I pick up this 1972 Mallock Mk11B next Saturday.
Plan is to do some track days this year, then Vintage racing next year.
Info on the Mallock from the original eBay ad (although that's not how I purchased it):
Description
Subject to complete restoration 2003-2004, including new epoxy coated square tube frame, aluminum skin, and fiberglass body parts. Virtually all running gear replaced at that time as well. Only 23 vintage historic events since. 0 hours engine by PHP Racengines of Wauconda, IL. This is a very competitive vintage British sports racer that handles like a dream. The car has been described as a "Lotus 7 on steroids". Suspension design by legendary race fabricator Sir Arthur Mallock. Virtually a new car. Will require tires and final race prep but otherwise ready to run. Eligible for virtually all vintage race organizations in North America or UK. Will fit driver up to approximately 6'3" in height. Car will be sold with a bill of sale.
History
Built for Clubmans racing series in England, 1972. Competed in Clubmans series 1972-?. Imported to US in early 90s. Campaigned with CVAR in Southwest, later CASC in Canada and recently in the Midwest with VSCDA and Midwestern Council.
Performance Data
  • Class: Vintage Historic
  • Weight: 953 lbs
  • Best Time: 1:20 sec
  • Track: Blackhawk Farms
Engine
  • Engine Builder: PHP Racengines, Inc.
  • Manufacturer: Ford
  • Type: Kent Crossflow
  • Displacement: 1600
  • Horsepower: 148
  • Torque: 122
  • Induction: Dual Weber 40 DCOE
  • Heads: Longman
  • Block: Ford
  • Crankshaft: 8 Lobe Counter Billet, Forged, Nitrided
  • Connecting Rods: Carillo
  • Pistons: Ross Forged
  • Valves: 7mm, stemmed, 21-4 stainless
  • Clutch: 7.25" Tilton Single Plate
  • Flywheel: 11.2" Aluminum, 110 tooth
  • Exhaust: Stainless, 4 into 1, new
  • Dyno Hours only. New Titan front mount oil pump
Fuel System
  • Fuel Cell
  • Manufacturer: Fuel Safe
  • Capacity: 8
  • Fuel Pump: Summit, electric
  • Fuel Type: 110 Leaded
Oil/Water System
  • Radiator: AH Fabrications
  • Water Rad Location: Front
  • Oil Cooler: Mocal
  • Oil Cooler Location: Front
Electrical System
  • Ignition: Pertronix
  • Alternator: None
  • Battery: Odyssey
  • Data Logger: None
  • Computer: None
Transmission
  • Manfacturer: Quaiffe Rocket
  • Type: 4 Speed dog box
  • Gears: Straight Cut
  • Shifter: Stick
  • Trans Cooler: None
Rear End
  • Manufacturer: BMC
  • Type: Live axle
  • Cooler: None
  • Ratio: 3.7
  • Axles: Sprite w/ double bearings
Body
  • Construction: Polished aluminum/fiberglass
  • Color: Silver/royal blue
  • Paint: Centauri
  • Condition: Excellent
  • New epoxy coated frame and aluminum in '04
Chassis
  • Type: Space frame
  • Builder: Mallock/Arch Motors
  • Material: Steel
  • Finish: Epoxy coated
  • Front Suspension: Double wishbone w/ coil overs
  • Rear Suspension: Live axle, trailing arm w/ panhard rod
  • Shocks: Carerra, 2003
  • Brakes: Offset discs, single piston
  • Steering: Rack & pinion, triumph rack
  • Wheels: Revolution
  • Tires: Formula Ford treaded
Interior
  • Color/Finish: Aluminum
  • Material: Aluminum
  • Fire System: Zero 2000 2.25 Ltr.
  • Restraints: Willans
  • Guages: Autometer
  • Steering Wheel: Momo
Spares
  • Quick Jack and Stands
  • New spare cylinder head by Burton Power (UK)
  • Complete set of ignition spares
  • Spare fiberglass nose
  • Bucks and molds for rear fiberglass fenders
Edited by bball7754
Not just you Croc. Glad you asked though, thought it was my not-so-smart Samsung phone acting up again!
If it's the car I think it is then I am familiar with it from my time crewing for a buddy racing with VARAC in Ontario. Was looking for a pic to confirm.
Was a very well prepped/maintained car, super competitive.
Good that there are no pix, I am already envious enough:). You shd bring it to NJMP for its shakedown! It's just an aero se7en.
Steve, save your strength. Don't wear yourself out by polishing Both cars to that mirror finish. :jester::cooldude:
See you shortly. Tom
Steve
Was it on Bring a trailer?
Very nice Mallock!!
Hope to see it some day.
Rick in NJ
Rick - Yes, I originally saw it on Bring a Trailer. By the time I called about it, it was promised to the person I'm buying it from. He owned it for about 2 months and then his race car situation changed and he decided he couldn't keep it. He called the BAT owner and got my name and a few others that had expressed interest. He called, and I decided (sort of) that it was fate.
Another person on the East coast was also interested in buying it. Was that you? And where in NJ are you? I grew up in Bergen County outside of NYC.
Steve
Steve - I was far to late to be a serious buyer. Really looks well prepared. Have been a Mallock fan from the first one I saw at Limerock many many years ago. Always though of it as a hard core Seven.
Grew up in Wayne now in Montville.
Rick in NJ
Picked up the Mallock this past Saturday. Any thoughts of bringing it to NJMP vanished when I realized that I would need to make some major pedal and seat adjustments before I could drive it. The previous owner was substantially taller than I am. I practically have to lie down to reach the pedals.
Here it is in the garage (briefly).
Very nice Steve! Looks like you've been giving your buffer a workout. What's the next
addition to your stable? Something red and Italian?
Mike
Edited by breezy7
