Vovchandr Posted June 17, 2023 Posted June 17, 2023 (edited) Is... Peculiar Edited June 17, 2023 by Vovchandr
panamericano Posted June 17, 2023 Posted June 17, 2023 The drivers look even worse than the poor car. Chapman was smarter than a computer! 1
wdb Posted June 17, 2023 Posted June 17, 2023 I like the style of the second one from the top, looks like a channeled Ford Model A or B. However the windshield is on the wrong side and it looks like the steering wheel is in the center? Hopefully AI will always remain so easy to spot...
Vovchandr Posted June 17, 2023 Author Posted June 17, 2023 (edited) 25 minutes ago, wdb said: I like the style of the second one from the top, looks like a channeled Ford Model A or B. However the windshield is on the wrong side and it looks like the steering wheel is in the center? Hopefully AI will always remain so easy to spot... This was a quick one off rendition or parameters with me messing with Bing. Here is an alternative run through another generator. Each can be fine tuned in obvious areas of errors to make look better Edited June 17, 2023 by Vovchandr
Vovchandr Posted November 16, 2023 Author Posted November 16, 2023 AI turned my track day photo into different interpretations 1
Vovchandr Posted November 16, 2023 Author Posted November 16, 2023 (edited) Also these Edited November 16, 2023 by Vovchandr
TEM Posted November 21, 2023 Posted November 21, 2023 What software are you using to generate these AI images? And are you using text, image or a combination?
