Everything posted by CBuff
I ordered the fuel gauge resistor mod beachman made 1-2 months ago. It shipped within a day or two and I received it a couple days later. I think @CatManDo was doing some work with them. Maybe he could offer some insights.
I like the child labor. Sorry I cant offer much technical expertise. But my 420R was just completed (factory built as I dont have the space). Happy to poke around and take any photos of how mine was put together (60% sure its correct).
Dremel with a polishing ball the "collars" where the axels comes out of the diff. Then coated in CRC. We will see how long it lasts. Will get more aggressive on the spots that were ground down on the diff housing and then paint those areas with POR 15 Top Coat.
Don’t have insights on fly wheel rust for operation. Since my car was new in June I have been tackling some surface rust issues. My coil cover bolts looked similar to your alternator. I replaced them. I am proactively doing some rust prevention on the underside. And the grot traps. Settled on crc. It leaves a yellowish film but seems to be well received https://a.co/d/irGFiMD also am going to paint portions of the diff. Seems like caterham grinds down the stock bmw diff housing in certain spots. But doesn’t paint them. Will grind it down and paint those areas with por 15 top coat. https://por15.com/products/top-coat?variant=39607017504935¤cy=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&utm_source=google&campaign_id=18079280352&ad_id=&utm_medium=cpc&utm_campaign=&utm_content=&utm_term=&gclid=Cj0KCQjw3vO3BhCqARIsAEWblcB-t0V5wM_DxR6_7323rBNvfo-ewPcDzFOalJJwbExk9oppEM9UUigaAjLdEALw_wcB&utm_term=&ad_group_name=&tw_source=google&tw_adid=&tw_campaign=18079280352&gad_source=1&gbraid=0AAAAAC-VAHXlmBFrXN2p_PmH8H_UWjqZF
A slight re-edit with some of the professional track photos added.
Push-button replacement for Dzus fasteners on Caterham nose.
CBuff replied to pethier's topic in General Tech
They used to be cadmium coated but I think the environmental folks didn’t like that. They also have zinc coated. these are more expensive but are powder coated (and black). I have not ordered from this place so no first hand experience. Not sure if ours are #5 or #6 https://dragracesolutions.com/black-butterfly-winged-head-fasteners-5-16-500-4pk/ -
I may eventually to a permanent change to the hardware. In the interim I got this which works well Bryke Racing Quarter Turn... https://www.amazon.com/dp/B00D954QJO?ref=ppx_pop_mob_ap_share -
@Croc thanks for this. Yet another amazing element from a great weekend.
I found this helpful
what is this crazy hot 68R (resistor?) under my dash? 2021 Caterham
CBuff replied to Austin David's topic in General Tech
Glad to know it doesn’t stay that hot when the engine is running. I had the accessory on and ignition off when I was trying to located the turning beeper. So it was hot for sure. Another mystery solved. -
I have that as well 2023 420r. Found it while trying to muffle my turn signal beeper. Reaching around back there and came across that one. Very hot for sure. sorry no insights on what it does. But can confirm I also have it. -
My 2023 Duratec was filled with motocraft yellow I believe. It is easily available. If you are doing a replacement / flush I think you’re pretty good with any of their products. It’s just mixing that can be tricky.
Not sure what year your sigma is. You could do a motocraft but just check about comparability. Some coolants don’t mix well with others. https://www.fcsdchemicalsandlubricants.com/quickref/coolantsEN.pdf
I am very biased. But love the green. Good luck. I can’t offer many insights as mine was factory built but happy to take pictures or measure anything on my car if you need. Mine is a 2022/2023 so it should be very similar.
I have been taking a deep dive into all this over the last year. I plan on eventually installing a msd solid state switch with addt fusing for a variety of things. but you can scale it up or down pretty easy. You can run a power lead to the master cut off so it will be cut off with mco. Also keeps the battery from having too many leads coming off of it. Make sure you fuse appropriately. if your not in a hurry we can run thru options when we meet up again. I also have a giant box of wiring , fuses, switches etc you can raid.
Maybe the clockwise running at the track. Ie more right turns than left. Heavier compression on the left side the car ????
So slight update. Fuel gauge mod has been working great. Inadvertently ran it all the way down to empty ( a needles width above R) at the USA 7 event this weekend. No issues but opted to fuel up at the track. Took 9.5 gallons (assuming it’s a 10.8 gal tank (SV)) with 1.5 gallons unreachable with the pickup. likely won’t push it that close in the future but very happy with the mod. Thanks again @BruceBe And @CatManDo
It’s on the wish list as an upgrade.
My first pass at throwing something together from the weekend. I took the liberty of poaching some photos and video that was posted up here. Please let me know if you have any issues with that or if you would rather not be in any of the video (I can re- edit). Thanks again to everyone for sharing the experience and being so gracious with your time and knowledge. I will likely make another version of this when some more photos and video becomes available. (and apologies for some of the footage quality - iPhones with no tele lenses makes it tough).
since @Croc gets dragged into any type of chat, reprimand or formal hearing for any attendees at the track event. He gets a chance to put a real name and face the online handle. (This group gets a solid C with its “adulting”) Thanks again Mike for everything!!
