Everything posted by SENC
It suggests that your original setup, in at least one carb, was leaking - a very common complaint, thus the kit - and you've stopped that leak and improved performance. An alternative to the kit frequently used is to "lock" the choke mechanism, easily done with a small piece of coat hanger sized wire with a 90° bend inserted into the choke lever on the carb and the other end locked into the choke cable clamp on the carb. This method assumes the internal bits all fit seat properly and just ensured they remain closed, and is what I've done on mine. Unless you're in, and using the car, in really cold climates, the cold start mechanism is rarely needed. Two quick accel pedal pumps then a slow, halfway depress and hold while starting are all I've ever needed for the engine to catch.
I would be hesitant to think this a major contributor to any issue, given how the system works. That cam doesn't push the pump rod, rather it drops, allowing the pump rod to drop (according to its spring pressure). That spring pressure, along with rod length, accelerator pump jet orifice size, and condition of the (valve) bearings and weights (and their chambers) determines how much fuel is delivered and for how long (and whether there is any leakage). Also remember that if everything is in good condition and working correctly, this should be a 1-shot fuel "injection" and should only occur with a rapid push on the accelerator. Though the cam rotates and allows the pump rod to drop under slow acceleration (or anytime the throttle is open), the weights and ball bearings should prevent fuel flow to the AP jet at all times EXCEPT during rapid accel. In other words, any issues you may be trying to solve are, in my opinion, much more likely to be a result of issues with jet size, bearing seating, rod length or spring strength, or weights (I think some have replaced these with small springs). Thinking about how our engines work, could it also be that the tiny fraction of time difference in how each cam would allow the rod to drop is intentional - that one cylinder optimally needs that fuel fractionally later? You mention a difference in pump travel - I'm assuming you mean by that pump rod travel. Is that actually the case, or are you assuming based on the cam? With the throttle shafts held full open, are both pump rods fully seated (they should be)? If one is being held slightly open, indeed you might have an issue. But if the difference is only that one starts its travel slightly before the other - but the full travel is possible - I'd tend to discount it as a major issue. Again, remembering that the system, as a whole, should only operate on response to a quick throttle opening. You might also check the rods for each to see if their lengths are different (perhaps the carbs were already rebuilt previously from parts carbs and you really do have a mismatch).
I believe the switch from positive earth to negative earth occurred with the Series 3, so should have been neg earth in an S4. I'm away from my manuals at the moment, but will check later to see if I see any specific reference one way or the other. Re other parts, check the Library section - there may be a S4 parts list there that would be helpful. If not, I'm pretty sure there are some Lucas catalogs and crossreferences from that time.
Hagerty pricing went down for me this year, from $990 to $820. That covers my Seven, Elan, and 560SL - roughly $75k in total agreed value. I'm in NC.
SENC replied to savagete2860's topic in General Sevens Discussion
For awnings, check out Kammok. More expensive, but their's doesn't require poles and setup and takedown time is seconds. I have one on my LR3 and use it frequently because it is so easy/quick to use - whereas a traditional awning would only be used for long stops and times that absolutely demand it. Would be a great solution mounted on the back and/or side of a trailer. -
Yes it is. Pawleys Island is a great area, as is Wilmington.
Happy to offer guidance/assistance for the coastal areas of SC/NC - have lived in SE NC for a long time and spent a good deal of time with up and down the Carolina coast. They're not great areas for your Seven, though.
On a Maine road-trip for the next bit (sans 7, unfortunately) - but will explore the links when I can. I'd definitely like to do something like this - but struggling to prioritize it against other demands on my time (thus my likelihood of selling it on sometime this year).
Assuming you have the Standard 10 rear axle and brakes, the following link to a resource in the library here should be helpful. As Scotticus recommended, Ken Gray at Dave Bean may be a very helpful US resource. As may Ray at Rzd Enterprises. But if neither have what you need, Google around for Standard 10 resources in the UK - there is a Std 10 club that is quite useful. When I replaced mine a few years ago, new old stock was readily available - though I don't remember if through one of the above resources or through ebay. Also check Kelvedon, SJS, and TTR. If you have a different rear axle, you may need to find alternate resources.
I would double-check the specs and manual on your truck to see if there is a max tongue weight (in pounds) for the vehicle and/or hitch (without a wright-distributing hitch). Also check the rear axle weight limits GAWR). As loaded, you've moved a lot of weight off the front axle and onto the rear axle - which I suspect is why it feels sluggish to you - much reduced steering. I might be hesitant to get much above 55 with that much weight moved off the front axle, but you'll know by feel. As an example, my LR3 is rated for 7700 pounds towing capacity... but the hitch is only rated for 750 or 800. So if towing near the max I can only go to 10% tongue weight. At any rate, adjusting your load so that your tongue weight is closer to 10% may improve driveability. -
Maybe the #s you posted were before moving the car around a bit, but it looks to me like your tongue weight is 780lbs (3020-2240). As to the tie downs, the last picture shows the rear side dropping straight down to the swivel. I was always taught to "tuck" the straps down inside the outer circumference of the tire... ie., move that swivel roller a slot or two closer to the tire. I'm not certain my way is "right", but it does provide more strap-to-tire contact area and allows less movement. Do similarly with the anchor on the front side of the tire if you don't use the yellow ramps. Like Pethier, with 4 tires strapped I tend to engage the parking break and leave the car in neutral. I tighten my straps down quite tight, then make a point of stopping in the first 50 miles for a quick check of strap tension. -
One other thought - if you're having them put track on the floor, get them to put some (horizontally) around the walls, too - makes a good place to store straps and also gives a way to strap other things (furniture, etc.) you may periodically use the trailer to haul. -
Excellent, you'll enjoy the head room walking in it and using it for other purposes - the only real downside is fuel mileage. The axles in that trailer pic are well back, maybe a touch more than my 14' trailer, and the weight in our cars is well forward of the rear axle (much of it in the engine and forward half of the gearbox), so your experience of it needing to be fairly far back in the trailer isn't surprising to me. What I'd worry about is that you'll likely want to use the front of the trailer (and/or truck bed) for tools/spares/gas tanks, etc. - which will add to your starting tongue weight. Be sure to check your truck and hitch ratings - there should be a published maximum tongue weight in lbs. I once used my trailer to tow a Mercedes 560SL home - it just barely fit and I was right at the max capacity of my Land Rover, but I had to go a little below 10% tongue weight target in order to get tongue weight below the 750lb max rating of my factory hitch (a non-factory hitch would have lowered my rating to the 600lb range). Backing the Seven into the trailer may give you more flexibility in positioning (the engine should be closer to the trailer axles in that orientation, I think). I have similar straps (without the yellow chucks) - I don't think there is a hold-down problem using as you describe, BUT our cars are so low to the ground I'm not sure you'll have the clearance to work the ratchet anywhere but in front of and behind the vehicle. -
Funny, I've always thought the S2 must have been built for a range between Jim Clark-sized (I think he was in the 5'7" range, if I recall) and 5'11"ish. I'm between 6' and 6'1 and my legs just barely fit under the steering wheel with the seat bottom thin and on the deck and back flat against the frame. If the car weren't so much fun to drive, it would get real uncomfortable, real quick - but the fun factor makes 2-3 hours go by quickly. Ultimately I suspect its less about height and more about where you get your height - if your build is in the length of your legs you'll struggle, if your height comes more from your torso, probably good above 6'1".
Height is simple - you want the trailer to be level. Once you have a trailer, you just adjust the tongue jack until the trailer is level, then measure tongue height from the ground and compare with trailer receiver height. From that you can accurately calculate needed drop (or rise) in the hitch bar. There are a number of websites with pictures if you want to look up specific measurement points. You can get an adjustable hitch bar if you want or if you plan to use multiple trailers or multiple vehicles for towing. I have one in case I need to use my wife's SUV or tow a rental trailer, but 99% of the time use a simple bar with the right drop for my main vehicle and primary trailer. Tongue weight has nothing to do with height. You have a bit more margin of error if you go with a double axle trailer, but either way the general idea is to get the center of loaded mass ahead of the axle. How much ahead determines the tongue weight. The longer the trailer, the more ability you have to get it just right... if your vehicle just fits in/on the trailer you become more limited. If you have a tractor trailer weight station nearby (Google CAT scales and I'll bet you'll find one), I think the easiest way to get it right is to load the trailer getting the loaded vehicle weigh just ahead of the axle (ensure it isn't behind) as an initial approximation, then drive slowly and carefully to the weigh station. First you'll unhook the trailer and weigh just your tow vehicle (front axle on pad 1, rear axle on pad 2) - then hook the trailer back up and weigh again (front and rear axles as before... trailer on pad 3). You'll get valuable information to confirm you're under gvwr, and tongue weight is the difference between the two readings for your vehicle rear axle. Target tongue weight is 10-15% of total trailer weight, as long as that does not exceed the hitch or vehicle ratings for tongue weight. Assuming you're off, just move the loaded vehicle in the trailer to increase (or decrease) tongue weight and weigh again. You'll have it after a reiteration or two, then you can just mark the trailer floor to identify where wheels and tie-downs should be. If you're going to carry tools, spares, heavy items routinely - go ahead and get them in the trailer (or, preferably pickup bed) for the above procedure. -
Nice truck, I think you'll be very happy you picked up a truck with a towing capacity around 7k rather than the Maverick - will give you a lot more flexibility in what you tow (and comfort in towing enclosed/bigger trailers). Personally, I'd probably hold off on the weight-distributing until you make a trailer decision. Maybe even rent and or borrow some trailers to see how things feel on the standard hookup. In my experience, assuming you can get the weight within the trailer distributed well and not exceed the upper weight limit on the hitch itself), you may not need a weight distributing hitch until you get closer to your tow rating. -
I am contemplating selling this 1965 S2, and interested in any suggestions and recommendations fellow forum members may have. The short version is that I'm just not driving it enough - a combination of where I live (limited roadways suited for it) and personal priorities (it isn't exactly suited for toting my 2y-o lab retriever, who is with me nearly all the time now that I'm retired). I'd hoped/planned to make trips to the mountains or other suitable places once or twice a year, but despite having a suitable trailer haven't done it. As much as I hate the idea of selling it, I don't see my priorities changing in the next few years and this car needs to be used, not just stored. We're entering much better driving weather in my part of the world, so I plan to put some miles on it the next few weeks/months and confirm my intentions, but want to get some planning underway. I'm leaning towards BAT, but have never bought/sold on BAT so will be gathering information over the next few weeks to better understand that process. I'd appreciate any insights/experience you have - and also any alternate suggestions. Thanks in advance, Henry
Crazy how different it can be, presumably based on location/state rates? In NC, I pay less than $1k/year (and complain about that!) to Hagerty to cover 3 classic cars, combined agreed value of about $75k.
I think those resources are here in the library. If you can't find what you need there I'll look through my files.
I have a hard time wrapping my head around "exact ballpark". But I'd start by calling my agent and asking if SF offers an agreed value policy or even a stated value policy (and, if so, an explanation of how SF's defines the two and implications for settlement). You can also ask the agent if they can help determine approximate value under your current policy, but as that value is based not just on "value" but also depreciation (which is often subject to appraiser evaluation after an incident), I'd bet even if they could give you a ballpark it wouldnt be as exact as you want. Avoiding this ambiguity is the purpose of agreed value and stated value policies, which many insurers offer - I'd bet SF does, too.
The value is fluid, unless you select an "agreed value" type of policy where that value is set annually. The Hagerty policies I have on my 2 Lotus are agreed value, which amounts are stated in the policy documents. I also have elected their "cherished salvage", which gives me the guaranteed right to the vehicle should they deem it totalled.
Perpetuating the "all kit cars are dune buggies" myth?
Looking for bellhousing for twincam/crossflow
SENC replied to Healeyracer's topic in General Sevens Discussion
Just looked at that and remember the discussion. At the end, they're both conjecturing that the relieving may have been for a later model Escort that had a different sized ring gear. Also note that 2cams says the machining he's seen appears factory-done. Bottom line... 105e, 109e, and 120e will fit the gearbox and block... but of the 3, only the 105e can fit a clutch larger than 7.5". -
As for sources for the shifter, the best bets are probably Dave Bean (they may not have one, but Gary may have a lead for you) or checking with the Golden Gate Lotus Club and seeing if someone can ask if Mike Ostrov (Elite guru who also had a long history with Sevens) may have one. Or possible find a Cortina lever and cut it down.
