Chris D Posted February 2, 2024 Posted February 2, 2024 Converting a TC with a dry sump to a wet sump system. I have a nice VC with NO top oil fill provision Anyone have a stock one to buy or swap? Also need: a lightened flywheel for a STANDARD 8 1/2" diaphragm clutch - 6 bolt A stock Elan/Cortina/ Kent oil pan - baffled would be great Oil strainer and pick up pipe - inserts in the bottom of the block Thanks, Chris D Rochester NY
wdb Posted February 2, 2024 Posted February 2, 2024 Oil pickup is available new, I believe I saw it at one of the English sites. There is also a pressure relief pipe (I think that's what it is); it can probably be recreated with steel brake line. Here's a picture of mine.
toldfield Posted February 3, 2024 Posted February 3, 2024 I got my lightweight flywheel from Dave Bean. I think I got the oil pickup and strainer there too. davebean.com tom
IamScotticus Posted February 3, 2024 Posted February 3, 2024 https://m.facebook.com/groups/680123115377846/ https://m.facebook.com/groups/341703863245260/ dangerous territory, but there are some honest people. Have the seller send you a picture of the items with a unique identifier you specify.
MV8 Posted February 4, 2024 Posted February 4, 2024 (edited) I've not seen a VC for this engine that was smooth on top (no ribs) before. Maybe it was machined to add lightness. You may need to mill for the standard, three ear oil fill cap or fill via a bolt-on, engine mounted breather canister (if there is no material inside to aid oil-air separation). A new steel pan and pickup could be made that addresses potential problems with ground clearance and armor at the front and bottom plus add baffling, a scraper flange, and trap doors around the pickup. Rail flanges can be cnc cut and provide a convenient straight edge for the sides. The tube for the oil relief valve helps to reduce oil air entrainment (whenever the valve happens to bypass). The pickup does not need to be spring loaded or have screened area up the sides which can pickup air. Edited February 4, 2024 by MV8
s2europa Posted February 7, 2024 Posted February 7, 2024 That is a standard cam cover (other than the mods). There were three different cam covers. The early one with "Lotus" down the sides, this one (middle years) with Lotus over the chain cover, and later, the big valve cam cover that is ribbed down the sides and says "Lotus Big Valve" on the chain cover. 3
Marek Posted February 29, 2024 Posted February 29, 2024 @Chris D Spares from my long gone Europa TC. Let me know what you need. You might have my email/number, or Dan G. can give it to you. 1
Chris D Posted March 3, 2024 Author Posted March 3, 2024 Mark - tried to contact you but there has been no response to your 1990's email or phone number... Chris D 585 330 5456
SENC Posted March 4, 2024 Posted March 4, 2024 Don't forget that sumps, pickups, and, of course, flywheels differ between early "4-bolt" and later "6-bolt" engine blocks - I didn't notice mention of which you have.
Chris D Posted March 10, 2024 Author Posted March 10, 2024 I'd prefer a 6 bolt but can machine a good 4. There's got to be some out there... same with the lower oil pick up parts. Leads appreciated. Thanks Chris D
SENC Posted March 12, 2024 Posted March 12, 2024 6 bolt sumps are damned hard to find. I grabbed some photos of one I picked up a while back as a backup for my Elan. I need to find my records for when I bought it, but someone went to a lot of trouble to fabricate a nice baffle system and pickup. If memory serves correctly, I think I remember being told this is one Col Croucher (elantrikbits) made up. At any rate, I actually got another one as part of a parts buy (no pickup and I still need to refurbish it a bit), so I could probably be talked into letting this one go to help get a Seven on the road. If you don't turn one up and are interested in this one, let me know and I'll try to find records to see what I have in it.
7Westfield Posted April 3, 2024 Posted April 3, 2024 if you still need a pan, someone just put 4 on feebay https://www.ebay.com/itm/156150141194?_trkparms=amclksrc%3DITM%26aid%3D777008%26algo%3DPERSONAL.TOPIC%26ao%3D1%26asc%3D20230811123856%26meid%3D08e41b736dc14195aa79a1fd4b12a83a%26pid%3D101770%26rk%3D1%26rkt%3D1%26itm%3D156150141194%26pmt%3D0%26noa%3D1%26pg%3D4375194%26algv%3DRecentlyViewedItemsV2%26brand%3DFord&_trksid=p4375194.c101770.m146925&_trkparms=parentrq%3Aa46c249218e0acf2598bafc3ffff3774|pageci%3Ad3ea1363-f1c8-11ee-9344-72e3c74276a3|iid%3A1|vlpname%3Avlp_homepage
IamScotticus Posted April 5, 2024 Posted April 5, 2024 Did the rope seal end with the 4 bolt flywheel?
