Time to add more here. This is for new guys who may not know the difference between the two types of coolant tanks. This thread uses overflow, recovery, and pressure tank terms frequently without really explaining what is what. Recovery or Overflow tank: an open air vessel that holds coolant that is purged from under a radiator cap when the engine is hot and for pressure surges like hard accelerations. The cap and hose are usually located at the top of a radiator or on the head as part of a thermostat housing or swirl pot. The vessel holds the coolant until it gets pulled back in when the engine cools. There should be enough extra coolant kept in thd recovery tank to ensure the hose doesn't pull in air. Expansion tank: a vessel that holds extra coolant in circulation under pressure. The hot coolant flows into it and pulls back when the engine cools. There is not a radiator cap, the radiator is typically sealed. The cap on the expansion tank regulates the pressure, but unlike the radiator cap, coolant does not flow through it, this cap stays above an air gap. Typically, a "closed" system expansion tank should be half full of coolant at all times, expanding with the temperature but not needing an overflow tank. Most road vehicles since the 90's will have this type of system with an input hose st the yop of the vessel coming from the thermostat housing hot side, an output hose at the bottom going to the lower radiator hose or the cool side and an overflow hose at the filler neck that drains to the ground, if needed. For sporting applications, the overflow should be captured in a recovery tank to prevent spills and is usually a safety regulations requirement. Location, location, location. For open radiator cap systems, the height doesn't matter as air bubbles are purged out and vacuum pulls coolant back in. For closed expansion tank systems, the tank should be located where the tank cap can be the highest point for efficient air bubble egress. Above the highest coolant level in the engine or radiator. Regardless of which system you use, and why, realize that a failure of the cooling system can destroy your engine. Pressure caps are wear items and should not be expected to last forever. In a 7 where the coolant recovery tank is often locating front under the nose, it's not very visible. And even if you do see coolant in it, are you sure the cap is working? Choose the system that you can watch. I prefer a closed system because the level in the tank is the level in your whole system. If there is a loss happening, it will be more apparent from an expansion tank mounted on the scuttle than a recovery tank under the nose. -
- 1
Well, the saga did not end with the last post. Two weeks ago I went in for lumbar area back surgery and am happy to report that I am recovering well most days. Unfortunately, I have come to realize that at my advancing age that golf, hard-core race cars, astronomy with large equipment, motorcycles and even camping with a trailer are not the most advantageous activities for my old bones. So, up popped a nice fellow who had shown interest in buying the Stalker XL Classic and it went off with him in his 24" Pace trailer this afternoon. It was a bittersweet parting knowing that it was going to someone who is a former HPDE instructor and is used to high-performance driving. OTOH, it is a bit of a sad day because I have come to realize that some aspects of aging are encroaching on longstanding fun activities and I am having to accommodate the realities. I will continue to enjoy the wonderful people on this site but will be moving on to other adventures. I am excited to see what the future brings? Anaximander aka Bob -
@Vovchandr is right. I got my insurance way before my title. All they needed was the VIN and asked me how I wanted the make and model written. My car is titled as an Assembled Vehicle in TX while my Insurance has it as a 2024 Caterham 420R. I'm only about halfway thru my 1st year of insurance. I'll let you guys know when I get my renewal notice what's changed.
I don't even understand how NY title makes any difference on it. It can be insured before ever being registered as anything the underlying covered item on agreed value doesn't change regardless of what you call it. Not saying it didn't happen to you but I just can't wrap my mind around the logic there.
I just renewed my hagerty policy. No change in price from the last two years. In NY it's $1130 (plus $70 for the club membership). For agreed value of $80K - 2023 420R. In new york it's titled and insured as a "custom" as when I originally did it with "Caterham" it was $2400. But all the back up was caterham stuff so I was transparent. They said, if NY titles it as a custom then thats what it is. A very rare occurrence that after jumping thru all the hoops, it saved me a little money
Just got my Hagerty renewal - premium went from $1046 to $1406. May have to shop around.
IamScotticus started following WTB/B Spirfire rear hubs & parts
Wanting to buy or borrow spitfire rear hubs & associated brake parts for experimental fitting.
Austin David started following North Carolina Mountain Leaf Viewing Drive?
We're all doing a terrible job representing the southeast. The following is a proposal, all of these are editable -- click to sign in (free for life), make copies to change stuff. Overview: Blowing Rock -> Cherokee -> Asheville https://route7.austindavid.com/route/QlYEaMKAeTmv 1 day to gather, 2 days in the mountains, 1 day home. Day 1: go to Blowing Rock. Resorts are cheap during the week... or at least, they were in the "before times" when I used to travel a lot. Wilmington route for SENC: https://route7.austindavid.com/route/fro05kDTO8i6 Charleston route for me: https://route7.austindavid.com/route/DaxxB9cfN1zG Greenville route for uglyfast et al: https://route7.austindavid.com/route/DgsB6zLJjAh8 Day 2: ... is a lot of BRP still closed? https://www.nps.gov/blri/planyourvisit/roadclosures.htm -- seems to be some significant closure between blowing rock -> asheville. Blowing Rock -> Cherokee: https://route7.austindavid.com/route/9vPhadSdsw_U Day 3: Cherokee -> Asheville: https://route7.austindavid.com/route/MmF50JNmMRLf There's room for Deal's Gap in here. I've never driven it, I hear mixed things. Day 4: Asheville -> home Wilmington for SENC: https://route7.austindavid.com/route/-O6uPcRau8GP Charleston for me: https://route7.austindavid.com/route/rJ-0jxW25_N0 Again, just a proposal. I'm tired of working and tired of looking at my garage.
activemoveuk joined the community
Thanks. But based on my ability to run over stuff that destroys the trailer fenders I don't think I want carbon ones. Maybe if someone is upgrading from fiberglass to carbon I could help them by buying their old ones...
Thanks John, I have Mintex 1144 pads front and rear as installed on the car when I purchased it. (2008 Roadsport S3 very low mileage). Once I get the master cylinder sorted, I intend to visit the front / rear bias as is the thread topic. Cheers!
