CBuff
Everything posted by CBuff
  1. CBuff
    From the album: She has arrived!!
  2. There is an importer in Chaffee ny (where I just picked up my new 420r). If you were looking for a new one or one he might have on consignment you should talk to him. greg (at) timemachinesauto.com he has a few in his shop that you could look at. also check the cars for sale section. A weekly roundup of new and ongoing sales listings are there. This group is great if you have any specific questions to help guide your purchase. charlie
  3. 7 days prior cancelation. 7pm check in 3pm out I’m planning on getting it for Friday night only. Come up Friday night and leave Saturday after the track day. I think gates close at 10pm at night. Still have Vineland holiday inn as well. I’m going to see how work unfolds and maybe try and make it out thurs night and run Friday as well
  4. Death Grip and eyes closed is my default state.
  5. I have a room booked at Holiday Inn express in millville. I also reserved a room at the track over the covered pit lane garages. Never seen those rooms so not sure what that's like. But in theory I will only use one of them. Likely keep the other till just before and can pass it to someone in need. (Just friday night as I will likely head back on saturday night - ideally with the car if it isn't in the armco)
  6. I am signed up for Saturday already. Will see how the work schedule shakes out, and if still room avail add Friday. I am going to try and do one/some track days before that to get comfortable in the new car. Also want to make sure it passes Tech (which it should) prior to arriving for the event. @croc let me know if you have any days between now and Sept 7th. Would love to pick up any tips from the master.
  7. Sorry for the low res. John I will read the uploading instructions you all have thoughtfully laid out. here is a link to the Hi res https://www.dropbox.com/scl/fi/ijkq0biti9a81xmhrhbq5/IMG_4443.MOV?rlkey=p53spqh79407jwlxch4t6ayzu&dl=0
  8. My head is still spinning. IMG_4443.mov
  9. For sure. Let’s hope the weather is on our side.
  10. I was getting about 24 mpg cruising at 80 at slightly over 4000rpm. You certainly aren’t bored as you’re always looking out for what everyone else is doing. A self driving Cadillac this is not. But what fun is that.
  11. Thanks @Croc you were so helpful and generous with your time. I very much appreciate it. Can’t wait to see you and others out in the track. Lots to learn on that front. One of the items I preemptively addressed was the mirrors. In reading about the side mirror vibrations I got the dprs and had them installed on the windshield frame. Man they are tiny in person. But was happy to see they worked great and were very stable. Was a little surprised that my windshield mounted mirror did vibrate quite a bit. It wasn’t stuck on when I got there. Greg mentioned he preferred it mounted lower on the windshield to improve forward visibility. And while sitting in the car I agree. While it looked a little odd at first I do love that it’s not in my forward eyeline. I love seeing those front wheels dance around. It’s relatively easy to remove if an upgraded one might be more stable. Or maybe a stubby mount to the scuttle like the aero. I did get the aero screen so I do have that spa type central mirror for that. I’m not concerned a solution is out there for the vibration. But the dprs worked great. immediately pulled the full hood and put the soft bits half hood on in case of rain. Fit very well and is very high quality. I love it, although that went into the boot in short order and hasn’t been out but I feel better knowing it’s there. the brakes take some getting used to. My modern car brain needed to recalibrate for the firm peddle feel. Especially after some highway cruising (where I wouldn’t touch the brakes ) then come to an off ramp. The ice cold and new brakes and my soft pedal brain combined for a slight panic when you step on the brake and feel like they don’t work. But as they bed in a bit and my brain got smarter they certainly do work. And shockingly well. The 6 point harness was a welcome combination with those maneuvers. For such a long cruise I was happy with the comfort level. The leather seats were great. My left foot sat nicely under the clutch. My right foot I could shift around a little while on long stints. I do have to tweak my Speedo. After it showing 170 mph at idle speed Greg put in the pulse code for the zzs staggered setup (think it was 039440 It’s reading a little fast (60mph indicated is 50mph on the gps , 95mph indicated was 80mph). I will look into some alternate codes. But was also reading about the “measured mile” method that the speedo can learn the pulse codes when programming.
  12. All went better than expected. No breakdowns. Temp stayed at 90 solid (or it’s not working and stuck there). Brakes bedded in a bit. Its was a lot to get used to. I have spent the last two years roaming here and learned so much. And you read all about people’s experiences in a seven. But to finally get to do it all and drive across the state of NY on day one. I’m exhausted. i was weary of the highways from taking to some owners. I actually didn’t mind that much. But I likely would drive thru the gates of hell with a smile on my face today. I couldn’t even imagine such an engaging car. It’s was a great drive and day. I took a guess and figured if the fuel gauge read 1/4 it might be empty. Nope that’s half full. Fully empty (needle sitting on E). You have 3.8 gals left.(it’s an SV so 10.8 total I think. One of the benefits of multiple fuel stops. When it reads empty go get some gas. Problem solved. I added some dated belts, so there was a good amount of time spent getting them adjusted. Greg did all the work while I sat in the seat. The car preformed flawlessly. And I was pleasantly surprised how much easier a long trip was in a seven. Not easy but easier than expected. But that’s also what makes it great fun. A great day for sure.
  13. Well. 1 year 11months and 2 days since I put a deposit in for my 420R. Yesterday I road tripped to upstate New York to pick the car up. Drove it back today (keeping it in south west Connecticut for the moment ). Put 550 miles on the first day. Big thanks to Greg at Time Machines for dealing with my insanity for the last almost 2 years. I absolutely love the car. Looking forward to seeing you all on the roads and tracks moving forward. Charlie
  14. CBuff
    From the album: Pre-Arrival
  15. CBuff
    Pre-Arrival
    Here are some photos of the production and pre delivery of my 2023 420R.
  16. CBuff
  17. CBuff
  18. CBuff
  19. CBuff
  20. CBuff
  21. CBuff
  22. CBuff
  23. CBuff
  24. CBuff
  25. CBuff
