pethier Posted 16 hours ago Author Posted 16 hours ago (edited) I need to know what this device is. Is it for controlling the heater? I'm standing on the left side of a 2003(?) Birkin with the Zetec engine, so the left side of the photo is towards the front of the car. On the left of these photos are the spark-plug wires heading forward to the engine. On the right of these photos is the heater core with two heater hoses coming out of it. In the middle of these photos is the gizmo I want to identify. It's in my way. If it is needed only for the heater, I would like to make it go away. I do not need a working heater. I can bag it and tag it. Edited 16 hours ago by pethier The other photo method didn't work 1
Scott_ Posted 15 hours ago Posted 15 hours ago (edited) @Vovchandr is right. An adjustable FPR. Scott Edited 15 hours ago by Scott_ 1 1
m2711c Posted 12 hours ago Posted 12 hours ago (edited) FPR? edit: Fuel Pressure Regulator? Edited 12 hours ago by m2711c 1
pethier Posted 11 hours ago Author Posted 11 hours ago In case it matters, this Birkin is fuel-injected.
11Budlite Posted 3 hours ago Posted 3 hours ago It looks like the same FPR I ran in my fuel injected Birkin. I think mine was an Aeromotive.
wdb Posted 3 hours ago Posted 3 hours ago It certainly appears to be a regulator, and fuel makes the most sense. But it also appears as though only one of the barbed tubes is connected to a rubber line. That seems odd if fuel is going through it. Is there a third connection, perhaps on the underside?
Silber Posted 1 hour ago Posted 1 hour ago For what its worth, with my Birkin having a Duratec and my FPR a different unit, the location is the same as yours: This is an old picture I pulled from my other thread, with an arrow added to point out the FPR.
S1Steve Posted 1 minute ago Posted 1 minute ago Basically the same regulator. Take a better look and you’ll see the second hose outlet at the bottom..
