KnifeySpoony
  1. Did another slightly longer test drive. Pulling smoothly. However, after car got warm, the idle speed crept up to about 1800rpm. Checked the TPS idle voltage and it had predictably crept down to 4.55. I have ordered two more genuine Ford TPS units. Hopefully I can get one that is reliable...
  2. How are all the JDM cars getting reg'd in CA then?
  3. How much does that lump weigh?
  4. AFAIK the 420R (with it's dry sump) is not possible to have a "proper" PCV setup. I think you just need to have something in place that will pass inspection when you go to the BAR. Some of us had nothing and still passed...
  5. Tires delivered. Wowwwwww these feel soft sitting in the garage. Do these need a proper heat cycle for durability? These feel like I will use half the tread just driving to the track...
  6. There are no smog checks or inspections for bikes in CA. If the bike was 50 state legal at time of sale, then you have no issue. If not, then the bike needs a minimum of 7500miles on it to be able to import to CA.
  7. Do you need to smog late-model vehicles upon bringing them to CA? For new cars sold in CA, there is no smog checks for the first 8 years.
  8. Oh also his inside info suggests that either Avon motorsport tyres has a buyer, and/or that another tire manufacturer is going to make our 13" sizes. (185/215).
  9. I ordered a set of 333s. The guy at Roger Kraus seemed to think that they are faster than the A24 but wear better. Life should be somewhere in between the A24 and A64. He said they really need heat, so was worried a bit when I told him I drive to/from track. He told me to be careful lol. I guess I'll find out. Also, RIP my wheel bearings...
  10. Shifter is remedied by getting the knob to sit lower. The hole in the knob is pretty deep, just need to tap the threads a little deeper and screw it down more. Or just twist it hard and let the steel shaft tap its own way into the alu knob like i did. Solved the issue completely for me.
  11. I know the key is a monster. Chapman would is rolling over on that for sure.
  12. Hmm that doesn't look like adding lightness to me ...
  13. Looks like a nice design. I bet you could sell those...
  14. I reached out to Bruce Beachman for some advice - we went through all the usual suspects, but he was sure to impress upon me the importance of TPS idle voltage. Which, of course, was the first thing I checked, but I didn't realize that being off just a few hundredths of a volt could induce such behavior. Also the replacement TPS I put in had idle voltage that wandered a bit and had excessive hysteresis. I swapped back to the OEM TPS and at 4.62V seems to be OK again. Will give another report after proper test drive.
  15. How many days you think you will get out of them?
  16. Seen some threads on blatchat. Some people with similarish symptoms from throttle body imbalance. My throttle bodies are visually balanced at idle and wot, but haven't tested manometer. Worth doing?
  17. I actually have a spare ECU sitting here that I am going to flash and then swap in to see if it's an ECU issue. Hope to do that this weekend. Next step will be injector troubleshooting. Thinking about it, I can't help but think this issue is some sequelae or somehow related to a prior high RPM high load misfire I had previously, that was caused by a broken coil loom wire to coil on #4. Relatively soon after fixing that, this new misfire appeared. Perhaps that first problem caused some type of damage to the injector or ECU coil driver? Seems like an odd coincidence otherwise.
  18. I inquired with SBD and this is what they said: " We have been doing work for a Caterham Agent in the UK who specializes in all Caterhams and we have been commissioned by them to resolve issues on the Caterham 620R and 420R. Both these cars run digitally controlled fuel pumps and a strategy that was originally created for them by Caterham in our opinion is definitely not ideal. The fuel pump was never controlled correctly. This could be the issue you are having with your vehicle. Because the work was carried out for the Caterham Agent and paid for by them the ECUs and strategies have to be supplied by them. We can supply unlocked ECUs but we cannot supply the components and map strategies that are designed to overcome the shortcomings of the standard vehicles. So because of above, yes you could buy an unlocked ECU but it is unlikely to be your problem. The reason the 9A4 is having to be replaced is because some of the components within the ECU were discontinued at short notice and therefore MBE have brought forwards the 9M4 which was not going to go into production until 2024/25. This means MBE have had to condense two years worth of work into a few short months. They are nearing the end of the development and testing stage and we are hoping to receive the first batch of ECUs in the first week or so. The first batch is already sold, but the second batch should be only a few weeks behind. At this point we should have full stock of ECUs and there should be no delay issues at that time. Initially the 9M4 will work in the same way as far as the user is concerned as the original 9A4, but within a few months the strategies within the 9M4 will become more advanced and software upgrades to the existing 9A4 will stop. So having the new ECU is a much better option for the future. Best regards SBD"
  19. Sorry, can you translate for an electronics idiot - I don't know what B+ refers to. I assume you're saying the key needs to be in the on position to test for ground on ignition and coils?
  20. FYI resistance was check with ECU plugged in, kill switch on, but car's ignition/power off.
  21. So I'm still trying to diagnose my part throttle misfire. I went and checked continuity on various things - coils, injectors, sensors, etc. Using the continuity check on my multimeter everything was ok with a BEEP. However I realized that it will beep with anything less than 120ohms. So looking at the actual resistance, I noticed that all of the coil (and I think injector) grounds are consistent at 44ohms. Other various grounds were sub 1ohm. Is this normal?
  22. Any comment on difference between the 333 and the A24 compound? Is the 333 in between the A24 and A64 or is it even softer than the A24? This is what Avon says, which is a little vague, but suggests that the A24 is still softest. Medium Hard (A64) - A Circuit spec compound also ideal for track day or dry weather fast road use. Medium Soft (A24) - Ideal for sprint / hill climb use. Medium Soft - Extreme (333) - A thermally optimised compound specific for circuit use. Developed for no compromise maximum performance and reduced lap times.
  23. Yeah but then you have to change the diff all the time which is a massive ball-ache on these cars lol.
  24. I am trying to troubleshoot an apparent misfire, and apparently this can be caused by a bad coil driver in the ECU (a not uncommon issue it seems). Hoping I can borrow an ECU briefly to test. I have a 420R with roller barrels, but I can save your tune, swap to mine, then swap back using easimap. I am in Newark. EDIT - I have one in my possession thanks to a very generous forumite
  25. Roller barrels?
