4 jack stands and remove it to be able to work under the car. It's about a 10-15 minute process to get the car up and down.
6 speed transmission oil change: car level / oil volume
sf4018 replied to sltous's topic in General Tech
It's the same for the other fluids too, they never refill the same amount as the original fill. -
I just used the 3 holes that lined up, don't need the 4th there's virtually no load on the plate, unless it's an OCD trigger.
@KnifeySpoony is the car over rotating while trail braking?
What’s the wear like on the Mintex?
I've been going through this the last 2 years. Here are the pads in play so far... 1. Delphi 507CP Brake Pads Rear - Use with 4 pot front brakes (caterhamparts.co.uk) 2. AP Racing Rear Brake Pads - set of 4 (caterhamparts.co.uk) 3. Pagid RS U.1163.RS42. [U.1163.RS42]Pagid Brake Pad Set, Caterham Seven, Ford Escort... (bestbrakes.com) Delphi: Brake bias seems fine to me. It's supposed to line up with the uprated front brakes for what should be a decent brake bias. Wear is high for tracks with massive straight line braking zones (probably due to excessive temps). AP Racing: Brake bias is ok too, but wear is massive. Don't like them. They are cheaper than the Delphis so I guess you get what you pay for. Pagid: These are going on next, a real hail Mary. But they are massively expensive ($200+) so if they don't last 3+ times longer they'll be a non-starter too. Ferodo: My fading memory when I researched this was that either it doesn't exist in this form or it's the AP racing one, but I can't remember for sure. For this project though I'm coming to the conclusion that I have to either accept replacing the rear pads every 1 or 2 weekends or replace the whole rear brake system with a track rated one. I'm still holding out hope the Pagids will work out. My understanding is the track systems will not have the hand brake so will not be road legal, but I haven't researched that yet to confirm. Engine braking is quite high on this car, maybe try dropping gears earlier when you brake.
1. Repair the throttle pedal, which snapped in half at the weld at Sebring a few weeks ago. 2. Replace engine harness to get oil pressure feedback working again. 3. Install fuel pump control module. 4. See if there's a way to get the front brake pads out without having to disassemble the whole front end (the retaining pins are currently blocked by the fender arms). 5. Replace engine coolant antifreeze with water wetter type.
Nut keeps coming loose - any long term solutions?
sf4018 replied to KnifeySpoony's topic in General Tech
Suggestions above make sense but I'm curious why the bolt/nut is getting turned instead of the bushing to begin with...is there anything that could be causing the bushings to bind up? Maybe excessive lateral force, not seated against washers properly, etc... -
Caterham A Frames - check them as part of your annual maintenance
sf4018 replied to Croc's topic in General Tech
I found this on my computer, I think it's from the Caterham maintenance manual which you may already have, but here it is anyways... Caterham Service Schedule - Duratec (1).xlsx -
That seems like the lowest hanging fruit, hopefully that gets you enough of the way there.
Will do!
It was an inertia roller, can’t remember the brand, but it wasn’t fancy.
I got 204HP after 15% add on for drivetrain loss. It was tuned quite rich, focus was response and reliability rather than outright HP, so there’s no doubt more in there. 141HP does seem off.
Thanks Croc! Thanks Carl! Good luck with your project! -
A real test for the new A Frame... I'd always heard about Turn 1 and 17 but until you drive over it it's hard to comprehend how bumpy (but fantastic) this track is! -
Just to defend the honor of the A frame a little, the bent A frame I got last month came after a track weekend at COTA on slicks. I looked back at the video and I was getting 2g lateral force at really bumpy parts of the track, particularly some of the bad curbs. I raced a well sorted E46 a few weeks later there, the engine belt came off at the Esses the vibration is so harsh. -
Just for closure, it turned out to be a broken 12V (GO) wire in the engine loom somewhere near or at the oil pressure connector. The broken wire worked when the engine was not running (which made troubleshooting confusing) but with the engine running the vibration caused it to open and close, creating noise for the oil pressure sensor. I suspect my crappy dressing up of wiring in that area with the long pressure sensor cable combined with 130mph winds blowing it around was probably the cause. That area seems pretty exposed. I've ordered a new engine loom, hopefully the engine doesn't have to come out to swap it out.
Here’s the oil pressure feedback when powered by a portable battery… …it’s stable and the correct voltage level. Here’s the oil pressure feedback connected to the normal supply from the car… …it’s all over the place! The ground seems solid at the connector - it stayed close to 0v to chassis and 0 ohms. The 12V though seemed a little erratic between 12V and 14V. How solid is the 12V supposed to be?
The drawing I made is based off of that, it’s factory wiring still. I find it hard to read without drawing it up.
The drawing above shows 4 wires (12V supply, GND, Signal, 5V Ref). The sensor itself only has 3 wires - 12V, GND, Signal). The weird circular connector that connects the engine harness to the sensor pigtail has 4 wires on top, 3 wires on the bottom. What the heck is the 5V reference wire for? It seems the signal feedback is adding 5V, so instead of 2V (2.8 Bar) on idle it's showing 7V (off the scale)...
I’m pretty sure it’s an electrical wiring gremlin somewhere at this point. Here’s the electrical wiring for the oil pressure sensor… Not sure what the point of the 5V reference is, but the 5V, 12V and GND are testing ok. What I didn’t know until I researched the schematics is the feedback also goes to the ECU as well as the gauge (strangely via the tach), and also the unused connectors on the engine harness on the left side near the oil filter can be used to connect the oil pressure signal and a GND to something. The signal WN52 is reading 7-8V, which is not possible for a device that can only put out 5V, so there has to be a bad ground or something like that somewhere. Grrr.
It's the original Caterham oil pressure gauge, dunno what type.
The last track day the oil pressure suddenly maxed out while on track. So I got a manual oil gauge, plugged it in the engine and ran it, it was perfect. Engine is fine. I then got a new oil pressure sensor and harness and swapped them out. Ran the engine, it maxed out again. Not a sensor issue. I unplugged the oil pressure harness while running and the gauge froze in the position it was in (almost max). I’m stumped what the problem could be. Anyone have any inspiration?
