I'm busy getting my engine back in my car and I went to refill my T9.  Everything I've seen says it should take 1.9L of oil but I started to get oil out of the side plug hole after about 1.25L.  Should I worry, or just get on with it?
I was able to add ~1.6L of rated 1.9L into my 6 speed and several members let me know there was likely to be significant oil in various parts of the transmission.  How did you drain your transmission oil?  I think I would re-fit and check fluid level a second time with the engine / transmission in place.
According to Chris at BGH, 1.25l is plenty. Ford varied the amount over model years as they were striving to claim it would never need to be serviced. Hence, no drain plug. If you rebuild it, you can drill and tap the bottom of the aluminum spacer plate between the main case and the tail shaft for one. At the same time, weld a threaded bung at the right front of the top cover. This can serve as a fill port. Once you fill it, rotate the gears a bit and let it set a while. Then you can insert a dipstick in that port, mark the level and you will always be able to ease your mind regarding quantity.
Wow, turns out I don't spell very well when I'm multitasking.  Sorry about that.
The transmission dumped most of it's oil out of the tailshaft when I pulled the motor and I sucked out everything I could get while it was on the bench.  I guess once it's back together I'll drive around a little bit and see if it will take a little more, not a big deal to top it off.
  • inchoate changed the title to Quick T9 transmission question
I would set it up on some blocking nose down to allow any excess oil to drain into the main case before reinstalling it. Then, when you add new oil, you will have a better idea of quantity. A certain amount does migrate back to the fifth gear cluster in the tail housing but there is a drainage path back to the main case.
Good call.  The car is on blocks at the moment and it will get it's nose raised when I fill the coolant system.  No big deal to bring the back end up for a little bit as well.
I went to a VDO GPS driven speedometer. When I rebuilt the transmission, I removed the speedometer gear and plugged the holes. In the photo above, you see that the boss in which the fill plug is located is elongated. in some of the cases, depending on model year, they drilled the hole higher for more quantity.
The later T9 models all had the filler plug lower, also the Tracksport aluminium case has it at the lower location. I think 1.25L is just about right.
