  2. Hi. Not sure if this can be opened. New laptop, new scanner - learning all over again! W. It notes that the measurement is 4.375 inches or 111.13 mm
  3. @ptegler Does this diagram from the Herald workshop manual help? Herald:Spitfire steering lever.pdf
  4. Today
  5. Well right now it simply reads "zero" so I'm going to get it even closer... hopefully that will help. I'll take a look at what's been written later today.
  6. A lot has been written about finagling the sensor and calibrating the gauge. Holler if you feel like giving up.
  7. I definitely got some neighbors outside to see what was up. I try to limit my noise making to reasonable hours, they return the favor. So far, that's the only issue I've found! Oh, and the spedo is there just for looks. Will work on that.
  8. On my Westfield it's about 4.5" Spitfire upright
  9. This definition of the designation CSR appears everywhere I looked except on the Caterham website and Wikipedia. Even going back to 2006 most of the media (both print and "e" publications) seemed to have used it. If it was direct from the factory press kit I'd have thought it would appear on Caterham's website. So, I do not know where it originated but it seems to be a thing now that AI has latched onto it and points to many articles as it's source.
  10. Open pipes? WOW! You must have some very understanding neighbours. Also, good shake down as it seems to have revealed some coolant leakage.
  11. Because of the way Iowa marks its plates, I went looking for Excelsior County New York. Nope. Excelsior is a New York state slogan. As Joni sang, life is for learning.
  12. I'm pretty happy with with mine
  13. I was thinking about License plates for the 7 aand thought id share my Elise from back in the day. One of my fav pictures of the Elise.
  14. sounds strange...but need a couple people to measure their front suspension steering arm on their upright.... what is the distance from where your steering rack arm meets the upright to the center line of the upright pivot dimension. EG: how long is your steering arm to it's wheel pivot point. tia ptegler
  15. That's awesome! The cool thing about these 7's is due to there not being many of them. The cool plates aren't taken. I tied in the 7 to my nickname "Walshy" on mine. Added a silicone plate frame after I seen someone recommend it on here. ill be installing it onto the plate holder from Josh at RMC.
  16. Careful, the floor is LAVA~!!!!
  17. Still doing the build, but after the engine was working and the brakes were bled I couldn’t help but get it around the neighborhood for a shakedown!
  18. I always find it interesting when I see another man in his later years, who has had many great sports cars over the decades, say a Seven is the elusive one he always wanted or the caf that was always his favorite. I know there is much a 7 can't do well, but If one car had to be chosen, it is likely to be a 7 that gives the ultimate raw driving experience. Or an Elan.
  19. No need to defend yourself. Comments are in jest. It's quite an awe inspiring picture. We welcome bragodociousness. By default, us as owners of any variety of a 7 should consider ourselves lucky to have enough disposable income for a toy car and understanding significant others (if applicable). Not having the latter helps with the former.
  20. My tag arrived. Scott
  21. I worked out how to get the IC7 to get the canbus data I needed the data from the MBE 9M4 so I didn't have to direct wire RPM, coollant temp, etc. It was a two step process that started with Easimap and defining the can output and then setting up the IC7 to receive it setting up the start bit and length for RPM, coolant temp, etc. signals in the Haltech NSP software. I was able to get rid of the Innovate AFR guage and run the signal into the IC7 and covert AFR to Lambda, so I'm able to keep an eye on that and check it against target lambda. I just find lambda easier to work with than AFR numbers. I have the shift light set too low and need to work out why the LC7 is not getting the speed sensor signal. My license plate arrived today. Scott
  22. this entire thread is showing off. You don't get to apologize for dropping two Astons in casually.
  23. My photo wasn't trying to show off. I promise. Getting the 620R to be registered, ppf'd etc has been a long process, I am just so happy to have it back in my possession. The 2 missing cars from this photo were my Mini JCW GP2 and my Lotus Exige S260. Other than the RS6 (German efficiency (which I may be debating switching to a Tesla Model Y (I know I know), so we can have 1 family cars in the household as opposed to 2, had a go with FSD the other day, and it was really incredible), I've predominantly tried to build a British curation, being English it's the one thing that makes me feel that bit closer to home.
  24. this is what came up for me
  25. Yesterday
  26. My income doesn't support this picture pixel/dollar resolution. too bad you have to keep that pesky column.
  27. Cosworth Seven Road Racing - Is that really what CSR stands for? I saw this on a YouTube video and I don't recall seeing it elsewhere.
  28. I’m on my third drink in a bar in Paris - works for me. Clearly the solution is alcohol.
