Mine came in over the weekend. It's the "G2" which has some sort of internal hardware and runs an app on my phone. I've reached out for some support, hopefully will hear back during the week. I did a check of my wife's car, which has unknown alignment but I assume it's OK. The numbers weren't crazy, but I didn't save them. IIRC it was something like -0.25 toe front + rear, but very precise-looking values like -0.18* and -0.37* The app has a few modes including a 4-point and 6-point check, plus a thrust angle which uses a body reference. The body reference I chose was the sill where the scuttle hits the "door". I'll assume my car is still square, it's never touched anything. The rear is a dedeon with machined plates, so I further assume the toe is controlled very precisely, tho thrust angle could be off slightly. note that in the photos below the "+1.00*" is a configuration I added, it doesn't actually mean anything for the measurements. here's #1 and #2. The pictures look alarming but the actual values are small. Note that the car didn't move at all during these two measurements, I just repeated the same test twice. The procedure involves holding the phone+device flat (the diamond in the center is your level reference), then hold it against the reference point on the body or the wheel. One of those will blink saying which one it wants next, you align it then tap to confirm. It sends you back and forth a few times to get the measurements before showing the result. I do expect some toe in here, and I think it's underestimating twice. As this is a dedeon I don't feel like toe has much room to wear -- it's steel or aluminium all the way around. I also did the "6 point" check for toe front+back, twice: again, the car wasn't moved between tests. This time the rear toe is more consistent but the front varied a lot. I have not tried to independently measure in 15k miles but I expect the front to be toed in a little. I'd already reached out to the team to see if they could help with the square-check. I don't know if a good set of thrust values would really help here... maybe? My dedeon doesn't have any thrust angle adjustment, I think the two swingarms will constrain that angle. At best I could try and shim the assembly left or right but I don't think the gyraline (as currently provided) can account for that. And It was shimmed + measured when I built it... The above 6-point rear toe check is encouraging, but the fronts and the thrust angle seem ... variable. I'm not sure what the expected accuracy is. I assume something like 0.5 or 0.25 degrees, just based on the swing in the numbers below. But if that's the case I have a front that may or may not be neutral. Based on the very obvious inside wear on both tires after 17k miles I assume they're toed in just fine. I have not yet attempted camber measurement. Again with the dedeon I expect the rears to be very precisely constrained. The fronts were aligned when new and with no accidents and mostly grocery and road trips, I expect the fronts to be about -1.5*.
Its a big readjustment process but incredibly rewarding as a driver. Most people come from bigger cars which have enough weight over the nose to just hammer the wheel left or right and the car just goes. However, a Caterham (or Birkin or Westfield or Locost) just do not have the nose weight when under acceleration so a left or right turn in that state will just lead to scrub. A brief lift of throttle or light tap on brake is nearly always enough to put more weight on the nose/front wheels to get them to bite for your turn. Then you can play with throttle in the corner to adjust attitude. Think of it in a sequence. Corner coming up. Brake to get weight over nose. Once weight is on nose then off brake and turn in. Once turn iniitated then start to feed in power progressively to come out of corner quickly. Slow in and fast out. Ross Bentley in his Speed Secrets series has a good section on managing weight transfer around the 4 wheels for varying outcomes. Find his first book in the series and have a read. Then go out and experiment - great opportunity for a track day since you can do it safely plus repeat corners to adjust technique and get a good seat of pants feel. Also read his section on trail brake as this is a great technique for keeping the rear end controlled under late braking entry to corners - Caterhams respond well to trail braking. Its more lack of weight on front tires under acceleration. Its not a 50/50 weight distribution front to rear as a driver is a lot heavier than a 4 cylinder Ford engine. Obviously with the aerodynamics of a brick, there is some front end lift which exacerbates the problem. The example corner for me is Copse at Silverstone. Its the old turn 1 if you are using the old pits. Its 60 foot wide track going and about 80 foot wide coming out. I go in at redline in 4th and have 15 feet of available track on exit, even without braking or lifting. And I scrub understeer the whole way through. I do not need to tap or lift as the track is so wide. But I have to do a lift to set the front tires up for a quick corner. Frustrating. Luckily there are not many places where that is an issue - top corner just past the rising esses at VIR, Copse at Silverstone, two corners at Portimao, entry into corner 1 at double Gauche at Spa, etc. Caterham sell one for rear camber and toe: https://caterhamparts.co.uk/de-dion-tube/6531-camber-and-toe-shim-kit-de-dion-cars.html I would ping Josh at Rocky Mountain - I bet he has some in stock. You do need to know where you are starting from on rear alignment. How much rear camber is dialed in from the standard de Dion. Should be 2.5deg but that is not guaranteed - check will tell you. Borrowing a photo from someone else since I am flying this month and won't be near my cars until June. Front - back of wishbone. Photo shows a more recent model Caterham with ali skin. The ruler points at measuring point. My measurement was ground to chassis tube as not all cars are covered in ali there (e.g. older chassis and race cars) but you can deduct the right amount of ali skin cover from the 120mm. For the rear measurement point, do it ground to chassis tube at the rear axle point - no photo handy right now. Its not much - only +5mm rake front wheels to back wheels.
Nice. Could you show us a view from the side? Looks like I need to prepare a 3/4” long channel to give it a prayer of being usable with this mount. i could use a badge like that for my steering whell as well. Looks thick and solid.
I installed the Zoom Compact mirror today. I had previously lowered the factory mirror to the base of the windscreen to reduce some of the annoying vibration, but the Zoom takes things a noticeable step further. While shake isn’t completely eliminated, it’s no longer objectionable. The mirror is slightly convex and, despite its small size, provides a good field of view between the seats. There’s no day/night function, but the surface is coated with a blue tint to help reduce headlight glare. I was concerned the coating might be too dark during daytime use, but it seems fine. My only complaint is that adjustment requires loosening and tightening a set screw. This isn't a big deal unless you regularly share driving duties, but with a wider channel machined into the socket housing, and a Belleville washer to apply constant tension to the ball, it could operate like a conventional mirror.
Of course they can be removed. Grab pair of cutters and cut the back side of the block. Don't use a box cutter or the like or you could damage the strap (not as big a risk if you had Diamond Weave straps). Then just bend the block and pull it off the strap. If, after your experiment, you think you need them, just pop them back on. They will function just the same as if you had not cut them. It should be a long time before you need to replace the straps. What usually kills straps is UV radiation. You are going to use and store these straps in an enclosed trailer. I renew my endorsement of the Diamond Weave straps with the European-style friction sleeves from www.autohaulersupply.com. I didn't buy these because my original straps were shot. I bought them because they are better. -
Let's start with "It probably does not make much difference due to the friction of the strap". Now, let's neglect the friction for a moment like a lot of classical physics illustrations do. If the straps go straight down to the roller and clip, then the portion of the strap between the two is at the shortest length it can be. The tire can't go anywhere because that would require more strap length. The yellow things are not ramps, but chocks. I believe they attach to the E-track. I therefore suppose they offer more resistance to the car moving forward in braking (or, heaven forfend, a crash). I don't think that strongly-enough to go out and buy a pair. What they are good at is stopping the car while you load it at the exact place you had it last time. Since I use a remote-controlled winch so I can see exactly what I am doing, I don't need permanent stops. Non-Seven sidebar: I have left door on my full-width trailer so I can open my car door. I don't bother with the winch when unloading the car, I just get and drive the car out. Some cars are set up so the car door will not clear the trailer inner fender and the trailer door. I have fashioned plywood risers that key into the E-track. I place two of these on the left track where the tires land. The front one has a wood strip at the front to prevent the car from rolling off the front of the riser if the trailer happens to be pointing downhill when I am winching a car in. These risers tilt the car enough to get door clearance. This is really a good thing, since my Cayman has a dual-clutch transmission, so just like with a conventional automatic, I have to step on the brake to get it out of park. The risers are sized so that I can still get the tire straps to the E-track slots. I don't need these risers with a Seven. I can enter either side of a Seven inside my trailer even if it has top and doors. -
I would double-check the specs and manual on your truck to see if there is a max tongue weight (in pounds) for the vehicle and/or hitch (without a wright-distributing hitch). Also check the rear axle weight limits GAWR). As loaded, you've moved a lot of weight off the front axle and onto the rear axle - which I suspect is why it feels sluggish to you - much reduced steering. I might be hesitant to get much above 55 with that much weight moved off the front axle, but you'll know by feel. As an example, my LR3 is rated for 7700 pounds towing capacity... but the hitch is only rated for 750 or 800. So if towing near the max I can only go to 10% tongue weight. At any rate, adjusting your load so that your tongue weight is closer to 10% may improve driveability. -
Is there a predetermined correction for measuring to the Ali skin? Or just measure both front and rear to Ali and it’s consistent. (I switched over from Avon zzs to Toyo r888r and I think there was a jump in front tire diameter vs the rears ). Although I never check ride height and rake with the avons. I feel like now is a good time to dial it in.
Those rubber guys are captive on the straps and cant be removed. There are 3 per strap. The also have little nubs that are supposed to go in a center groove on a tire to hold the car in place even more. However, on the r888rs, the center groove is offset so you cant really use it. When these straps need replaced I will likely grab some regular straps. I plan on doing something like this eventually. I am planning on getting a second set of wheels for the caterham along with one or two trailer tire spares. This seems like the best solution for secruing them as well as maybe a few other things. You're including the 240lbs that is coming from the front axle with the trailer loaded. it would be (3020-2240) - (2800-2560) = 540 Thank you and good catch, I will move the roller closer next time and pay attention to that. I assumed it was close when i did this yesterday but you're right, looking at the photos at least the one could move at least on slot closer to the tire. If they are touching or could touch the tire in any capacity, is that too close?
Check your inbox, I sent a message you can respond to yesterday.
Thank you, Croc. No insult taken, and I appreciate verification on anything I post. I didn’t know understeer was the de facto behavior as this is the only Caterham I’ve pushed hard enough to find out, and I’m still learning how to dance with it. My expectation was that it would oversteer naturally and I would have to manage it. At Autocross I did a better job of balancing the weight, but didn’t do great every time and it showed. I’m no professional and still got much to learn. Yesterday I admittedly chucked it into a hair pin expecting Chapman’s hand to give me rotation. It’s good to know about the high speed understeer too, although that sounds like aerodynamics may be playing an effect too? Greatly appreciate you sharing your specs! Good to hear that you shim the rear as well. Are there a set of recommended shim kits? Could I bother you with sharing a picture of where you measure the ride height? I thought I measured it at the right place but every time I look I get more confused. I set it to 145mm front and 160mm rear with me in the seat, mainly because of oil pan clearance but it will be lower with 13s once I eventually do that.
You don't need those rubber blocks on wide tires. I stopped using them long ago because they were a right pain on my lowered Elise. You can test the theory by leaving them off on one wheel. If the strap is placed correctly, it's not going anywhere. If it is placed incorrectly, I don't think the blocks are are going to help much. It probably does not matter, but I tend to have the parking brake on and the car in neutral. I use the space behind the car to stack up my race ramps and use a 1" ratchet strap from one E-track to the other to hold them in place. They weigh almost nothing. Ignore the D-rings. The car needs to move on its suspension. A Caterham does not offer much in the way of good places to hook tiedowns: That's what is so good about using the tires. I have a short strip of E-track about shoulder height on the side wall of the trailer near each corner of the car. About 6 slots: three for a tire strap and 3 for whatever else is hanging around. Since I run my ratchets ahead of the car, I generally only disconnect the after clip of the three on the front straps and leave the assemblies lying on the trailer floor while I am driving the car. When the trailer is used for something else, I hang the front straps on the wall E-tracks. With all three clips fastened, the mass of the straps themself is unlikely to cause any trouble. Don't just clip two; you don't want that idler roller swinging around when you are towing an empty trailer. If you need to put the car in the trailer and don't have time to tie it down right then, take one of the straps and put it in the driver footwell of the truck so you you don't come back later and drive the rig away. -
Thanks everyone for you commets and advice so far. Made some more progress today. New tongue weight scale came in, and it wasn’t accurate at all either. These things are junk. It would weigh the tongue weight at ~200-300 lbs which just didn’t seem right. I decided to just strap the car down and drive to a CAT scale and get real weights. truck steer axle: 2800lbs rear axle: 2240lbs trailer axle: 0lbs truck + trailer steer axle: 2560lbs rear axle: 3020lbs trailer axle: 3100lbs So the loaded trailer was 3650, and tongue weight with where I happened to place the car, was 540lbs, pretty much sport on 15%. That also gives me about 100+ pounds more payload than I thought I would have which is great. I can probably move the car back a foot and gain even more payload if I ever needed it. Strapping the car down was... interesting. I am new to ratchet straps, etrack, etc. I put it all together and wasn’t 100% confident on how tight the straps need to be or where to place them. I just cranked away until it was not that easy to do more. I checked after a few miles and the straps didn’t move or loosen, so must have been okay? Here are a bunch of photos of the car strapped. Does it seem okay or should I change anything? Should I leave the car in gear with the ebrake on? I do have drings I can certain use in addition to the over the tire straps if that would be a good idea as well. The truck with the trailer loaded with the car drove fine, albeit I was not on a high way and only was going between 30-55mph. You can certainly tell the trailer has more weight with the car loaded though. Its much more sluggish in every area.
Don't think much of the terrain tires on my F-150. The Michelin all-weather LT tires on my Suburban 2500 were much better. On the F-150, I keep the tires at 80 PSI all the time and use the sway-snubber.
