7Westfield
Club Member-
Everything posted by 7Westfield
Agreed I dug out my tonneau a couple of weeks ago, and checked it's fit----or lack thereof mind you, this is 40 years old, and NEVER installed from the "roll" bar to the rear end, it was about 1.5" short I didn't even check it going forward I didn't check the top why bother? I'm making a new one to keep crap out when on the trailer
the cog setup Pegasus sells is for FF only 30 tooth crank pulley and 44 on the pump, and they don't have anything for the alternator I doubt if the pump does anything below 2000 rpm I have the Burton v-belt pulley on mine, and it's fine stock pump + alt pulleys Burton do have a cog setup that includes the alternator, but I don't know the ratios
fun fact about the mechanical fuel pumps on these if you remove the pump, be sure when re-installing that it sits square with the block before you tighten it down if one side doesn't go all the way down, try again it means the lever is not on the cam lobe, but off to the side DON'T use the nuts to pull it down bad things happen if you force it if the pump has a cast top section with the brass nipples in it, those must be replaced with threaded fittings--at least on the output side they have a habit of popping out and spraying fuel everywhere it happened on a friend's FF H*** of a mess when it lit off same for the inlet on a DGV SCCA mandated that YEARS ago
EDIT previous post only one spacer/cushion per bolt, as in SENC's photo you got 8, so you're good duh I welded a bung into the side of a 90 degree bend in my lower hose, but one of those splice things would do fine I can get a pic later if you want did it 30 years ago, so don't recall where bung came from, but it's an early VW Rabbit switch just have see what sensor will fit your particular bung that's the right fuel pump block
Pegasus doesn't have v-belt pulleys theirs are for cog belts, so you have to change both pulleys and then you have an alternator problem...........and they are a serious underdrive--to much for a street car on any of the Fords, pre or crossflow, the factory fuel pump spacer is mandatory--it positions the pump lever correctly on the cam, and insulates it
I think you're stuck with the single o-ring setup, since you have the grooves in the manifold Hopefully you got 8 of the grommet sets-use 2 on each bolt instructions with mine said tighten them so there's about a mm between the washers puller fans are better, in my experience mount it against the rad, and seal around the perimeter of the rad to the nose as well as you can a pusher fan turned around is not as effective as one designed to pull I have the fan switch in the lower hose, controlling the fan thru a relay with always hot power-fan runs maybe 5 minutes after shutdown if your sensor is in the engine, use switched power
I was referring to something I posted
the square bolt adjuster was on, among others, MGB rear drums also, early sprites (front) used a snail type adjuster between the piston and end of shoe I've never seen the type pictured here---any idea where they were borrowed?
posted in wrong thread
Oh yeah massive diff between springs, new ones are MUCH lighter it's actually usable now
Possible new series 2 owner, with lots of questions
7Westfield replied to randomDMZ's topic in General Sevens Discussion
Also remember that tha brazing on these was probably not done as we consider brazing over here It was done with an uncoated rod and a fluxor unit that puts the flux into the gas line The coated rods don't give the strength or nice appearance of that process -
well, the springs don't look like factory items the ends aren't finished as they should be, they look like they were cut down from longer ones I wonder if somebody put in stiffer ones to disable the system Also, they told me the Italian carbs use a lighter spring than later ones
OK just got a scale to check the pull around 5 pounds on each lever!!!! a couple of pounds on each piston no binding evident just talked to Pierce, best guess is massively wrong springs in the pistons, so a new set is on the way not the first FUBAR I've found in this set.....
front left corner probably behind the alternator bracket If you're ever over at Rich's, look at the motor in his Dulon
I've ordered a trigger scale, we'll see what that shows As little as it's needed, I might just do the delete option, but then I'd have to figure out what to do with the hole in the dash--maybe just an unused mystery switch
John is still there, but I've lost his number I'll get back to you edit google sez FB or 262-740-0180
Scott I've got it all hooked up correctly I'm just looking to reduce the effort to pull the knob, wondering if there is any reason not to remove that coil spring around the actuating lever Even with the start gizmo off the carb, it has a lot more spring pressure than I expected doesn't seem to be gummed up or anything, just a lot more spring than needed
The "choke" cable on my Westy takes way more force to pull than I like, even with a new cable. The issue seems to be the enrichment units themselves. I don't know how stiff the spring action on them should be, but these are stouter than I'd like, but no sign of binding, etc. Can I just remove that external coil spring? I've not tried yet because it looks like you have to cut them to remove, and not sold as replacement parts. You have to buy the whole block for stupid money. I took one off, and the pistons it raises seem to have a spring load of their own, so it seems removing the external one would be OK Very rare that I use it, but, if it's there I'd like it to work
Basically anything except Pertronix
if you'd rather have aluminum, I can mail you a handful https://www.speedwaymotors.com/Large-Head-3-16-Inch-Exploding-Rivets,42816.html?sku=910049-PLN remember---add lightness
WTB/B Spirfire rear hubs & parts
7Westfield replied to IamScotticus's topic in Parts For Sale / Wanted
also called Dykem Blue -
fuel pressure regulator? I found pics of similar units on Westfield forum
I wouldn't think it's a fire nozzle, with that hose barb on the side. My guess would be some sort of vent gizmo for the fuel tank
the sticker is WAY past it's certification date it would be bad to show up at an autocross and be denied wouldn't matter if it was in working order, without a current sticker it don't fly
just for grins, see if that company is still supporting that unit lots of those aqueous units are no longer serviced you might end up just removing it all without a gauge on it, how do you know?
