Ran into my first real issue - looking for some wisdom from the group. ready to start the car. Battery is hooked up and ground connections are solid. When turning on the ignition, the starter button will not work unless the headlights are turned on.
Turning on the headlights will light up the dash, but also bring the speedometer up to 20mph and create a buzzing sound. Attached is a video of the speedo with the sound. Any guidance?
I have no direct experience with assembling a Caterham from a kit so please keep that in mind. But it sure sounds like a ground issue. Current is finding strange ways to get places.
You might try taking a set of jumper cables and clamping them here and there, the goal being to see if some part of the car is isolated electrically. After that I guess I'd dig into the harness and connections. Headlights and starter are both big users of current, maybe they have some part of the circuitry in common?
My first guess is the same as @wdb. One of the grounding points isn't tightened or the powder coating wasn't properly removed. There are three places where I'd run the jumper cable: The ground location at the back of the engine/bellhousing, the main grounding point on the shelf next to the battery, and the grounding point for the switches & gauges at the wiper motor attachment point behind the dash. The first two are easy to find. For the third, see this photo with the scuttle removed. The dash grounding point is at the top of the photo, circled in red. One caveat is that it's been a few years since I redid my under-dash wiring, so there may be a fourth point for a portion of that harness that I've forgotten about.
Thank you, both! It was a ground issue. I forgot to reinstall one of the under dash grounds when I installed the windshield wiper motor (my car didn’t come with the windshield originally). Appreciate the wisdom and the photo!
  • Like 3
I'm so glad that's it! Hopefully you'll film it firing up!
Tons of progress yesterday! Ground issue sorted, engine started, shake down run completed!
  • Like 3
And startup!
A few things to sort after a quick test run:
- Tach not reading
- Gas gauge not reading
- Windshield wipers worked then stopped
- Radiator fan didn’t turn on
All in all, a fantastic day!
Sounds like you have some electrical gremlins so it might all be related.  My radiator fan stopped working on my inaugural drive.  Turns out the connector by the front cross strut shook itself loose.  I made some slack and zip tied it together.
8 hours ago, TorqueSpec said:
And startup!
- Tach not reading
IMG_0859.mov
  1. You can check w/ @hahuang65as he had seen tach problem before. I thought the fix was a new gauge.
  2. How much gas do you currently have? I have noticed the gauge will read zero (or near zero) when the tank is less than half full. I used this "Caterham Fuel Gauge Correction Module - 2016+" from Beachman Racing, and it fixed the problem.
  3. My wiper had the same issue and Rich sent me a new wiper switch to fix the issue.
  4. Radiator fan should turn on when the temperature reached about 95F.
Exactly what @empti said for all points.
I had to get a new tach although you can check your dipswitches. Rich had sent me a document but I can't seem to find it. If he's your dealer ask him about it.
Definitely get the fuel gauge correction module.
I also had to get a new wiper switch though I haven't installed it yet because I switched to the aeroscreen.
Yeah run the engine until it gets hot,then the fan will start. In fact let it cycle a few times...the fan will cool the radiator enough to shut down,then it'll get hot enough to turn back on.
I am so surprised that they still haven’t fixed the fuel gauge without some weird aftermarket man in the middle. Seems like an obvious problem with a customer need Caterham should address themselves!
Huge news! Congrats on getting it running. I don't trust the fuel gauge in my car at all (with similar behavior) but unlike a 2016+ car I'm not sure there's a cure.
Hope to go for a drive soon!
(my car is back up on stands to address a noise coming from the rear suspension, which really means I'm long overdue for a torque check on every bolt back there...)
Update - have sorted out the radiator fan (and cleared the coolant system of air). The tachometer fix mentioned above worked, too! Wipers appear to be a fuse issue - getting new fuses and will see if it blows again.
New item to troubleshoot - the headlights work, but the high beams do not - any wisdom on where to start troubleshooting? The fuses seem fine.
My wiper switch blew 5x fuses before it was replaced. FYI.
I think the headlight issue might be related to wiring. Check the connector from the light to the harness.
Almost done and doing more shake down rides! Question for those of you in California - are there specific regulations for placement of the CHSML? I just installed the set from CaterLED - deciding between placing them on the roll bar vertically or placing them up top horizontally.
Also - as I prep for SB100, any recommendations on which DMV and inspection locations? I’m in Fremont but happy to drive around the Bay Area if it simplifies thing. I’m assuming you need to tow the car for the CHP inspection?
  • Like 3
I went to los Gatos dmv even though it's not that close to me based on recommendations that they were more familiar with sb100 than some other locations.
I used Concord DMV and Martinez CHP office. I think they both are great.  Just make sure you ask for the ones that understand SB-100. You can go to DMV first with all the paperwork (without your cat) , and get a temporary operation permit that is good for a few months. Then you can insure and drive the car around and get the BAR inspection for smog waiver, Vin verification at CHP, and back to DMV for the inspection. Be prepared for multiple trips to DMV:)
Totally understandable... Wealthier community, even by Bay Area standards with an older population that have a higher likelihood of appreciating classic and custom cars? Yeah definitely can see that.
