fastg
Everything posted by fastg
  1. For this time around the goal is 275 rwbhp on pump gas. I will still be using the DC 2.2 cams but they are the best option for the current rpm limit. I want to end in on the 325 rwbhp range. Graham
  2. Typical winter projects. 1. I am actually look inside my junkyard Honda engine, just replacing the head with a rebuilt unit. New inlet, injectors and throttle body, It should be the biggest HP increase so far:) Picked up a used K20A2 head for $150, currently off at 4Piston racing being rebuilt. The K20A2 has larger ports than the K24A2 stock head. 2. New shocks. from Procomp and big UK Locost racing shop. If they will ship to the US, might have to go thru a family member. My current setup is quite soft and I don't like the feel thru high speed corners. 3. Relocate the Tillet brake/clutch reservoir higher up the firewall, instead if being under the air inset pipe. 4. New electronic power cutoff, with a remote switch inside the car. So I don't dislocate me shoulder after getting strapped in and forgetting the switch the car on:) 5. Trim the dash to get better knee clearance. 6. Add padding to the roll cage.
  3. Welcome Greg. Great looking car. I have a locost and visit Pitrace a couple of times a year, great track. Graham
  4. On a Miata there is an engine ground bolt in the back of the block/head, I think it's on the exhaust side. Make sure you use it or you will have problems. I remember on the Turbo Miata list when people would install MegaSquirts and ground them to the chassis. It got to the point were the first question to people having issues was, where is your 'Squirt grounded? Talk to me again when it's grounded to the stock engine ground. Graham
  5. Would that be a purple Rotus? Maybe out of Dan's stable? Cool car. Graham
  6. Your details work and attention to details is amazing, so I have a suggestion for your plumbing system to take it to the next level. I don't use hose clamps. The only hose clamps in my far are for the air filter. If a connection will not get disassembled for maintenances I use Oetiker clamps, for the connection that will come apart during maintenance I use spring clamps. Why no hose clamps, they damage the hose, they look ugly, and the bare ends can really slice your hands when reaching into an engine. bay.
  7. You can never have to many tools:) Drag it across the surface to be cleaned, rather that push it. That will get most of the goop off, maybe a little push action for the hard to remove patches. Graham
  8. Most of the Japanese factory products are very good, I have used Hondabond with success. My favorite is the Toyota product especially designed for oil pans. https://smile.amazon.com/gp/product/B000EDDTV0/ref=ox_sc_act_title_1?smid=A32SNTCC2T0DPY&psc=1 A good carbide scraper names light work of any clean up. https://smile.amazon.com/gp/product/B01JBHZ890/ref=ewc_pr_img_2?smid=ATVPDKIKX0DER&psc=1 Graham
  9. I done many track days with many organizations over the years and have never seen the broom stick test even talked about let alone practically applied. Graham
  10. Do you have a lower radiator hose? That would be next on my list, that does look close. Graham
  11. I was thinking the same thing, I don't think Pectel is made in France. When you say nothing what does that imply, injectors firing, plugs. Is it ODB2 or have any diagnostics? Graham
  12. Front setup looks good, I see no reason to update, just rebuild. 7's do not need a lot of brakes and that is a Wilwood 2 piston caliper. As for the rears upgrade if you want to, but not necessary. If it was my car I would re-build the front and upgrade the rears to disks. Graham
  13. I like https://hpdejunkie.com/ as a search site. appears to have a lot more tracks and organization than https://www.motorsportreg.com Graham
  14. I would recommend this Red Line oils https://flyinmiata.com/products/redline-mtl-synthetic-gear-oil?_pos=4&_sid=869072710&_ss=r Graham
  15. I run RaceChrono on my phone in the Locost with an ODB2 and a Garman GPS receiver. The data it captures is amazing for the $19 outlay. But I have nothing to compare the data against. I generally review the data back at the hotel or when I get home, I do not chase lap times. With nothing to compare to I am a little confused. The data I find most useful is speed, lateral G and vertical G. So I start looking to braking, I want 1g braking in the hard braking spots. Then a decrease in vertical G with an increase in lateral G as I enter the corner, with the lateral G getting up to 1g cornering. That is easy to say but tough to do, but we are getting there is the slower corners. But on the faster corners say 60mph plus is it reasonable to still expect 1g cornering? Faster corners are one of my weak spots, but I am not sure what to aim for. Graham
  16. J1000, you sure have a project. Looks kinda complete, your typical Locost. You should probably join the Locost list at http://locostusa.com/ Graham
  17. Question about your trailer and using a winch. I though when using a weight activated pivoting trailer you had to drive onto the trailer in one motion. If your too slow the trailer will pivot as soon as the front wheels pass the pivot point, causing the trailer to slam into the bottom of the chassis. Maybe I am wrong? Graham
  18. It's all very subjective, I am 6'3" and used to own an MG Midget. Some people think a Miata is small, it's huge compared to a Midget. Graham
  19. You need to go to NJMP September 18/19. You will be able to try all the variation of for size. Graham
  20. You are right, you will probably end up with a better running car. I would guarantee that most DCOE setups are poorly jetted and tuned even worse. So I think you will be happy with the results. Graham
  21. My preparation is 3 days at Pitrace over the Labor Day weekend:) Graham
  22. I think the ban is not going to start until 2035, so we have a while. I think the battery landscape will be very different, maybe hydrogen fuel cells will be dominant. Time will tell. Graham
  23. Great news Roman, looking forward to having another Honda powered car. Graham
  24. Or do you have a local Harbor Freight https://www.harborfreight.com/bearing-separator-and-puller-set-62593.html Graham
  25. From the Locost list, nice looking car, nice price. https://www.locostusa.com/forums/viewtopic.php?f=40&t=23047
