carguy1315 Posted August 7, 2020 Posted August 7, 2020 (edited) Yellow Birkin S3 built in 1998, $25k obo, constantly updated, well sorted, easy to drive, RELIABLE, 2 liter Zetec, T9 5 speed transmission. Odometer now shows 64xx miles, it had 2164 when I took delivery on July 5th 2014. With slipping clutch (as described by previous owner), excessive rake and shocks set to maximum stiffness, I can see why nobody drove it much! With the clutch slave cylinder bled, rear shock pre-load and damping reduced it now rides comfortably and handles magnificently. Firmware update for ECU and tuning made the engine start instantly and run strong. Cold air intake brought more top end power and smoother running yet. Front facing intake rig now installed, rear facing rig included. Raceline water rail, Stewart Manufacturing electric water pump and controller, electric fan, East Coast Alternator 6 pound 2025 UltraMini 55 amp installed 2018. 2 Ford reprogrammed ECUs, 2 PCM and ignition modules included. Engine believed to be Series 3 because it has aluminum and steel sump, offset water pump, and horizontal oil filter. Fresh Ford plug wires, T9 standard ratio transmission flushed and fresh Redline gear lube 2020 Easily removable headlights with integral turn signals make aiming easier, includes new and used chrome buckets. Old style front turn signals and fender signals included. New, non-tinted windshield 2020 Spare windshield mounts could be used for a polycarbonate, shortened windshield. Wide track front end, installed Spring of 2019, has all new A-arms, ball joints, stub axles, steering arms, brake rotors and 4 piston Wilwood calipers, Wilwood .75” brake master cylinders, fender stays, working fenders and new front fenders. The new front end is quick and easy to align (street and track alignments now practical) and improves handling with 2” wider track than original. Jaz 15 position, single adjustable coil over shocks, corner weighted for 190 lb driver and half tank of gas. 15lb Braille battery 2 quart Accusump with electric pressure sensing valve, braided line in passenger compartment, aluminum rack mount for easy installation and removal in passenger seat area. Shortened fiberglass seats, reinforced driver's seat, OEM upholstered and light weight aluminum rear interior panels, 3 point belts installed, 5 or 6 point driver belts included, Hella battery cut off switch. Heater/fan unit, all interior panels, carpet, insulation, seat adjusting rails, and OEM external mirrors are included. Mini 7 four panel wink mirror with left and right side blind spot mirrors mitigates need for external mirrors Shown with 4 silver Enkei RPF1 wheels with 2015 195-50-15 Dunlop Direzza Sport ZII Star Spec tires. 2019 Bridgestone 195-50-15 RE71R tires on Black Enkei RPF1s with Black 948 Racing wheels (slightly wider front and rear track) Rear track variable from 52-56” (63" edge to edge) with included spacers and wheel selection. Quaife limited slip installed spring of 2017. Tall (broomstick test) 5 point track day roll bar has removable SFI padded Petty bar. The bikini top and doors work with both roll bars. Tonneau cover works with street and track roll bars sans Petty bar. For track events, I mount the Accusump rack where the passenger seat goes. OEM top works with the OEM roll bar now installed. All weather gear in excellent condition. Caterham clear and Birkin tinted wind wings. OEM 11 gallon tank. 3 piece trunk liner allows easy removal for changing roll bars, damper adjustment, rear axle maintenance. Driveshaft safety hoops. braided stainless DOT approved brake lines, braided fuel and oil pressure gauge and Accusump lines. Lightweight stainless steel Magnaflow side exit muffler (clears chassis dyno, saves 6 lbs.) and quieter, stock rear exit stainless steel muffler, heat shield and pipes. Lightweight fiberglass boot cover, spare tire rack, license plate light, some special tools, spare clutch, oil cooler included. Maintenance notes, Birkin build manual, Escort 4000pg factory pdf, T9 transmission manual, note book setup notes, measurements, Zetec and other info, bracket and panel templates, prototype rear compartment bottom panel. Edited March 1, 2021 by slngsht added info, added new pix
Mondo Posted August 9, 2020 Posted August 9, 2020 Looks very nice and well sorted! Good luck with the sale.
sltous Posted September 5, 2020 Posted September 5, 2020 I went to take a test drive of this car about a week ago and I wanted to pass on my notes. TLDR: Great car, if I was a Colorado resident I probably would have bought it but titling in California in the time of Covid is tricky and I have a fun car to tide me over. Background/comparisons: I was interested in this car to replace my Locost with a 1600 xflow. The chassis in my car is running out of reasonable upgradeability and jumping to a new chassis before any more power or handling upgrades make much sense. I’ve also taken rides in a Superlite R400 and a 1700 xflow although I have not driven either. Power: The car has tons of power that is accessible over a wide RPM band, I was held back by road limits from ever getting out of 3rd gear but it was smooth and quick to rev up at all times. Comfort/handling: Much more comfortable ride than either my Locost or the R400. Personally I like the stiffer ride and sparser cockpit but it was nice to not have my organs bouncing around too much. The seats had tons of side - to - side support and at 5’9 the car was plenty big enough. I really enjoyed the clear view of the driver’s side front wheel and I knew exactly where the car was at all times. Both my Locost and the R400 have aeroscreens which I really like, but the wind deflectors on the windscreen really helped make the airflow more comfortable. In the 1700 xflow I've been in without wind deflectors the airflow could whip around the windscreen and apply uncomfortable pressure to the outside ear, which was not the case here. Seller made it clear that it would be easy to tighten up the shocks for track use or if you prefer a little stiffer of a ride. The exhaust makes it nice and warm without requiring a heater, but was never uncomfortably hot. The braking was much stiffer than I am used to, because I’m a bit shorter than the seller I was using a foam block to be in a comfortable sitting position and I couldn’t easily apply as much force as I would have preferred, but it’s reasonably straightforward to adjust the pedal box or potentially move the seat forward. Previously the seat was on adjustable rails but it is in a fixed position now. Fit/finish/accessibility: The car is in great shape, sensible upgrades have been made, using existing mounting holes wherever possible. Seller showed some track upgrades that come with the car that I was especially interested in as I have not been confident to take my Locost to the track and I would like to, but I don’t know enough about them to evaluate. It is much easier to get to components in the car to do repairs or upgrades, the Locost I drive has a one-piece fiberglass body and a removable bonnet but access is terrible outside of the engine bay. This car has removable body panels with access to the engine area, area behind the dashboard, sub-trunk area, etc.
carguy1315 Posted September 12, 2020 Author Posted September 12, 2020 Not yet Sent from my iPhone using Tapatalk
carguy1315 Posted September 13, 2020 Author Posted September 13, 2020 Try to PM me, I think that works. Or accept PMs to you. Everything listed is included, might be a few more things, everything I’ve collected for this car goes with it. Sent from my iPhone using Tapatalk
Tempesto Posted September 13, 2020 Posted September 13, 2020 carguy1315 said: Try to PM me, I think that works. Or accept PMs to you. Everything listed is included, might be a few more things, everything I’ve collected for this car goes with it. Sent from my iPhone using Tapatalk For some reason I don't have the option to PM I understand, I'm trying to figure out how to get everything else to Florida, the car is easy.
carguy1315 Posted September 13, 2020 Author Posted September 13, 2020 My email is: carguy1315@gmail.com Sent from my iPhone using Tapatalk
spitfun Posted October 10, 2020 Posted October 10, 2020 I was wondering if this is still available? Thanks Rich
carguy1315 Posted October 14, 2020 Author Posted October 14, 2020 Yes, it is still available for the right person/ home. Sent from my iPhone using Tapatalk
Djplaster Posted December 21, 2020 Posted December 21, 2020 I am happy to say I am the new owner of this Birkin as it is on a truck headed to Massachusetts. The car was exactly as the owner Jim described it and isvery well sorted. Jim was very accommodating and pleasure to deal with.
mrmustang Posted December 21, 2020 Posted December 21, 2020 Djplaster said: I am happy to say I am the new owner of this Birkin as it is on a truck headed to Massachusetts. The car was exactly as the owner Jim described it and isvery well sorted. Jim was very accommodating and pleasure to deal with. Congratulations, it's a really nice car and Jim did a great job of sorting it out. Enjoy the ride. Bill S.
Vovchandr Posted December 21, 2020 Posted December 21, 2020 Welcome fellow Zetecer to NE. You have an identical Zetec model with VCT like mine. I believe Cougar was the source for these. East or West MA?
Kitcat Posted December 21, 2020 Posted December 21, 2020 (edited) As yet another Zetec powered se7en owner, welcome. I just had mine tuned and it made 152 hp, 140 lbs torque at the rear wheels on a "conservative" chassis dyno. Relatively flat curves as well. It feels very fast, even though it is not as powerful as current Duratec powered se7ens. Mine is the SVT version, which I believe was only made from 2002-2004. So likely yours is the earlier version which could make similar power with various mods. It will be a challenge for you to match the prior owner's accumulation of 60+K miles. What a die hard. Higher mileage se7ens always seem to have fewer problems as they are so well sorted. Enjoy your new ride! Edited December 21, 2020 by Kitcat
BlueBDA Posted December 21, 2020 Posted December 21, 2020 I am curious also - where are you located Djplaster? Vovchandr said: Welcome fellow Zetecer to NE. You have an identical Zetec model with VCT like mine. I believe Cougar was the source for these. East or West MA?
Djplaster Posted December 21, 2020 Posted December 21, 2020 I am in Needham which is eastern MA. I did travel to test drive it and found power to be excellent yet very drivable. BTW the car has 6800 miles not 60k. Looking forward to the spring when I can drive it. Glad to Seven owner.
Vovchandr Posted December 21, 2020 Posted December 21, 2020 Djplaster said: I am in Needham which is eastern MA. I did travel to test drive it and found power to be excellent yet very drivable. BTW the car has 6800 miles not 60k. Looking forward to the spring when I can drive it. Glad to Seven owner. We are 2.5 hours apart. With more and more active NE owners and pending pandemic resolution I'd look forward to some kind of meet, cruise or joining others in an bigger event.
