Apparently, Cat has not yet found a way to neatly tuck the Horse ICE into the 7... properly.   In my purist opion.  Comments?
Images:
https://caterhamparts.co.uk/
On the Caterham UK forum, there is a member "wgm20" who has posted pictures of his purple people eater purple bonnet all pretty and painted. But I will not risk raising any cackle by linking it here.
Edited by IamScotticus
There are no issues linking to another car forum. This isn't a competiton.
  • Haha 1
It is what it is. One might also say that only “true” 7’s have clamshell front fenders but we know why they don’t.
It is just another step in the evolution of the Caterham Super 7. At least the present ‘bulge” has been  smoothed and shaped to better the air flow. The first one with the mesh screen in front didn’t work as they first thought it would.
I’ve attached two images with their links.
The first is from EVO magazine showing the test car.
https://www.evo.co.uk/caterham/7/208108/caterham-seven-horse-prototype-pictures
The second is a used Academy car presently for sale.
https://www.woodcoteandcopse.co.uk/used-car-details/used-caterham-academy-race-package-caterham-motorsport-13-horse--convertible-bespoke-manual-petrol/id-5899127252571025082/
Is this new engine from Horse due to a Sigma supply problem, or merely ongoing commercial evolution? thx
Well yes...no more Sigma production.
Edited to add:
Ford moved to a 3 cylinder ecoboost thing which is too tall for a Caterham.  A new engine solutions is needed.
Similar for Duratec but they have quite a few years Caterham production of engine stockpiled which gives them time to sort a replacement.  They are evaluating options.  I think the MZR is still produced in places - thats the Mazda version of the Duratec.
I'm surprised they didnt switch to the MZR, or partner with a small firm to contract xyz castings. Shame the K20 wasnt looked at, as I belive it is roughly the same height of the duratec?
Conglomerate engines are rarely good (stellantis) - not sure using fluff business case capacity makes sense for a traditional silhouetted vehicle.
VT holdings or outgoing CEO probably had ties to Nissan etc, which facilitated the Horse discussion.
Sales over time will show, but the vehicle is no longer the same.
it's the same crap most businesses face....sell more than last year to stay afloat.
Cost per unit...
The Horse is no donkey, but certain sacrifices must be made.  The European ICE environment is not a friendly one.
I believe Westfield had the best engine option but that didn't work out.
It seems like a dream engine (god knows people aren't swapping it into everything else), but I don't think that's true.
Two of the ones I've seen (one was a Locost and the other is a Caterham) don't make it look easy.
(the aforementioned Locost)
A forum thread about a K20 in a Caterham S3. Guy ended up with 25mm of ground clearance. That said, they put a dry sump on and gained some of that back. Can't argue with the results but it was a heck of a squeeze.
https://www.pistonheads.com/gassing/topic.asp?h=0&f=101&t=1811005
I saw this car at Spa - it was being trucked back to the UK broken - head gasket.  Photos halfway down in the link below.
Between the photo on this thread and when I saw it, it gained new exhaust headers for more space.  Packaging was clearly a complicated work of art by the installer.  There was still not as much ground clearance as a Duratec installation.
I have to think that the car shown above (and in Croc’s gallery) had the engine placed lower so that the bonnet would fit without any unsightly bulges or scoops.
In our little Group of Sevens we also have a member with a Honda powered Locost. Like the Locost above his car’s engine sits up above the bonnet. He has since made a scoop to cover it as well as doors.
MK has a bolt-in option for the K24. It makes for a pretty compelling package.
22 minutes ago, Croc said:
@fastg has a Honda Locost.  Really nice installation and bags of power and torque.
Sounds like youre an expert on other's hood bulges.
Thanks for the comment John.
Have a few K24 / K20 kits being delivered in the next 3 weeks - and a few on order for the next shipment as well.  Pretty much everyone goes with the K series - but may be due to my influence...
Really is a spectacular car.  Most of the kits I'm selling are not Miata based anymore, they are the Sprint kits - all new except for engine and transmission.  Miata parts have gotten expensive...  Pretty much a wash to go with new now.
Have done a lot of development over the past few years - DBW, traction, launch, cruise control are all pretty much standard on a K series now, have found ways to do this affordably, and with good equipment to boot.  Dialed in.
A solid 250Hp in a 1250# car - with a gently modified honda engine.
Simple, reliable, great noises, and as fast as you would probably want it.
Croc Is correct I do have a Honda K24 powered Locost. It's a great motor, I built it in 2014, it has done 12-15 track days per year and never missed a beat. Engine management is also easy with the K-Pro modified factory ECU, I used new Honda engine and power harness, I think they were $125 each. I now have a high spec 4 Piston cylinder head with matching inlet and exhaust setup. The car owns the record at a popular local dyno shop as the most powerful 4 cylinder motor they have ever tested. I started with and Miata 5 speed but quicky changed to a Miata 6 speed. My only issue with the motor it it's very tall. I do not have a hood scoop, but I do have a spacer below the hood, I also have very limited ground clearance. One advantage of the K20 motor is has about 3/4" height advantage, but the K24 is more common. I started with a K24A2 out of a Acura TSX, I think it cost me $700 after I sold all the parts I did not need.
Graham
A couple of points about the K20/K24 engine.
The stock ECU is complex. There is a fuel and timing map for each inlet cam timing setting 0-10-20-30-40-50 degrees. There is a complete set for high and low VTEC settings. So a lot of maps, that is why the Hondata K-Pro is a good choice, it's a stock ECU that has been modified to be fully tunable. You can also use the stock harnesses that are real cheap.
The engine has a VIN number plate, you can run a CarFax to get information on the motor. Not perfect but it can be useful, my engine was out of a 70k mile wrecked vehicle. I got if from the breakers yard they stripped it. Maybe other manufactures put the VIN on the block I do not know.
They are easy to keep cool mine runs at about 190 degrees on a 30min track session. They like a lot of cool air, so plan the airbox with care. I run a backwards facing manifold with an airbox over the passengers feet. With a NACA duct, inlet air temps are only ever 8-10 degrees over ambient.
Don't skimp on the exhaust. If you want all that flat torque curve all the way into the 9k+ rev range, put some thought into the exhaust.
I run a tiny alternator, the 7 chassis really pinches down at the front and the stock Honda alternator is huge.
When I first engineered the swap I used a S2000 inlet manifold with the throttle body pointing forward. The first time went to the dyno,  as soon as I opened the hood the dyno operator said, what are you doing, your just getting hot air into the engine. So next winter we swapped to this setup, it was worked well, I run  a 90mm throttle body, designed for a tuned Ford Coyote, the engine really likes good and in and exhaust out.
Graham
