IamScotticus
  1. You won't see me promoting products here much. I just think when Ford re-casts a vintage motor for the enthusiasts, and upgraded it, its a big deal. This is the first time I've seen them advertised https://www.pegasusautoracing.com/productdetails.asp?RecID=9127
  2. yep, thats purple people eater purple
  3. Of course you are interested! Does anyone know the oil flow rate of a Kent Crossflow with standard oil pump at various RPMs, 3K, 2K, etc? Or that of any engine if you know it. I just have never known if engines flow quarts per second or gallons per minute. I have no idea.
  4. Dave Bean has been in the Lotus game for a long time. Dave has left us, but Ken is a true Loti guru. http://davebean.com/
  5. PPF? Plastic Protective Film?
  6. Burton??? Pegasus and Dave Bean! What pan do you have? I have a "wedge" from Caterham. its even with the bellhousing bottom. Ive managed to hit it, drop the car on it going over a curb, etc. I have ruled out a dry sump unless its necessary because I'd rather be hitting the pan before hitting the bellhousing. Update: I have since changed my mind and am piecing a DS together as cheap as I can. Why? reduce foaming, improve cooling and aeration. All to feed the engine better oil.
  7. The CF looks right on that blue.
  8. I weighed my FIA, sans Petty strut, at 21 lbs
  9. Yea, I was concerned about the zinc. Thanks.
  10. Use a windscreen washer bottle. Pump the excess back at shutdown. Just guessing here, it probably couldn't handle the pressures either.
  11. I have decided to build my frame stands, basing the design after the Allstar 10625, but more over built. I the commonly available materials are Uni/Super strut channel tubing, and hole punched 1-1/8 & 1-1/4 square tube at Depot. The Unistrut I can bolt together but would have to hunt for the angle braces. The square hole punched tube will be welded and welder can fab the braces. The hole punched tube will slide together so I can have some telescoping. I'm not certain this punched tube is adequate??? What say the gallery?
  12. Yosa, welcome. we need to know what car you have to help.
  13. is Atlas a brand like Dana?
  14. Edumacate me.... the "English" axle is not the Escort, right? Definitely not the Morris Ital/Marina. What street cars got English axles? Is it the same as an Atlas axle?
  15. Thanks Bruce. I hadn't seen this.
  16. At the bottom, the cable anchor. I didn't install it, the shop that built up the car did. its not in the picture anymore because it worked loose and i cut it off recently since im removing everything soon. But I would definitely have it, or something to retain the cable. Another thing the shop did was zip tie the sparkplug boots to the distributor.
  17. don't forget to zip tie or safety wire that cable to its fixing, and the cable sleeve to the collet.
  18. Mines is mounted to the inboard screws, pointing inwards. There appear to be differences in bracket construction.. the collett may be either inside or out. position the collet so its centered.
  19. I know, it never left. But, in my opinion, the Seven rag was stuck in the grot trap after the L7C shake up, fall out and reorganizing. However, if you are able to read the March issue, don't miss it! LF is back in force with some amazing articles and photos in the March issue. "fallout"...did anyone catch that?
  20. On the Matt Lewis site, and possibly elsewhere, is a line of differentials, the BlackLine, which appear to be very similar to the QUAIFE torque biasing diffs. These run a few hundred cheaper than the Quaifes. Does anyone have experience with these? https://www.mattlewisracing.co.uk/product.php/2860/0/limited_slip_differential__triumph_herald_spitfire_tr7 https://vi.raptor.ebaydesc.com/ws/eBayISAPI.dll?ViewItemDescV4&item=233036752837&category=180406&pm=1&ds=0&t=1633017026000&ver=0&cspheader=1 The Quaife: https://shop.quaife.co.uk/shop/differentials/quaife-atb-differentials/qdf8k/ I am tempted to "uprate" my Ital axle with a Backline HLF080. I don't have any plans to track so Im wondering if the tradeoffs are reasonable?
  21. Has anyone found an adhesive backed vinyl covering, in red, to lay over the black Caterham instrument panel? I suppose I could order a Prisoner spare, or buy a second hand. That is a detail for later after we get running.
  22. Don't tighten fiberglass too much, or make the fastener holes too tight. GRP needs to float. When drilling new holes on GRP, finish edges with slight bevels on both sides. But spider cracks will happen all kinds of ways. Just accept that you (like I am now) that a paint job may be in the footure.
  23. I Love clams too but for sport, its better to see where the front wheel is tracking. I have also heard of the clam tips being forced down. I can't verify that. The Clams give the car that familiar MG TC look that complements the short boot as Lotus marketed the S2 as more of a road car, which carried over to the S4. This continued with Caterham well into the 80s until Cat introduced the cycles in fiberglass. I can't think of any Lotus 7 S2 or 3 that had factory cycle wings. Once Lotus was done banging out alloy noses and fenders of the 6 and S1 Seven, that was it. GRP was cheaper to make, required less skill set and didn't need painting. Also, as these parts tend to get damaged easily, GRP makes a lot more sense.
