  2. Without having read most of the previous, my solution to the filling issues is to forgo the 90˚ elbow and instal a vertical pipe, much like the S1/2 type. This will allow me to hold the fuel nozzle above preventing shut-off and give me visual confirmation of the fuel level and prevent wetting myself with everyone watching. Easily done in a non emission vehicle.
  3. A couple of pics of some of the FOUR Sevens that showed up at our event at Summit Point on Saturday! --Bob Collum, NoVA Lotus Car Club
  4. Today
  5. Yesterday
  6. I think I have found the trick to filling gasoline/petrol (hereafter "gas") into a Seven. It's not very useful on a cross-country trip, but if you are planning to drive your seven close to home (or close to your trailer), this could be the answer. The problems are: You can't tell how much gas is in the tank. The gas-station hose keeps shutting off, and you don't know which shutoff is the real one, so you get gas all over the back of your Seven and on your shoes. The gas station staff isn't all that happy, either. Get a couple of red plastic gas cans. The kind that do NOT have an air vent on a different location from the spout. The kind with a valve that is meant to be opened by allowing the weight of the can to open the valve when the little hook on the valve is allowed to press on the edge of fill port on lawnmower or the like. ( My lawnmower has a handy little shelf down inside the filler neck which allows the spout to go farther into the tank to reduce the gas from splashing out.) If the spout valve has a little nanny-lock that you need operate each time you want to open the valve, remove that with a pair of cutters. You need the valve to respond to your commands without interference. I picked five and two gallon sizes. Both can be filled at the gas station without a lot of drama. You can have multiple big cans in whatever size you can handle in their vertical-valve orientation. You really only need one small can. You want a small size that you can easily handle with the valve/spout in a horizontal orientation. Two gallons worked for me. Add a piece of hose to the spout. Make sure it has a good seal to the spout. The idea is to have the length from the valve-actuation to the end of the hose long enough so that when the valve is operated the end of the hose is all the way into the Seven's gas tank. Pick up the small can. Shove the hose into the car. This is not easy, as the hose wants to hang up on this and that. I have experimented with tapering the leading edge of the hose. Engage the hook on the edge of the car's gas port and push the tank forward to open the valve. The gas will glug into the tank. Periodically, the gas flow will glug to a halt as air from the tank backfills up the spout. If the can empties completely, raise the can and drain the hose into the car. Put the little can on the ground and refill it from the big can just as if it were a big lawnmower tank. Repeat the procedure. When the gas in the tank rises to the end of the hose, air can't get into the hose and gas stops flowing from the can. I'm calling this "vapor lock" whether that is the correct term or not. Let up the pressure on the can to close the valve. Withdraw the hose a few inches and raise the can so the gas in the hose drains into the car. Lower the can and carefully withdraw the now-dry hose from the car. The tricky part is knowing how long to make the hose. If you make the hose too long, you won't fill much of your tank. If you make the hose too short, you will have a gas mess again. Ideally, the vapor lock will occur when the tank is almost-full, but not yet into the car's large filler hose. I tried this method at home and at an autocross practice day and it seems to work. I still have not determined the ideal hose length, so I am erring on the side of "too long" instead of "gas-soaked Seven". You could do this at the gas station with just the little can, but you might not feel comfortable carrying a partly-full gas can in your Seven. (It is difficult to see the hose on one of the little cans in the truck photo.)
  7. Week Beginning May 17, 2026 USA7s Classified Ads of Cars for Sale USA7s classified pages - USA7s club members have the benefit of selling their cars by listing them for free on USA7s forum. https://usa7s.net/ips/forum/26-cars-for-sale/ New Ads This Week WCM Ultralite https://bringatrailer.com/listing/2006-world-class-motorsports-seven-replica-3/ Locost Project https://www.facebook.com/share/195xDotw3S/ Locost Project https://www.facebook.com/share/17KkahLK2j/ Lotus 7 https://www.facebook.com/share/18ggemMZ9U/ Lotus Mk6 Tribute https://www.facebook.com/share/1Y7VevT2FU/ Repeat Ads From Prior Weeks Lotus 7 https://www.hemmings.com/classifieds/listing/1963-lotus-super-seven-cochranville-pa-2891143 Caterham https://www.hemmings.com/listing/1999-caterham-all-models-526915 Caterham https://www.hemmings.com/classifieds/dealer/caterham/super-seven/2638345.html Caterham https://www.hemmings.com/classifieds/listing/2026-caterham-seven-miami-fl-2916813 and here https://www.facebook.com/share/1EFHC4RJHT/ Caterham https://www.hemmings.com/classifieds/listing/1998-caterham-super-seven-fort-lauderdale-fl-2914012 and here https://ebay.us/m/2R2wlX and here https://www.facebook.com/share/1EUVGu1kzz/ Caterham https://ebay.us/m/N9vevX and here https://www.facebook.com/share/1EMdXVwYKh/ Caterham https://ebay.us/m/7vLyH5 and here https://www.facebook.com/share/1EDSLhmYLA/ Lotus 7 https://www.facebook.com/share/14kyivg4B31/ Stalker https://www.facebook.com/share/18bQjYNhKa/ Locost https://www.facebook.com/share/19uDaLBrqB/ Locost Project https://www.facebook.com/share/18TEHHhAR9/ Lotus 7 https://www.facebook.com/share/1KMaPmsWmp/ Locost Project https://www.facebook.com/share/1BRoJSdZ2i/ Caterham https://www.facebook.com/share/18eBcA31Tp/ Locost https://www.facebook.com/share/19wtGoGYf9/ Westfield Pre-Lit https://www.facebook.com/share/18ADE6ShL6/ Caterham https://www.facebook.com/share/1H81A36hrV/ Locost https://www.facebook.com/share/18S84CLUJi/ Caterham SP300R https://www.facebook.com/share/18qhNsaei1/ Canada Locost Project https://www.autotrader.ca/offers/bmw-2002-kit-car-9b5e3f67-7e4f-4f56-acac-2df6e6c12e99 Lotus 7 https://www.facebook.com/share/1NdrX6wVov/
  8. I haven’t ever really determined my maximum range or filled my tank all the way (except the time I overflowed!) but I tried to crunch the numbers from my notepad-based drive log over the past two years and it seems I get around 20mpg, give or take. This is mostly on canyon drives (since the hills start 10 minutes away), so I guess I’m satisfied. Would always like to see a little better though! Edit: Zetec on TWM throttles, Pectel T2, 13” Toyo 185/205 tires. Actually a bigger rolling diameter than stock so my economy should be *slightly* above indicated but not enough to matter.
  9. I wondered why Steve left the practice day before the 4:00 shutdown. People told me the Electo-Birkin had shut down midrun. I didn't notice at the time. Apparently several folks pushed the car onto Steve's trailer and he took it home. I saw Harold at the autocross this morning. Not wishing put him on the spot, I tried to ask a general question: ===== What's the status of the Electo-Birkin? "I wanted to go home and spend some time with my wife and family." A laudable action. How about the Electo-Birkin? "A problem with the proximity circuit." What kind of problem? "I had the sensor in my pocket." ===== Yes. It seems that as soon as Harold drove away, the car decided that the driver was out of range and shut down.
  10. I’m very interested in the clam shells. Would you pack and ship to Canada?
  11. And its lap time there is? Not exactly a Caterham friendly track with all of the high speed sections.
  12. https://www.hemmings.com/stories/the-green-hell-turns-100-caterham-drops-a-limited-edition-seven-nurburgring-pocket-rocket/
  13. THANKS! Will check out
  14. https://gazcoilovers.com/caterham-gaz-dampers-326-c.asp I bought a complete set front and rear for my 88 S3. Even with the tariff and shipping it wasn’t excessive. Enjoying the car too much at the moment to take it off the road to install them along with the bushings I got from Sevens and Elans.
  15. I wish I had the budget for this….it would be great to have these as spares for my 1600 BDR
  16. A few folks have asked me if the Birkin that gave it's gasoline guts for my Caterham has progressed on its electric journey. Steve made it to part of the MAC autocross practice day. Since he lives near the site and I heard he and co-conspiriter Harold were tying up some loose ends to get it to the event, I motored over there in the Caterham. I got a shot of it on the trailer. I didn't shoot it at the event, but I'm here to tell you Steve and some other folks got it around the course in a respectable time. I don't know how old those Avon hillclimb tires are...
  17. Minnesota is a two-plate state, but Collector Class (20 years old) cars, AND cars old enough to eligible for Collector Class even if not registered that way, only need to display a rear plate. I may get away with not having a rear plate light on the Birken. Or do what I did with a former trailer; install the plate using mounting bolts incorporating directional LEDs. I think I even saw an MK Car so-equipped in one of their promo pix.
  18. Last week
  19. 1994 S7 -- a year or two ago, I would have just ordered from Caterham. Any US sources of stock or high performance shocks? Street car, so don't need anything super trick. Need fronts. Suggestions? THANKS!
  20. I’m filing that under “seven immunity” like not mounting my front license plate.
  21. Mike, PM sent with my contact information. The trailer has been undergoing a further refurbishment. I am pretty compulsive when it comes to my equipment
  22. I'm not certain, but I think engine OFF, ignition ON is legal in most states.
  23. Just. Wow.
  24. These are all vintage components that would be required for a 1600 BDR kit. Complete from intake to collector. From the pictures of a BDR kit, the exhaust pipes and collector are not provided. Cosworth head has been machined, welded and pressure tested by a machinist who also builds Top Fuel motors. New custom valve guides were installed along with strong recommendation to use new valves. The head is marked with “EC 72” and other markings. The original head work was performed by Vegantune using their cylinder head components. Cosworth cam tray has “BA” markings and contains reinforcing blocks fitted at the first cam support. BDD race cams were reground by Schneider to 284 duration with 0.400 lift. These cam specs still provided over 9K with a steel rotating assembly on the Schlossnagel engine dyno where 185 HP was recorded. Cosworth intake manifold is port matched to the head. Cosworth pistons and all sprockets are included with 56 new and used top hat shims. Cosworth/Ford cam cover contains a plaque with the Vegantune ID number. The Caterham exhaust pipes for the 3 bolt flange are sand formed and the fitted collector and are no longer available making these exact fit headers very rare. The headers and collector have been powered coated. Time to divest of remaining Lotus, Caterham and Cosworth parts, still "super7guy7@yahoo.com" Asking $4K or OBO, located in San Diego,CA Cosworth cam card.pdf Cylinder Head Service.pdf
  25. I am trying to find a pair of the rear fender stone guards seen in this picture (this is my old car, my new one does not have them) also I need new wiper blades. Any help appreciated.
  26. Rodnok, Have a pair of NOS undrilled clams with depression for hood clips as advertised here. Also have a collection of S2, S3 and Caterham spring clips. Pics upon request. Located in San Diego, CA
  27. Hello Dr. Bob- I am a new poster here, but a long-term lurker. I am very interested in your car. I live outside Atlanta, but am currently in Satellite Beach assisting an elderly relative for a few days. I would like to come meet you and see your Stalker. My schedule will have me passing through your locale early next week. Mon. - Wed, most likely, but I am flexible as to timing. I'm a prior FormulaFord and FormulaContinental racer, and am looking for a street/track car as my entering retirement prize (currently 64). I'm asking you to PM me rather than posting my phone number for obvious reasons. Hopefully that is viable, given this is my first post here. I look forward to hearing from you and meeting. Thanks!! Mike
  28. Very Nice Darren, I manage to get my hands on CROC’s CSR when I visit him at New Jersey Motorsport Park… In my opinion, it’s the finest Seven ever produced…. Best of Luck ..
