as in, "outer banks is cool but mostly straight and salty" ?
Happy to offer guidance/assistance for the coastal areas of SC/NC - have lived in SE NC for a long time and spent a good deal of time with up and down the Carolina coast. They're not great areas for your Seven, though.
On a Maine road-trip for the next bit (sans 7, unfortunately) - but will explore the links when I can. I'd definitely like to do something like this - but struggling to prioritize it against other demands on my time (thus my likelihood of selling it on sometime this year).
CBuff started following Route 66 Road Trip
I am always excited to get into the cat and go for a drive. If it’s a decent amount of miles I am also excited to get out of it. That’s how I know it’s a long enough drive. A trip out to Colorado or across the country is on my bucket list. @CWThomson well done. That’s no small achievement.
I just had a full hood. Given lack of luggage space, and unpredictable weather along the route, I needed to have a full hood (especially for parking overnight). Having some shade together with a breeze would have been nice. I'm tempted to get one of the roll bar mounted bags for the hood to free up some of the trunk space. Being 6'3", the hood makes a "fun" entry and exit so tended to avoid using it as much as possible. On a fast moving road, without the hood, the breeze was just about ok even with the high heat but coming into LA traffic was pretty tough. It did feel good getting into my first car after 3 weeks in the Caterham and experiencing AC again! I did also think my steering was broken on my regular car but it just took a while to get used to power steering again! :-)
At least in ny you need a vin to get insurance. And insurance to register. So the ny dmv inspects and assigns a vin. At that point the make is “custom”. Preliminarily I asked Hagerty if they would insure and caterham and then asked for a quote. $2400/ year which surprised me. Then when I got the vin assigned and they designated “custom” it was $1200. Even with my mco and all the invoices from caterham to prove worth. Hagerty said. It’s custom not caterham $1200. but @Vovchandr agree with you on the model/maker designation, especially on agreed value makes no sense. I’ll take one of the few financial wins in that whole process.
Time to add more here. This is for new guys who may not know the difference between the two types of coolant tanks. This thread uses overflow, recovery, and pressure tank terms frequently without really explaining what is what. Recovery or Overflow tank: an open air vessel that holds coolant that is purged from under a radiator cap when the engine is hot and during pressure surges like hard accelerations. The cap and hose are usually located at the top of a radiator or on the head as part of a thermostat housing or swirl pot. The vessel holds the coolant until it gets pulled back in when the engine cools. There should be enough extra coolant kept in a recovery tank to ensure the hose doesn't pull in air. Expansion tank: a vessel that holds extra coolant in circulation under pressure. The hot coolant flows into it and pulls back when the engine cools. There is not a radiator cap, the radiator is typically sealed. The cap on the expansion tank regulates the pressure, but unlike the radiator cap, coolant does not flow through it, this cap stays above an air gap. Typically, a "closed" system expansion tank should be half full of coolant at all times, expanding with the temperature but not needing an overflow tank. Most road vehicles since the 90's will have this type of system with an input hose at the top of the vessel coming from the thermostat housing hot side, an output hose at the bottom going to the lower radiator hose or the cool side and an overflow hose at the filler neck that drains to the ground, if needed. For sporting applications, the overflow should be captured in a recovery tank to prevent spills and is usually a safety regulations requirement. Location, location, location. For open radiator cap systems, the height doesn't matter as air bubbles are purged out and vacuum pulls coolant back in. For closed expansion tank systems, the tank should be located where the tank cap can be the highest point for efficient air bubble egress. Above the highest coolant level in the engine or radiator. Regardless of which system you use, and why, realize that a failure of the cooling system can destroy your engine. Pressure caps are wear items and should not be expected to last forever. In a 7 where the coolant recovery tank is often located in front under the nose, it's not very visible. And even if you do see coolant in it, are you sure the cap is working? Choose the system that you can watch. I prefer a closed system because the level in the tank is the level in your whole system at all times and temperatures. If there is a loss happening, it will be more visible from an expansion tank mounted on the scuttle than a recovery tank under the nose. Can I use my current thermostat housing from Caterham for a closed sys? Yes, if you can fit a cap that is not an overflow pressure cap. The outlet barb should go to the top inlet barb on the expansion tank (not the overflow barb). On those pressure caps, only the lower seal holds pressure. The top seal has no guarantee of it. It's better to use a housing without a cap so you don't have a failure point. Also be aware of those housings elbows that have the vertical nipple , those nipples are glued in and have been known to come off. Some Formula Ford tracks don't allow them. The nipple can be replaced with a threadded brass barb. -
- 4
Well, the saga did not end with the last post. Two weeks ago I went in for lumbar area back surgery and am happy to report that I am recovering well most days. Unfortunately, I have come to realize that at my advancing age that golf, hard-core race cars, astronomy with large equipment, motorcycles and even camping with a trailer are not the most advantageous activities for my old bones. So, up popped a nice fellow who had shown interest in buying the Stalker XL Classic and it went off with him in his 24" Pace trailer this afternoon. It was a bittersweet parting knowing that it was going to someone who is a former HPDE instructor and is used to high-performance driving. OTOH, it is a bit of a sad day because I have come to realize that some aspects of aging are encroaching on longstanding fun activities and I am having to accommodate the realities. I will continue to enjoy the wonderful people on this site but will be moving on to other adventures. I am excited to see what the future brings? Anaximander aka Bob -
@Vovchandr is right. I got my insurance way before my title. All they needed was the VIN and asked me how I wanted the make and model written. My car is titled as an Assembled Vehicle in TX while my Insurance has it as a 2024 Caterham 420R. I'm only about halfway thru my 1st year of insurance. I'll let you guys know when I get my renewal notice what's changed.
I don't even understand how NY title makes any difference on it. It can be insured before ever being registered as anything the underlying covered item on agreed value doesn't change regardless of what you call it. Not saying it didn't happen to you but I just can't wrap my mind around the logic there.
