I see you practiced restraint when choosing the engine -- that turbo looks bigger than my steering wheel!  :)  What are the specs?
Cheers,
John
Cheers,
John
The turbo is a BorgWarner
S300
SR20DET CP 8.5 pistons, Eagle rods, Mild porting, Electromotive Tech GT stand alone, 74 lb injectors, Gretty intake, SR20DE cams.
Well that should be QUITE the interesting ride!!!
Traction control??  :)
Nicely put together.
Back story?
Looks like dwarf car inspired ifs and custom spindles with a standard racing cross flow radiator (22x19 originally?) turned vertical, cut and shut.
Mustang axle stubs. Wilwood 2500 lb front brake kit. Dwarf car wilwood rear brakes. Full midget 2 pass radiator. Custom intercooler. 1131 lb with 8 gallons of gas.
  • Thanks 2
9 hours ago, Bob Drye said:
I'm 76 and have Parkinson's so this is my latest handicap vehicle.
@Bob Drye HI Bob.  Good to see you are still alive and kicking.   I met you at Carlisle in 2009 when a group of the USA7s folk got together.  At least I think I met you because I have photos of your Locost parked a few spots along from my Caterham.
Other photos from that event which I have handy on this computer:
