captain pabst Posted September 9, 2024 Posted September 9, 2024 (edited) Just delivered this Morning before the driver headed up a little north to drop off another. edit: oops put this in the wrong spot. missed the dedicated build threads. Mods either delete or move please. Edited September 9, 2024 by captain pabst note about being in wrong location
JohnCh Posted September 9, 2024 Posted September 9, 2024 2 hours ago, captain pabst said: Just delivered this Morning before the driver headed up a little north to drop off another. edit: oops put this in the wrong spot. missed the dedicated build threads. Mods either delete or move please. Done. Congrats on the arrival! What options did you add other than the stripe and weather gear?
captain pabst Posted September 9, 2024 Author Posted September 9, 2024 34 minutes ago, JohnCh said: Done. Congrats on the arrival! What options did you add other than the stripe and weather gear? Thanks! its Series V with lowered floors Heat! Carbon seats 4 piston brakes track day cage shift lights map pockets
JohnCh Posted September 9, 2024 Posted September 9, 2024 If you optioned the cage, then there is no point in asking if you plan to track it
Croc Posted September 10, 2024 Posted September 10, 2024 4 hours ago, JohnCh said: If you optioned the cage, then there is no point in asking if you plan to track it oh hello! What’s your local track @captain pabst ? Congratulations on Christmas arriving early!
Legs Posted September 10, 2024 Posted September 10, 2024 I'm the guy from 'a little up north'! 😆 Congratulations! Thanks for doing the crate unboxing and removal first, the driver knew exactly what needed to happen and we were offloaded in 30 minutes! 1
slowdude Posted September 10, 2024 Posted September 10, 2024 Congrats! Might as well put that other car in your garage up for sale. 😉 Great color and looking forward to the build!
captain pabst Posted September 10, 2024 Author Posted September 10, 2024 (edited) 12 hours ago, Croc said: oh hello! What’s your local track @captain pabst ? Congratulations on Christmas arriving early! Summit, I haven't been this year but look forward to the build on this and going from there. 12 hours ago, Legs said: I'm the guy from 'a little up north'! 😆 Congratulations! Thanks for doing the crate unboxing and removal first, the driver knew exactly what needed to happen and we were offloaded in 30 minutes! Glad you guys got it unloaded so quick. I got about 5 minutes notice before he showed up so I was extremely short handed. Edited September 10, 2024 by captain pabst
captain pabst Posted September 12, 2024 Author Posted September 12, 2024 On 9/9/2024 at 4:05 PM, JohnCh said: If you optioned the cage, then there is no point in asking if you plan to track it Optioned but not included at all. I have quite a few missing things, including a missing pick list which could explain a lot, but makes reconciling what is and isn't there even harder. 1
captain pabst Posted September 16, 2024 Author Posted September 16, 2024 I've made some progress, Front suspension is on. We put the wheels on for fun ( I have a 5 year old ) I did the suspension while everything was very low to the ground and put it on jack stands after. Engine and Tranny are ready to be bolted together. Seats are just placed in the interior. Having a lot of fun so far ( even amongst the looking for the correct hardware for each step)
CBuff Posted September 16, 2024 Posted September 16, 2024 I am very biased. But love the green. Good luck. I can’t offer many insights as mine was factory built but happy to take pictures or measure anything on my car if you need. Mine is a 2022/2023 so it should be very similar.
captain pabst Posted September 27, 2024 Author Posted September 27, 2024 (edited) So one thing I find to be daunting is the drilling of the steering wheel. I have come up with the following 3d model that should take some of the guess work out of it. Feel free to use it as you please. The hole at the center is 2mm and I used a small drill bit here to center on the divot in the back of the wheel. The holes for the drill bit are modeled as 6mm. I measured my bolts as 5.8mm This is designed around the felt wheel. The thinking being there is a pointer at 12 o'clock and then a flat on the bottom to align with the text of the wheel (assuming it is square). the gold is from my kid and the paint pens... steeringdrill11mmextension.stl Edited September 27, 2024 by captain pabst 1
captain pabst Posted October 8, 2024 Author Posted October 8, 2024 Engine is waiting some free time to be dropped in.
captain pabst Posted October 9, 2024 Author Posted October 9, 2024 Engine went in. Amazing how little space there is in the transmission tunnel. I wish I leveled everything better before starting. Took a little over an hour.
JohnCh Posted October 9, 2024 Posted October 9, 2024 Yes, that transmission tunnel is tight. Given production tolerances, some transmissions rest against the side of the tunnel requiring extra effort to create a gap. Any updates from Caterham on your missing roll cage?
captain pabst Posted October 9, 2024 Author Posted October 9, 2024 1 hour ago, JohnCh said: Any updates from Caterham on your missing roll cage? My missing parts including roll cage and pick list are en route. I hope it has everything. Seeing some other threads where there was 1 missing radiator mount and I have the same issue. Probably best to be the lowest number in a group of cars coming over instead of the highest like mine was. 1
pethier Posted February 19, 2025 Posted February 19, 2025 On 9/10/2024 at 7:31 AM, captain pabst said: Summit, I haven't been this year but look forward to the build on this and going from there. Have you driven the Shenandoah Circuit?
captain pabst Posted March 10, 2025 Author Posted March 10, 2025 On 2/18/2025 at 7:21 PM, pethier said: Have you driven the Shenandoah Circuit? Indeed, I have driven all of the tracks at Summit, but not every layout. Only been on track there with a Porsche GT4.
pethier Posted March 11, 2025 Posted March 11, 2025 6 hours ago, captain pabst said: Indeed, I have driven all of the tracks at Summit, but not every layout. Only been on track there with a Porsche GT4. I drove the Shenandoah Circuit at the LOG30 track day in 2010. My Elise was stock at that time. I had just sold my first Caterham off to Cape Cod. The Caracciola Karussell is a hoot. When I was there the concrete was nice and smooth. I hope it's holding up well.
captain pabst Posted March 29, 2025 Author Posted March 29, 2025 Anyone Know about de-pining the Body side of the Engine harness? I've got a no start and it appears the culprit is in this connecter. Pin numbers are for reference and probably not the actual connector because I'm not sure of the numbering on this connector. But It goes Red-5 White-6 black-7 on the engine side and then on the body harness it goes to White-5 Red-6 Black-7 (Red and White have switched positions). Leading to Crank Signal being at ECU pin 7 instead of 12 (which is supposed to be a power ground), and Crank Return is at Pin 11 (correct) and Power Ground is at pin 11 instead of 7.
