Well, the saga did not end with the last post. Two weeks ago I went in for lumbar area back surgery and am happy to report that I am recovering well most days. Unfortunately, I have come to realize that at my advancing age that golf, hard-core race cars, astronomy with large equipment, motorcycles and even camping with a trailer are not the most advantageous activities for my old bones. So, up popped a nice fellow who had shown interest in buying the Stalker XL Classic and it went off with him in his 24" Pace trailer this afternoon. It was a bittersweet parting knowing that it was going to someone who is a former HPDE instructor and is used to high-performance driving. OTOH, it is a bit of a sad day because I have come to realize that some aspects of aging are encroaching on longstanding fun activities and I am having to accommodate the realities. I will continue to enjoy the wonderful people on this site but will be moving on to other adventures. I am excited to see what the future brings? Anaximander aka Bob -
@Vovchandr is right. I got my insurance way before my title. All they needed was the VIN and asked me how I wanted the make and model written. My car is titled as an Assembled Vehicle in TX while my Insurance has it as a 2024 Caterham 420R. I'm only about halfway thru my 1st year of insurance. I'll let you guys know when I get my renewal notice what's changed.
I don't even understand how NY title makes any difference on it. It can be insured before ever being registered as anything the underlying covered item on agreed value doesn't change regardless of what you call it. Not saying it didn't happen to you but I just can't wrap my mind around the logic there.
I just renewed my hagerty policy. No change in price from the last two years. In NY it's $1130 (plus $70 for the club membership). For agreed value of $80K - 2023 420R. In new york it's titled and insured as a "custom" as when I originally did it with "Caterham" it was $2400. But all the back up was caterham stuff so I was transparent. They said, if NY titles it as a custom then thats what it is. A very rare occurrence that after jumping thru all the hoops, it saved me a little money
Just got my Hagerty renewal - premium went from $1046 to $1406. May have to shop around.
IamScotticus started following WTB/B Spirfire rear hubs & parts
Wanting to buy or borrow spitfire rear hubs & associated brake parts for experimental fitting.
Austin David started following North Carolina Mountain Leaf Viewing Drive?
We're all doing a terrible job representing the southeast. The following is a proposal, all of these are editable -- click to sign in (free for life), make copies to change stuff. Overview: Blowing Rock -> Cherokee -> Asheville https://route7.austindavid.com/route/QlYEaMKAeTmv 1 day to gather, 2 days in the mountains, 1 day home. Day 1: go to Blowing Rock. Resorts are cheap during the week... or at least, they were in the "before times" when I used to travel a lot. Wilmington route for SENC: https://route7.austindavid.com/route/fro05kDTO8i6 Charleston route for me: https://route7.austindavid.com/route/DaxxB9cfN1zG Greenville route for uglyfast et al: https://route7.austindavid.com/route/DgsB6zLJjAh8 Day 2: ... is a lot of BRP still closed? https://www.nps.gov/blri/planyourvisit/roadclosures.htm -- seems to be some significant closure between blowing rock -> asheville. Blowing Rock -> Cherokee: https://route7.austindavid.com/route/9vPhadSdsw_U Day 3: Cherokee -> Asheville: https://route7.austindavid.com/route/MmF50JNmMRLf There's room for Deal's Gap in here. I've never driven it, I hear mixed things. Day 4: Asheville -> home Wilmington for SENC: https://route7.austindavid.com/route/-O6uPcRau8GP Charleston for me: https://route7.austindavid.com/route/rJ-0jxW25_N0 Again, just a proposal. I'm tired of working and tired of looking at my garage.
activemoveuk joined the community
Thanks. But based on my ability to run over stuff that destroys the trailer fenders I don't think I want carbon ones. Maybe if someone is upgrading from fiberglass to carbon I could help them by buying their old ones...
Thanks John, I have Mintex 1144 pads front and rear as installed on the car when I purchased it. (2008 Roadsport S3 very low mileage). Once I get the master cylinder sorted, I intend to visit the front / rear bias as is the thread topic. Cheers! - Last week
JohnCh started following Rear uprated ("race") brake upgrade finally done
JohnCh replied to KnifeySpoony's topic in General Tech
I upgraded my old Westfield from the standard Girling 0.7" master cylinder to the AP Racing unit. The mounting lugs differ slightly from the Caterham version to suit Westfield-specific packaging constraints, but otherwise the assemblies are effectively identical—including AP’s practice of individually shimming each unit to account for production tolerances. Both cars use the same rear calipers and feature four‑pot fronts, but the piston layouts differ slightly: the Westfield setup uses four 1.5" pistons, whereas the AP calipers use a staggered configuration with 1.5" and 1.625" pistons. So while the brake systems aren’t identical, they’re very close. The difference between the MCs was immediately noticeable—firmer pedal feel and easier modulation. Zero regrets despite the price and 6 month wait for AP to do a small run. Here are the AP and Girling 0.7" side-by-side: I also played around with brake pads on that car and found feel differed wildly. My assumption is the non-assisted nature tends to exacerbate differences in initial bite. @KnifeySpoony how is the dust with the Pagids? Is it just a little worse than the stock pads or is it excessive? -
Upgrading old suspension from original Bilstiens
IamScotticus replied to Elldawg's topic in General Tech
Too pretty to drive! Have coil covers?
