Everything posted by SENC
I don't recall, but if not you can get them from Chris Mintoft at Redline. He had a tonneau made for me that I'm very happy with.
I can attest to the seats from XtraSpecialSevens. The PO had Mick make entirely new seats for my Seven, they are superb.
111 max Db, 138 lbs. Not sure the power to weight ratio meets Lotus standards. Needs to add some lightness. Perhaps they should have done bookshelf speakers rather than floor speakers.
I prefer the traditional black hood, boot cover, and tonneau - but it's your car, you should do it exactly the way you want it!
I went back into the old se7ens listserv and simplesevens archives to see what I could find - no references to other cars from which this might have come. Caterham continued use of it for many years (though maybe in flat rather than bent) so I'm surprised they can't be found. Did you check with Chris Mintoft (Redline)? Arno Huberts in Amsterdam frequently has obscure old parts, worth checking (search for him or his parts page on FB). I did find this picture in the simplesevens archive..
@SevenAmerica?
I was chuckling about this, too. I got caught in a brief shower while driving in the WVa mountains last year. Both sides of the windshield were wet when I got back to the trailer at the hotel, but no evidence of a windshield leaks.
Agree with the recommendation on Tony Ingram. You might also reach out to Mike Ostrov - if you don't know Mike, he is the Elite guru but also quite knowledgeable about Sevens and all things Lotus in California. You can probably find contact information for him through Golden Gate Lotus Club - he's also fairly active on lotuselan.net.
Grabbed a couple pictures while st the shop... Handbrake from below - no obvious markings but may help you establish if yours might work. As you'll see (and someone noted previously), in the Seven the inner cable is anchored to the chassis and the outer sheath is what is moved back and forth. And my tachometer - correct for 1965 and positive earth, not sure whether it was different in earlier S2s.
I can't say for certain about earlier S2s, but that is different from the handbrake lever and mechanism on my 65. I only have this picture on my phone, which probably doesnt help you much, but will try to grab one today or tomorrow of the mechanism itself to see if it has any identifying numbers/markings.
Totally forgot to add when posting last night, but I suspect Redline will have what you need for the handbrake. I'm pretty sure I recall reading that Caterham continued with that brake design for a bit, thus my thinking parts are likely available. If not, it's not a terribly complicated design - essentially a cable levering the rear Triumph brake drums - and wouldn't be hard to figure out I think. Do you have the Tony Weale book? If not, order it pronto- it is a very useful reference and also helpful with identifying parts from other cars and when parts changes occurred
This might be useful - an extract from a Lucas parts reference book. Includes the wiper motor numbers which do appear available on ebay.
The amp, temp, and oil pressure gauges look right to me I can look for #s in mine if you'd like. I seem to recall a reference to the wiper motor and use in other vehicles somewhere - will scour my notes when I can.
DCOE2s are what the S2s that came with them had, and those numbers are close enough together they are likely a matching pair. Must have been picked up from another Seven by the PO? Great luck! EDIT - I found after rebuilding mine that a differently angled butterfly aided in getting the progression holes coming in as designed. I think all that is in my 65 S2 thread, but happy to go back to my notes if you need/want.
Would be a lot of hot air, but on the other hand might mitigate the low pressure in the cockpit problem that causes so much buffeting. Re: the steering wheel, if you want a period Lotus look without the crazy cost of an original, check out jacobengoneering.co.uk - their repro is excellent. Not cheap, but a LOT less than an original.
5-speed? Interesting, haven't seen one of those fitted but valuable for higher speed tracks or highway cruising I'd bet. If I'm not mistaken, that T9 doesn't have a remote for the gearbox, rather it is built into a modified tailstock. I'm thinking the remote is what caused the need for the rounded tunnel cover - or in Ian's case with the 105e box and adapter/raised remote perhaps a rounded cover still wasn't tall enough so the remote would be over the flat cover?
AHA! Makes sense. Seeing your following post of a Cosworth cam cover, though, if you're upgrading to that level you probably want to upgrade to the gearbox that goes with it. Should be the same tailshaft extension and bellhousing, just a different box and innards.
Your gearbox's difference from my Ford box piqued my interest enough to keep digging a little - I had not remembered that Lotus offered the 997cc 105e engine and gearbox, I thought for Ford engines it was just 109e and up (which used later gearboxes). At any rate, the Lotus7registry site even comments about an adaptor plate for the 105e gearbox... Available between January 1961 and early 1968 - 997cc. FORD 105E overhead valve engine with twin side-draughtH2 SU carburettors on Lotus manifold developing 39bhp at 5,000rpm. Compression ratio 8.9:1. Matching 4-speed gearbox using Triumph Herald remote and gearknob with special adaptor plate on most cars but a few 116E gearboxes with Ford GT remote and gearknob at the end of production. Standard ratios 4.118:1, 2.396:1, 1.412:1, 1:1. Reverse 5.404:1. Close ratios (Hobbs?) 2.917:1, 1.696:1, 1.280:1, 1:1. Reverse 3.83:1.
Ian - looking again at the picture of your gearbox, it looks like it may be a Ford Anglia 997 gearbox (105e) rather than the 113e/2321e gearboxes Ford used in the Cortinas, Corsairs and Lotus in Sevens and Elans. It may be that Lotus used this with early 105E engines, but I'm not sure. It may be worth checking the gear ratios to see if they are what you want. If the 105e box is shorter than the 113/2821 box (I'm not familiar with the former), that might also explain the custom mount.
Here is my mount (no pictures after cleanup, sorry), if it my help you. It looks like yours was modified to mount a different gearbox up and forward - may account for the rat-hole. If that is the case, I'd guess your propshaft would be longer, too?
Perhaps they were trying to run a retrofit remote above that flat cover?
