I really like how your car looks in solid yellow/gold with no stripes.  I didn't notice if you're planning on adding any, but it's a cool look as-is
Thank you! No plans to add any stripes yet, though my son is lobbying me to add black stripes to the bonnet…
A black stripe + nose band like the old Lotus would look very slick.  Wasp-like.
Ha! I think I’ll wait a bit and decide if like the solid yellow first…
in the interim, installed CaterLEDs for the 3rd brake light and also 3D printed some mirror mounts for the Spa mirrors. I think both look great!
What 3D print model did you use for the Spa mirrors?  Is it one that you can and are willing to share?  What type of print filament did you use?  I figured I'd try to get the Eccles version mounts from somewhere, but no idea how long that might take.  Ordering anything from the UK these days seems to be a crap shoot, what with tariffs, backlogs, etc.
William is correct with the post and files. I grabbed the STL from there, then uploaded and ordered through Xometry (a contract 3d print company). I had them printed in Nylon 6 CF (carbon fiber), solid infill. It was about $50 shipped.
They came out pretty much perfect. I did need to widen the hole for the door post - pretty minor!
SB100 process started! Got a temporary operating permit - now need CHP, BAR, and brake and light checks. Went to the Los Gatos DMV and they were helpful. Hopefully the paperwork is correct…
First full tank of gas!
  • Like 5
Working my way through the SB100 process and getting some good miles on the car. Got the car aligned and she drives wonderfully! Now down to the last few small items (anti-submarine belts, snaps for floor mats, remaining interior rivers, etc). Plan to replace all fluids at 500 miles.
  • Like 5
Are you satisfied with the CaterLED 3rd brake lights?   Any issues with the installation?
@jmaz not OP, but I love my CaterLEDs. If you have a new build they're plug and play and awesome. No issues whatsoever and helps you be more discernable especially here in TX where I'm surrounded by trucks that are 8 feet tall.
One thing to be aware of is if you install them horizontally on the top of the rollbar it'll interfere (and not be visible) with the hood or half hood.
I installed mine on the vertical posts of the rollbar in case I want to ever get a hood.
I love them - super easy to install and look great. Also like that it’s a community member (and their kid) that are selling them. I’ll probably move them to the vertical mount position after I have my plates.
On 4/12/2026 at 12:22 PM, TorqueSpec said:
With my Europa, Elise, and Sevens, I got pretty good at removing seats.
Just did an R&R on the driver seat of the CSR.  Not for the usual reason, access under the dash, but to block up the seat so I can see.
Subscribed!
I live in SF and am considering buying a 420 Cup, but I'm slightly put off by the SB100 logistics.   Very useful to see what this involves and how long it takes, given how painful DMV visits usually are around here!
The Caterham is mostly done - just odds and ends left - so taking advantage of the amazing weather to get some good drives in (including letting my 81 year old dad compare it to his S2000). Also working my way through SB100. Got the CHP VIN verification done. Tried getting my sequence number at the dmv, but there was a state-wide outage. Next time!
  • Like 8
  • 4 weeks later...
Still working through SB100, but having a ton of fun with the car while I wait! Took it up to Skyline this past weekend…
  • Like 5
  • Thanks 2
Plates obtained! Finished the last of the SB100/SPCNS process today, with the in-person referee inspection following the virtual BAR inspection. I've got a wet sump duratec, and the car as assembled does not have a closed-loop PCV.  Most documented SB100 cars here have a dry sump, which requires a different solution. The wet sump has a PCV valve on the block (unlike the dry-sump motor, which has a blanking plate there). What was needed was to route the valve cover vent bank to the air intake (new hose and new hole drilled into the intake cover).  Photos attached.
Car passed both inspections, and the referee placed the coveted SPCNS sticker in the engine bay this morning.  Following my final trip to the DMV, plates were issued! This forum was invaluable, as were the many detailed build blogs.  See you on the road!
Edited by TorqueSpec
fixed photos
  • Like 9
Congrats! Hopefully your experiences will also be a resource for folks negotiating the SB100 process in the future. Enjoy!
