Everything posted by ashyers
The lock is standard. It's sold by these guys: https://www.gorilla-auto.com/cap-locks-cap-screws I purchased a set for some 16x7 wheels to get a key since the original owner lost the key.
Nut keeps coming loose - any long term solutions?
ashyers replied to KnifeySpoony's topic in General Tech
"I can only assume no movement, but how can I know for sure?" If there is movement it will likely show up as galling/wear on the clamping surfaces. That would indicate a loss of clampload do to some part in the stack yielding. -
jeffs, The TPS could be going downhill. That would cause the mixture to go bonkers. You could check the signal with a meter and see if you get a clean sweep from idle to WOT. Andy
Between the inner shell of the bushing and the bolt/washer/chassis. -
Any signs of relative movement between the clamped surfaces? -
jeffs, If you have an infrared thermometer you can check the header tubes to see if it's dropped a cylinder. A somewhat cruder method is to flick a bit of water on the tubes and try and determine if you have a cold one. In addition check the harness connection at the coolant temp sensor. If it's sending wonky values occasionally that will seriously mess up the fueling. What MBE/easymap system are you running? Andy
Replacing spherical bearing in front lower control arm
ashyers replied to ashyers's topic in General Tech
CarlB thanks for the help. Here's the magic tool I used. A bit of corrosion on the stud of the spindle bonded that sucker to the bearing quite well. I'm shocked how hard it was to remove. Needless to say it was reassembled with some antiseize. As far as the nuts, I machined some top hat bushings and used some 1/2-20 jet nuts I had on hand to replace the factory's set up. I replaced the factory spherical bearings with some NHBB bearings. These made quite a difference in the steering since they have low breakaway torque. One of my favorite parts of the car is the steering feel and it's now even better . Andy -
Have you used some rotor paint to see where your temps are? Andy
Hi All, I'm replacing the spherical bearing in the lower control arm of my '03 SV. The threaded portion of the spindle seems to have permanently attached itself to the ID of the bearing and whatever spacer is in there. My '03 uses the special machined lower nut (now obsolete) and a spacer between the top of the bearing's ball and the spindle. I'm guessing that there's also a sleeve of some sort in that is preventing the removal of the control arm from the spindle. Anyone have any tricks, besides anti-seize on reassembly ! Thanks, Andy
John, It was a Pace dry sump, but I have a Raceline sump in the Shop. They're very similar as far as the scraper and windage setup. I chucked the studs up in the lathe and trimmed them a bit for clearance. I suspect you could do the same with the bolt's heads with no ill effects. Andy
John, Looks like fun! If it makes you feel any better, I had to trim a few of the ARP studs to fit the dry sump to my engine. They needed to be flush with the pan rails so the scraper and windage tray would fit. I look forward to seeing how this all works out. It should be a really fun engine, big displacement and revs . Andy
It appears to have A/C!
Check to see that the washers used to center the A-frame in the chassis are not rubbing on the OD of the A-frame that retains the bushings. If set up incorrectly they will make quite the racket!
I was watching that exact video last night! Good stuff! It was scary watching some of the off track excursions, those drivers had guts.
KnifeySpoony, I'm sending you a PM now. Andy
As I said earlier in the post, my '03 SV is very similar to UlfarE's and was built with a 2.3L Duratec from a Ranger. It received cams, rods, pistons, porting, ITB's, MBE967 and a dry sump. I suspect both cars may have been built by William Sours of Autocourse. I'll bet if UlfarE checks his motor mount they are not Caterham parts, but fabricated by the builder. I think Autocourse was using Zetec cars as a basis for Duratec builds early on. Not that any of this really matters, if it runs good who cares !
UlfarE, I'm running the same ECU. It's a nice unit and reasonably easy to get the hang of. The "Woody" reference is to a shop owner who serviced some Caterhams in this area years back. Get in touch when you want to play in the East Bay Hills Andy
Your car may have been built/sold by Autocourse which was run by William Sours. Some of the details look very similar to mine and that's where it originated.
The SBD unit is an ITG, guess how I know :). I suspect the orig. filter material deteriorated like mine did. The foam doesn't like UV much and eventually falls apart. You can buy replacement foam, but I'm not sure it's worth the effort of installation compared to a new unit.
Check under the dash for the ECU. I wonder if this is a Woody car.
Ulfar, Looks like the setup is nearly identical to mine from the Hillbank photos. It's an ITG filter. Hopefully the same knuckleheads that built the original motor in my car had nothing to do with yours. Lots of expensive parts and crap attention to detail. Runs good now, but not without a bit of work! The Duratecs are pretty easy to deal with. Andy
UlfarE, Where are you located? I'm in Oakland and have an '03 SV with a 2.3L Duratec. I know a bit about 'em, at least enough to be dangerous . I'm in agreement that I hope the car was not run too often w/o filters, but what's done is done. I suspect it uses the same filter as mine. If you post a photo I should be able to tell. Get in touch if you're over in the East Bay and I'd be happy to look the car over with you. Andy
If you have an MBE9A4 you should be able to look engine parameters there with no issues. You could install a switch to "tag" your data stream if an event occurred.
John, If you would like some measurements of the hole in my bonnet and trumpet relationship I'm happy to take them, but be warned, the motor mounts are not factory Caterham. My car is an early '03 Duratec and has some non standard parts. Tell me what you'd like as a reference point and what you need for measurements. Andy
